Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
108 registered members (28oz, Anduril, 750IX, 2013ecof150, 2012AccentSE, alchargo, 5 invisible), 2,397 guests, and 19 spiders.
Topics301,901
Posts5,205,044
Members70,798
Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? #5335021 01/28/20 09:51 PM
R
RonRonnster Offline OP
R
My dad just bought a used 2015 F150 with the 2.7L EcoBoost. Will mostly be a second vehicle for him and something to put an ATV in the back or pull a side-by-side on a utility trailer. I'm reading the Owner's Manual and finding Ford is only mentioning 5W30 API SN - nothing past that. Since this engine takes 6 quarts exactly, it seems like this would be a good candidate for the 6-quart Havoline Box? First EcoBoost engine in the extended family.
[Linked Image]
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335027 01/28/20 09:57 PM
chemman Offline
Yes, a good choice. It's a very good oil.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335029 01/28/20 09:58 PM
W
wallyuwl Offline
W
You would be fine with the Havoline. I have run it in my second gen 5.0 (DI but not turbo).
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335038 01/28/20 10:20 PM
N
nlife Offline
N
You'd have to look online to see what the latest oil specs are for that particular model year, but the d1g2 license exceeds any requirement currently in place by Ford.
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335049 01/28/20 10:45 PM
R
R
I did find the specification in the online owners manual - seems to be WSS-M2C946-A which Havoline says they meet, so we should be good there. Also, good point on D1G2.
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335074 01/28/20 11:45 PM
P
pitzel Offline
P
Idaho...I'd be aiming for a 0W-30 personally. It can get very cold there.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335160 01/29/20 06:54 AM
M
metroplex Offline
M
Ford basically calls out a non-synthetic 5W-30 as a minimum requirement for their EcoBoost engines. When EcoBoost first came out on the MKS and SHO, I believe they called out 5W-20! Then when the first F-150 EcoBoost engines first came out, everything was then specified for 5W-30 (naturally aspirated engines still call out 5W-20 in the manual). The Ford GT is the only exception for EcoBoost engines as it requires 13.7 qt of Castrol Edge Supercar SAE 5W-50 WSS-M2C931-C. The track cars like the Shelby GT350/R/Boss 302/GT500 typically use 5W-50 Motorcraft synthetic.
The pre-17 F-150 2.7L EcoBoost is 99.9% the same engine as the 2.7 EcoBoost used in the Edge Sport/ST and Ford Fusion Sport. The oil pans tend to leak, but the cartridge filter is easy to swap out. My Fusion Sport is pretty easy on the oil, I generally use 6 qt of any OTC full synthetic 5W-30 like Pennzoil Platinum. The difference between the pre-17 truck 2.7 and the transverse 2.7 is the truck uses different turbo packaging and has an engine oil cooler mounted by the oil filter cap. The turbo difference is minimal, the compressor speed curves are different but the other parts of the compressor maps are identical. Camshafts, manifolds, etc... are all the same. Post-17 is different because trucks got split injection while transverse did not.
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335296 01/29/20 09:19 AM
CT8 Offline
In 2015 there was nothing past SN
2015 F150 2.7
2018 F350 6.2
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: wallyuwl] #5335331 01/29/20 09:58 AM
1
1978elcamino Offline
1
If you have the newest Gen 5.0 with dual port and DI its a 3rd gen.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335427 01/29/20 12:09 PM
bdcardinal Offline
I would not hesitate to use the Havoline. Its a good oil and the 6 quart container is super convenient for your engine.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford oil spec for 2015 F150 w/ 2.7L EcoBoost? [Re: RonRonnster] #5335513 01/29/20 01:43 PM
B
BucDan Offline
B
That looks like good oil. Has it's Dexos cert, and funny enough, glug free pour, haha.
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
