How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
141 registered members (14Accent, 762fermeandyou, 4WD, alphadog, Al, archibald2, 12 invisible), 1,883 guests, and 15 spiders.
Topics302,056
Posts5,208,234
Members70,826
2006 Caravan... how to remove window Regulator #5335057 01/28/20 11:10 PM
DeafBrad Offline OP
Hi Everyone,
I have a 2006 Dodge Caravan with the passenger window not working. I have another 2006 Grand Caravan that I am stripping parts off of, and the Grand Caravan has a working window regulator that I want to use. I went to remove the regulator and found the regulator is attached to the door with what looks like very large push pins.
I have never messed with plastic pins like that. I watched a you tube video where the man used a chisel to cut them off as new regulators come with new plastic pins. I am using a used unit so cutting them off is not an option. Can I pry the pins out and re-use them. If so, any tricks to getting the pins out?
Thanks for your time,
Brad
Toyota Echo 250,000 + miles
Geo XFI 50+ mpg
Honda CBR250r 65+ mpg
Re: 2006 Caravan... how to remove window Regulator [Re: DeafBrad] #5335060 01/28/20 11:16 PM
dishdude Online Content
Online Content
It sounds like they're a single use plastic pop_rivet. Can you substitute a nut and bolt or source the pins separately?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: 2006 Caravan... how to remove window Regulator [Re: DeafBrad] #5335063 01/28/20 11:20 PM
1
14Accent Online Content
Online Content
1
This video shows how he removed the pins without breaking them. Whether they can be re-used, or this even works, is something you'll have to find out for yourself. I couldn't find a source for just the pins with a quick Google, but someone may make them..
Link to video: Caravan window regulator R&R
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2006 Caravan... how to remove window Regulator [Re: dishdude] #5335064 01/28/20 11:22 PM
DeafBrad Offline OP
I tried briefly to source something but no luck. Just now I tried to use a pry bar to pry a pin out. No luck... it broke. I have plenty of room to get my hands inside the door so bolts may be a good plan.
Geo XFI 50+ mpg
Re: 2006 Caravan... how to remove window Regulator [Re: 14Accent] #5335072 01/28/20 11:38 PM
DeafBrad Offline OP
Thanks for the link! In the video he showed how to remove them without breaking them but when he installed them he used bolts. He said he wouldn't wish it on anyone.
Geo XFI 50+ mpg
Re: 2006 Caravan... how to remove window Regulator [Re: DeafBrad] #5335091 01/29/20 12:43 AM
1
Online Content
1
I'll admit, I didn't watch to the end, and oddly enough I've never had to do a regulator on that generation Caravan, but if he used bolts I would just follow that advice. I've used 1AAuto videos plenty of times in my line of work, they aren't always perfect but they really do seem to lay it out in layman's terms to help you get the job done.
I re-watched the video, and he didn't seem to specify what type of bolts he used, but since he said he used a screwdriver I would assume he used machine screws and nuts to secure the motor. That's as good an option as any, although I would have just used nuts, bolts, and washers.
Good luck on the project!
Re: 2006 Caravan... how to remove window Regulator [Re: DeafBrad] #5335156 01/29/20 06:49 AM
Z
zrxkawboy Offline
Z
NAPA has a good assortment of pins/fasteners...maybe they have a suitable replacement.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: 2006 Caravan... how to remove window Regulator [Re: DeafBrad] #5335180 01/29/20 07:21 AM
SeaJay Offline
These door assemblies are engineered for ease of manufacturing with no worries on what consumers need to do to repair if broke.
