Hi Everyone,
I have a 2006 Dodge Caravan with the passenger window not working. I have another 2006 Grand Caravan that I am stripping parts off of, and the Grand Caravan has a working window regulator that I want to use. I went to remove the regulator and found the regulator is attached to the door with what looks like very large push pins.
I have never messed with plastic pins like that. I watched a you tube video where the man used a chisel to cut them off as new regulators come with new plastic pins. I am using a used unit so cutting them off is not an option. Can I pry the pins out and re-use them. If so, any tricks to getting the pins out?
Thanks for your time,
Brad
Brad
