Robocalls stopped for now...
by rekit - 02/20/20 02:27 PM
Pennzoil 0w30
by Eddie - 02/20/20 01:55 PM
Using an upper cylinder lube for lean running engine?
by dunlop0078 - 02/20/20 01:45 PM
New Ford Escape...1.0 liter...really?
by grampi - 02/20/20 01:34 PM
I need information on these filters
by 4fordsd - 02/20/20 01:18 PM
WashZilla
by John_Conrad - 02/20/20 12:56 PM
Continental WinterContact TS870
by SubLGT - 02/20/20 12:52 PM
What sort of ATF and is Merc V synthetic?
by Stinky123 - 02/20/20 12:37 PM
Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
AAIRCraig, Jason454, Max331, 4fordsd, Mayberryminitruc
70760 Registered Users
118 registered members (Alfred_B, 1978elcamino, Anduril, 4fordsd, 53' Stude, allepunta, 11 invisible), 2,259 guests, and 16 spiders.
Topics301,706
Posts5,201,014
Members70,760
Oil mixing...does density matter? #5334723 01/28/20 02:02 PM
L
LotI Offline OP
L
Theoretically. This crossed my mind as I was looking at my oil stash spreadsheet(nerd!).
If I were to mix my most dense oil, Valvoline Premium Blue 15w40(.880) with my least dense oil, RGT 0w-20(.833) would they mix homogeneously our would they separate if left sit for a period.
Just a thought. I wouldn't mix these oils unless the virus has completely taken over civilization and I had to!
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Oil mixing...does density matter? [Re: LotI] #5334728 01/28/20 02:06 PM
csandste Offline
Others know more than me but I'd be really surprised if oil separates. If you miss 5w30 with 5w20 it doesn't restratify once you drive it.
2017 Kia Soul Plus-- Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Oil mixing...does density matter? [Re: LotI] #5334745 01/28/20 02:34 PM
K
kschachn Offline
K
Only if they are immiscible which isn't going to be the case with those two oils. Also ASTM D6922 (part of SAE J300) addresses that, and if the oils pass that standard then they will not separate.
Different viscosity motor oils don't have that wide of a density range either.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Oil mixing...does density matter? [Re: LotI] #5334783 01/28/20 03:41 PM
I
Imp4 Offline
I
Here is an excellent thread discussing the subject.
Thanks to Shannow and TomNJ for the included content.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3503628/Re:_The_oft_quoted_ASTM_D6922
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Oil mixing...does density matter? [Re: LotI] #5334810 01/28/20 04:37 PM
L
Lou_Boyle Offline
L
All the distillation and fractionation equipment oil companies use to separate crude oil into different components is proof they won't separate naturally.
Think carefully about what you are doing, but be decisive. The road of life is paved with flat squirrels who couldn't make a decision.
Re: Oil mixing...does density matter? [Re: LotI] #5334823 01/28/20 04:56 PM
csandste Offline
There was no Bobistheoilguy in the mid sixties. But this is one of the first oil questions I ever asled. Guess I was in my early twenties and I'm mid-seventies now. Put some 10w40, noticed my new used car was full of 10w30 and called the selling dealer panicked. The answer was the same then as it is now.
Re: Oil mixing...does density matter? [Re: LotI] #5334843 01/28/20 05:28 PM
M
Mad_Hatter Offline
M
They make blended oil (different densities) already, don't they?..so you are fine.
Re: Oil mixing...does density matter? [Re: LotI] #5334846 01/28/20 05:35 PM
BlueOvalFitter Offline
I used to mix oil all the time a few years ago. None of the engines I added it to ever died.
Blend to your hearts content! thumbsup
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Oil mixing...does density matter? [Re: LotI] #5334873 01/28/20 06:08 PM
E
eljefino Offline
E
I rebuilt my saturn engine way back in the day and wanted to break it in with random leftover 1/2 quarts.
Put some 10w40 in, 5w30, straight 30, whatever.
Drained it 200 miles later.
Most of the oil came pouring out in a stream.
But there was a dribble of drops coming out concurrently.
Was it one of the random ingredients? We'll never know.
Filled the engine with all-the-same stuff afterwards and never saw this phenomenon again.
Re: Oil mixing...does density matter? [Re: LotI] #5334897 01/28/20 06:45 PM
danez_yoda Offline
in the interest of science. Pour a could of teaspoons of each in a glass container. Add some food coloring to one so you can see.
Lightly mix (dont blend bot lightly mix) put the jar in a old pillow case and swing it around (outside) as hard as you can to make a centrifuge.
Then check it after to see if the heavy stuff settled to the bottom or stayed mixed.
Re: Oil mixing...does density matter? [Re: LotI] #5334912 01/28/20 07:14 PM
L
LotI Offline OP
L
So if the API says it’s miscible they mean anything, huh?
11 Kawasaki KLR 650
Retired:
17 VW GTI
17 Mazda6 GT
Re: Oil mixing...does density matter? [Re: LotI] #5334923 01/28/20 07:32 PM
CT8 Online Content
Online Content
Motor oils are a blend of different base stocks and viscositys.
2015 F150 2.7
2018 F350 6.2
Re: Oil mixing...does density matter? [Re: LotI] #5335353 01/29/20 10:52 AM
K
kschachn Offline
K
You asked about two specific oils, both of which according to their websites are API SN licensed. Therefore both must pass ASTM D6922 as part of that license and will be miscible.
It won't depend on the density however, that is also what you asked about. Miscibility of one liquid hydrocarbon in another is not about density.
1994 BMW 530i, 251K
