Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
23 registered members (2013ecof150, AnthemBassMan, Compagnion, Black_Thunder, 4 invisible), 1,000 guests, and 17 spiders.
Topics301,684
Posts5,200,469
Members70,756
Page 1 of 3 1 2 3
Uh Oh. Subaru Front Halfshaft CV Going Bad #5334698 01/28/20 01:25 PM
A
ARCOgraphite Offline OP
A
Wife hears noise once and a while, dealer assessed at the recent 60K service that the front right outer CV was failing.
2017 Subaru Crosstrek w/ CVT
Question.
Are any of the aftermarket axle+CV assemblies reliable?
The Job looks easy enough if you separate the lower ball joint - about 1 hour
Dealer wants $680-
I can get aftermarket axle assemblies for about $100.
The Subaru part goes for $400- (!)
Anybody here have aftermarket front CV +axle replacement stories to share ?
Thanks, Ken
p.s: I have to run out for a couple hours, be back around 4:30 PM EST.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334700 01/28/20 01:31 PM
2
2strokeNorthstar Offline
2
I’ve had better luck with junk yard CV axles than reman. Reman don’t last and sometimes will vibrate right out of the box.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334701 01/28/20 01:33 PM
supton Offline
Seems early to go out. Is the boot split? Wondering if it's a proper diagnosis.
IIRC you swap out cars often; is this a real problem? I mean, if you're just going to trade soon...
Reading various threads here have me thinking that aftermarket CV's are kinda hit or miss. Depending on the level of work I might be willing to try a cheapie once or twice, especially if it was quick and easy to swap out and to keep swapping in. OTOH my time has some value and I might prefer to do it just once.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334704 01/28/20 01:39 PM
N
nthach Offline
N
On an old Nissan Quest my parents had, I went through 3 Cardone remans, I asked AutoZone for a refund after the 2nd one. I went to O'Reilly and bought a reman expecting another shoddy one, that 3rd one was actually a Chinese new axle that seemed to work better.
The Chinese stuff is hit or miss, I think if you get a decent one like GSP or Surtrak, it might be OK but still YMMV. The VW Vanagon guys are using Chinese ones as a "budget" fix if one can't afford the OEM GKN(Lobro) or 944 upgrade.
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334715 01/28/20 01:48 PM
J
JTK Offline
J
That's an odd one for a 2017 of any make/model.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334718 01/28/20 01:51 PM
gathermewool Offline
What symptoms do you have? I'd get a second opinion, unless you know what you're sure you know what it is and the dealer WAS the second opinion.
I'm curious to hear what people report, since my extended warranty is up and I occasionally hear a clicking from the front right while making tight right turns and accelerating.
This likely isn't helpful any longer, but I had major issues replacing half-shafts in my previous '97 Legacy. By the third axle from second auto parts store (Advanced, I think), it fit perfectly but vibrated noticeably at certain RPM. The first replacement vibrated worse and the second was way too short (maybe they boxed the wrong shaft?) By too short, I mean the boots on either side had to be stretched comically before each side was even fully inserted.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334719 01/28/20 01:52 PM
1
1978elcamino Offline
1
why not try a Napa part, they are the go to for a Jobber
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334726 01/28/20 02:05 PM
M
Miller88 Offline
M
I would not recommend running aftermarket axles in a subaru. I'm in a few facebook groups for Subarus and the aftermarket ones are problematic. I'd try to find a junkyard one in good shape and reboot it before running an aftermarket one
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334727 01/28/20 02:06 PM
B
brages Offline
B
In 2014, I replaced the axles in my 2005 Odyssey with Advance Auto/Carquest "ToughOne" cheap aftermarket. These Odysseys have a problem where the inner boots lose all their grease and then start causing vibrations on acceleration.
I put the aftermarket axles on and the vibrations stopped.
BUT
Right before we were were about to go on a big trip, my wife had the tires rotated and the tech noted a large amount of grease inside the driver's wheel. The boot on the ToughOne outer CV had failed. So I got a new axle from Advance and put it in, no problems - lifetime warranty.
So, my experience -- if replacing the axle isn't a huge hardship, go ahead and save some money. If you are paying someone else to do the work, or if it is a really hard job, maybe get something better...
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334733 01/28/20 02:16 PM
slacktide_bitog Offline
Raxles is the only reman worth using. They offer axles for all Subarus smile
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334737 01/28/20 02:20 PM
R
racin4ds Offline
R
NAPA Premium in my '08 Legacy, not a single issue. Went right in and almost 2 years later its still fine. I think I paid $79 for it versus over $200+ for OEM...
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334743 01/28/20 02:32 PM
L
ls973800 Offline
L
How close to the 60K service was it? Your factory powertrain warranty covers this part for 5 years or 60000 miles.
If under the 60000 you have warranty. If just a little bit over, the dealer may be willing to have it taken care of as a customer good will repair if you have had services done there in the past. You may even want to check with Subaru for any good will assistance.
2019 Honda Pilot Touring AWD
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: brages] #5334749 01/28/20 02:41 PM
M
Miller88 Offline
M
I've gone through a few of those Advance Auto CV shafts in my Jeep*
*I use them as a fuse so I don't blow up the differential. I am not easy on them. Honestly surprised at how well they hold up. The last one I managed to snap the shaft off and the joint stayed intact!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ARCOgraphite] #5334751 01/28/20 02:46 PM
A
ad244 Offline
A
I've had really good luck with the Napa CV offerings on my Toyota. Others have reported the same (in the toyota world).
Re: Uh Oh. Subaru Front Halfshaft CV Going Bad [Re: ad244] #5334756 01/28/20 02:52 PM
diyjake Offline
Reman or new ones? I need a passenger side axle for my 09 camry
Page 1 of 3 1 2 3
