Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
101 registered members (A310, 69GTX, 55hambone, ArrestMeRedZ, ammolab, 10 invisible), 1,814 guests, and 19 spiders.
Topics302,059
Posts5,208,286
Members70,826
Parasitic battery draw. #5334941 01/28/20 07:49 PM
W
wtd Offline OP
W
About a month ago, my fiancées 1994 cavalier started killing the battery in about a weeks time. Since the battery was five years old we just thought it had finally went out because it was so dead it wouldn't even charge. We replaced it and about a week later it was dead again, down to 10% charged.
I tested the alternator with my tester and then took it to parts store for them to test and it showed it was charging at a high rate, about 15.6 to over 16 volts so we replaced it under the lifetime warranty. A week later the battery is dead again.
So now I finally get smart and use my multimeter inline with my negative battery cable and the negative battery post and find that I'm getting a 95 milliamp draw with the interior lights off and door closed. This car also has a switch on the dash to operate the dome lights which was turned off. I start pulling fuses one at a time and find that the CTSY fuse circuit is what is causing the draw. The things that are on this circuit are: Interior lights, Horn, Power Locks, Audible Warning system, remote liftgate release(which this car does not have) and the Check oil light.
I thought that it might be either the power locks(since they would click and make noise when you would attach the negative batter cable back on the battery with the door open and the CTSY fuse in) or the Audible Warning system because the key in ignition alarm would still sound after taking out the key with the driver's side door open. Ignition switch was just replaced which also deals with this alarm and the battery still drained down so I don't think it's that.
I went to the junkyard and got another Multi function alarm module which is part of the audible warning system since it has a speaker in it and the dinging noise comes from it. I installed it and still the same draw at the battery. I disconnected all of the connections I could find in the driver's side door and the dome light switch in the dash with no results. I disconnected the horn pad and that did nothing.
I disconnected a big black connector that is mounted right next to the alarm module and the battery draw went back to normal. This black connector has tons of wires on both sides and I can't really tell where it goes since it's up under the dash on the driver's side. I have not taken the passenger side door panel off to disconnect all of it's connections but I don't have high hopes that it will solve anything.
This car also doesn't have the typical door jamb switches for the dome light but rather a door handle activated switch which I don't know how it works because with the door panel off, there are no switches mounted to the back of where the handle attaches and I can't see anything else in the door that would be a door switch.
so I'm kind of at a standstill. I'm not the best at diagnosing electrical stuff so what else should I be doing to try and track this issue down? Thanks for any input or advice.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: wtd] #5334959 01/28/20 08:23 PM
StarCaller Offline
I had the same thing on a 2000 cavalier; ended up putting one of those disconnectors on the battery /
Re: Parasitic battery draw. [Re: wtd] #5334973 01/28/20 08:41 PM
R
rubberchicken Online Content
Online Content
R
Sounds like you did a great job so far.
Re: Parasitic battery draw. [Re: wtd] #5334987 01/28/20 09:07 PM
gathermewool Online Content
Online Content
Can you elaborate on this?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Parasitic battery draw. [Re: wtd] #5334993 01/28/20 09:18 PM
samven Offline
It sounds like you have done more than most dealerships. I dont know what it is about older cars and trucks but something causes them to draw more parasitic load. Did you ever notice that the factory installed battery last 6 or 7 years and the replacement might go 4 or 5 and then every one after that only seems to last 2 or 3. It seems to happen on every car I have ever had ( I tend to drive the wheels of of them before replacing) I am going through the same thing with a 03 Ram. When the battery is first connected I get a large draw about 300 ma then after 5 or 10 min it drops to 100 ma then finally after 30 min to 50 ma. If I start with a fully charged battery after 4 days or so its down to 50%. No way a 50 ma draw is draining a 1000 CA battery down in 4 days so something else is turning on and off and drawing it down. I have read that certain EVAP test will kick in if the fuel level is right and the temp is in a certain range and the engine has been warmed up for a spec time before shut down. I have used the disconnect switches but I hate too because of the ECM and learning mode it goes into and I am not crazy about shocking that expensive computer all the time. Like you I know something is going on but darned if I can find it. Now I have a 10 watt solar panel in the window plugged into the aux port when it sits.
Re: Parasitic battery draw. [Re: wtd] #5335002 01/28/20 09:27 PM
A
atikovi Offline
A
You can't rely on pulling fuses on modern cans with multiplexed electronics to diagnose drains. Pulling a fuse on one circuit can awaken a module on different circuit. You need to do a voltage drop test across the fuses.
Re: Parasitic battery draw. [Re: wtd] #5335010 01/28/20 09:32 PM
P
pitzel Offline
P
On my 1992 Oldsmobile, there was a relay that energized a seat belt tensioner solenoid that tends to go bad after a while and stays in the powered up state. Took me a decade to track it down, but once I unplugged that, magically my battery drain issues went away.
A 1994 Cavalier, I can't say it has the same issue, but they're certainly comparatively very simple compared to the modern stuff.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Parasitic battery draw. [Re: gathermewool] #5335014 01/28/20 09:39 PM
W
wtd Offline OP
W
This black wiring connector is mounted to the convenience center next to the Alarm module and up past the fuel panel. It probably has 20 wires or more coming out both sides. It is secured together by a bolt. All of the wires are wrapped in that black tape and it looks like it goes up into the dash as well as other directions. I have no idea what those wires power. I only have the basic Haynes and Chilton manuals for this car so it doesn't really tell much and the wiring diagrams are not the best.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: StarCaller] #5335016 01/28/20 09:40 PM
W
wtd Offline OP
W
Her dad suggested doing that and is what may happen if I can't figure this out.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: wtd] #5335017 01/28/20 09:47 PM
F
FordBroncoVWJeta Offline
F
I'd just leave the fuse out.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Parasitic battery draw. [Re: samven] #5335018 01/28/20 09:47 PM
W
wtd Offline OP
W
When she got home from work yesterday, I checked the battery and it was 100% charged so I know the alternator was doing it's job. I checked it this morning before she left for work and it was at 25% charged and the battery voltage was at about 11.8 volts. She took my car to work and I messed with hers all day. This car is fairly basic so I'm not sure if other things are turning on during the night and I don't think the ECM goes into any learning mode but I could be wrong. All I know is that it's driving me crazy.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: atikovi] #5335019 01/28/20 09:49 PM
W
wtd Offline OP
W
I'm not exactly sure how to do a voltage drop test on the fuses so I will have to do some research on that.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: pitzel] #5335024 01/28/20 09:54 PM
W
wtd Offline OP
W
The connectors going to the seat belt retractors were one thing that I did not connect inside the door. I'm not sure if it has a seat belt tensioner solenoid. I don't remember seeing anything mentioned in the service manuals about it but I will look again. I will also unplug the retractors and see if that makes a difference.
I dread taking off the passenger side door panel since the driver's side was pretty difficult and I ended up breaking some plastic since it's fairly cold out and the plastic is brittle from age.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: FordBroncoVWJeta] #5335030 01/28/20 10:08 PM
W
wtd Offline OP
W
I thought about that but the vehicle speed sensor wiring goes through the alarm module and I didn't know if leaving out the fuse will mess with that. From reading about this alarm module, it's almost like it's the predecessor to the BCM that is in the newer vehicles these days. It controls the power locks, the interior lights, the auto dimming dome light, the power auto lock feature, and the wiring going to the seat belt retractors.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: Parasitic battery draw. [Re: wtd] #5335054 01/28/20 11:02 PM
1
14Accent Offline
1
Great job so far, you're farther along than most real mechanic's would be at this point. It reminds me of an old 2000's Stratus I worked on that had all kind of electrical issues due to a shorted ignition cylinder lockout solenoid. That was a fun one to track down...
Looking at the wiring diagram, assuming this isn't a convertible or wagon, the following are powered by the CTSY fuse:
LF door lock sw
RF door lock sw
Luggage compartment lamp
Dome lamp
Instrument cluster
Multifunction alarm module
Horn relay
Door unlock module
Given that you already ruled out the alarm module, and the drivers door switch, I would next try the passenger door switch. I know it's a pain. The dome light and luggage light are easy, just look to see if they're on. The horn works, I presume, so that's not a likely culprit. The only things left are the IC and door unlock module.
I couldn't actually find any reference to a "door unlock module" in the service info, but I did find reference to an "Automatic Door Lock Relay" that's supposed to be behind either the passenger kickpanel or behind the passenger side of the dash (Behind I/P on Right Shroud is what the manual says). This relay is activated by either the multifunction module OR either door lock switch. It's basically a two in one relay, where one side controls the lock function and one controls unlock. Try unplugging this relay and see what happens.
Also, when you find this relay, as another test, which I would do with the multifunction module DISCONNECTED (since you've ruled it out by swapping): with no door lock switch pressed check for voltage on either the black wire, pin F, or the light blue wire, pin A. If you have voltage on either of those with no switch pressed, there's a problem. The switches splice together before the relay, so because you've already tried disconnecting the drivers side switch it would point to either the passenger side or a short to power somewhere. If there's no voltage on either wire, you've got a short somewhere.
Just for reference, the multifunction module only controls the lock function, not unlock. So if the problem is on the unlock (black) wire, it can't be the module. The diagrams are very confusing, when I look at the power distribution diagram it's called a "Door Unlock Relay" but everywhere else in the service manual it's called an "Automatic Door Lock Relay". It serves both functions, however the lock side it the only one that the multifunction module has control over. Very weird.
Hope that helped a bit! A couple vodka's make it harder to translate diagnostics into words smile
*Edit again* If all that fails, you would have to start looking at the things controlled by the multifunction module. The only other outputs I can see on the module are the seatbelt retractors, as mentioned previously. Do all the seat belts work? None are locked up? Another easy check, although you may have already done this.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
