06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
108 registered members (Atrocious, ArrestMeRedZ, 1978elcamino, 10WSmuckers, 50jeffrey, Alfred_B, 9 invisible), 2,844 guests, and 55 spiders.
Topics305,906
Posts5,282,552
Members71,535
Page 2 of 3 1 2 3
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334764 01/28/20 04:05 PM
O
Onetor Offline
O
I would stick with OEM, Raxles (as mentioned above) or CVJREMAN.com. Let us know what you decide and a follow up report if you have a chance.
N = R* x fp x ne x fl x fi x fc x L
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334776 01/28/20 04:30 PM
spavel6 Offline
I just did one on a friend's car a month or so ago. Same symptoms, rattling around turns. I believe their's is a 2014 Crosstrek.
Took about 30 minutes without removing anything - Just the axle nut.
Didn';t even need to drain the fluid as none came out of the case when we popped the axle out.
He chose to get an aftermarket. With how easy it is to go in, I don't blame him.
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334779 01/28/20 04:35 PM
P
PandaBear Offline
P
Originally Posted by ARCOgraphite
Are any of the aftermarket axle+CV assemblies reliable?
Not unless they cost almost as much as OEM, or a junkyard pull from the same generation (for 2017 this means a collision salvage or a flood car).
Dealer wants $680-
The Subaru part goes for $400- (!)
For $280 to install it sounds like a reasonable price. You can always buy the axle and bring it to another place to install if it saves you $150 or $100.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ls973800] #5334789 01/28/20 04:45 PM
dishdude Offline
Originally Posted by ls973800
Wife hears noise once and a while, dealer assessed at the recent 60K service that the front right outer CV was failing.
How close to the 60K service was it? Your factory powertrain warranty covers this part for 5 years or 60000 miles.
If under the 60000 you have warranty. If just a little bit over, the dealer may be willing to have it taken care of as a customer good will repair if you have had services done there in the past. You may even want to check with Subaru for any good will assistance.
This is what I would be doing.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334802 01/28/20 05:25 PM
Chris142 Online Content
Online Content
The new Chinese axles seem ok. I have installed a few with no issues.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: gathermewool] #5334807 01/28/20 05:33 PM
A
ARCOgraphite Offline OP
A
Originally Posted by gathermewool
What symptoms do you have? I'd get a second opinion, unless you know what you're sure you know what it is and the dealer WAS the second opinion.
I'm curious to hear what people report, since my extended warranty is up and I occasionally hear a clicking from the front right while making tight right turns and accelerating.
Clacking from the fight front when cornering under acceleration. Seems the Axles are at an extreme angle on the Impreza.
I have to do some more "parking lot circles: to diagnose further. I've also heard of center support bearings/rubber damper going on the center drive shaft, rearward.
Never had issue like this on a Subaru over Decades. Accordion boots are fine. I might get a new boot clamp and pull the boot back and see if there are metal bits - and move the grease around. Doesnt seem any worse than any NEW 4WD truck I've owned,
Also I might make sure the axle is in all the way at the differential side. This model year the halfshaft splines just pop in, no circlips or roll pins.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ls973800] #5334813 01/28/20 05:43 PM
A
A
I think she was at 62K. We were doing "alacarte" service since they want a fourtune. They bled the complete braking system and rotated the tires and did a under chassis inspection. I did everything else - minus changing the Ruthenium spark plugs. I am not pulling 17 dollar long ife plugs at 60k/3 years that should be 100K easy. Engine runs great no misfire, good fuel mileage.
I also did the last two OCI since they mess those up terribly.
I would had done the plead for leniency but the wife did this on her own and is not a barterer.
Maybe I can get her to call SoA. I would plead my case to the Service manager and owner. I dont know them and they dont seem like nice guys.
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: dishdude] #5334815 01/28/20 05:45 PM
M
maxdustington Offline
M
Aftermarket axle on a 2017 with 60k, lol. If a CV went on a car I bought new at 60k I wouldn't be paying for it. The dealer is trying to soak you, OP.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: spavel6] #5334818 01/28/20 05:47 PM
A
A
Thanks for the first hand knowledge
Did the '14 Crosstrek have a roll pin at the diff end? Or did you just pry it out of the case with a big bertha?
-thx - Ken
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: maxdustington] #5334821 01/28/20 05:53 PM
A
A
Really? Around here even if you are a bit within warranty mileage they deny smile
But they are overcharging on labour, but Subaru shop manual wants tech to unbolt the strut from the hub assy and the redo the FEA, The shad tree "cheat" is to separate the lower ball joint so no alignment is required then the job is only 1/2 hour after the car is in the air and the tire is off.
They soaked my wife for $228 to just bleed the brakes!
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: supton] #5334829 01/28/20 06:01 PM
A
A
Originally Posted by supton
Seems early to go out. Is the boot split? Wondering if it's a proper diagnosis.
IIRC you swap out cars often; is this a real problem? I mean, if you're just going to trade soon...
She thinks its going to explode(!) and fail, then she said the car is worthless as it is smile
A little overreacting(?) But she does have a high speed (75mph+) interstate commute for a bit down 495-S from Haverhill, MA to Andover , MA as she is heading to Wilmington, MA to Charles River Labs at 4 in the AM. Yeah, 4AM.
The boot is fine. The car is only 3 -1/2 years old. The "jacked up" impreza that is a Crosstrek puts the halfshafts at an extreme angle.
This must "do a job" on the outer fronts.'
IDK.
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334920 01/28/20 08:29 PM
W
wdn Offline
W
The actual Impreza though, not the jacked up Impreza with plastic body cladding, has the axles at a completely normal angle for a car. It is very unusual part to go out at 62K miles and not be caused by a torn boot where the grease leaked out and dirt got in. More like 10 year lifetime on the OEM part. You might check Crosstrek forums but the actual new gen Impreza 2017+ are not calling this a problem area. The Chinese axles have put a lot of the local rebuilders out of business. The local car guys radio show said the Chinese axles are quite good now and inexpensive. Their opinion was it is hard to justify using a reman when you can buy one of the new Chinese ones have a lifetime warranty like Raxles, cheaper than a reman. Lifetime meaning they will give you one free replacement part. For a 3 year old car it would be natural to want the genuine Subaru part. I should think Subaru corporate would do maybe a 50-50 good will repair or provide the part free and dealer charges for labor only. Have a reasonable expectation though because 62,000 is still past the warranty. Good luck.
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334961 01/28/20 09:25 PM
G
gregk24 Offline
G
Call Subaru Corporate and ask for goodwill assistance.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: Miller88] #5334970 01/28/20 09:37 PM
B
BISCUT Offline
B
Originally Posted by Miller88
I would not recommend running aftermarket axles in a subaru. I'm in a few facebook groups for Subarus and the aftermarket ones are problematic. I'd try to find a junkyard one in good shape and reboot it before running an aftermarket one
I've heard from my friends who are mechanics a similar story. My buddies recommend a full axle replacement and NOT aftermarket. They say they don't last.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(46k)
2017 Sub OB M1 5-30 EP FRAM Ultra(76k)
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5335003 01/28/20 10:27 PM
gathermewool Offline
Rule #173B: it never hurts to ask and Subaru of America is EXTREMELY easy to contact!!!
Also, stop blaming your wife for high PMS costs; are you completely out of the loop when hundreds of dollars are being spent????
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Page 2 of 3 1 2 3
