International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
109 registered members (1978elcamino, ammolab, Aichiguy, 28oz, alex_at, 01VFR, 7 invisible), 2,403 guests, and 20 spiders.
Topics301,905
Posts5,205,137
Members70,798
Power Steering Fluid for 54 Chevy #5334492 01/28/20 08:54 AM
T
ThomasJ49 Offline OP
T
My 54 Chevy calls for hydraulic fluid to be put in for the power steering. My question is, is power steering fluid and hydraulic fluid the same, can I just buy any power steering fluid to add or will I need to be specific and use a hydraulic fluid.?
TIA
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334542 01/28/20 10:01 AM
MolaKule Offline
Global Moderator
Global Moderator
Power Steering fluid and ATF are special forms of hydraulic fluid.
I think the PS fluid back then was Dexron/Merc fluid which had a viscosity of 7.5 [email protected], or about a 5W20.
Is this PS system the original or has been upgraded?
If original, it can probably use any mineral oil-based run of the mill Dex/Merc.
I'm a Student Pilot. Frightening, isn't it?
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334588 01/28/20 11:02 AM
W
WyrTwister Offline
W
Were Power Glide transmissions available at that time ? If so , I am guessing , what ever ATF they used ?
Wyr
God bless
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334610 01/28/20 11:34 AM
Chris142 Offline
I believe you want Type A trans fluid.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334617 01/28/20 11:39 AM
MolaKule Offline
Global Moderator
Global Moderator
According to James Dickey (former Exxon ATF fluids engineer), Type A was in play until 1957. In 1957 that's when GM introduced the upgraded "Type A Suffix A" ATF.
In 1967 the Dexron and Ford Type "F" formulations were introduced.
But the Dexron series superseded all previous Type A fluids, which is why I think any run of the mill, off the shelf mineral oil based Dex/Mercon should work in an OEM PS system.
Re: Power Steering Fluid for 54 Chevy [Re: MolaKule] #5334624 01/28/20 11:47 AM
T
T
So i'musing Dexron lll in my transmission so it'll be the same stuff in my power steering correct? From what I'm seeing the bowl that holds the power steering fluid looks to be the original one.
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334625 01/28/20 11:50 AM
MolaKule Offline
Global Moderator
Global Moderator
As I asked previously, is this the original ps system or has it been upgraded?
Re: Power Steering Fluid for 54 Chevy [Re: MolaKule] #5334639 01/28/20 12:14 PM
T
T
All I can tell is what I posted above about the original looking bowl. I've only had the car a few months and from what I can see everything looks to be original, the previous owner didn't mention any up grades on the power steering. The only upgrade I'm aware of is for disc brakes in the front.
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334736 01/28/20 02:18 PM
MolaKule Offline
Global Moderator
Global Moderator
I am assuming by "bowl" you mean the fluid reservoir.
If the transmission is a 3-speed TurboGlide or 2-speed PowerGlide then yes, I think both components would use a mineral oil-based Dex/Merc.
Re: Power Steering Fluid for 54 Chevy [Re: MolaKule] #5334778 01/28/20 03:34 PM
T
T
Okay guys thanks for the help. :-)
Re: Power Steering Fluid for 54 Chevy [Re: ThomasJ49] #5334830 01/28/20 05:01 PM
N
nascarnation Offline
N
That's a good plan.
My Chevy is 13 years newer but I run Dex III in the ps (and the convertible top hydraulics!) and it works fine.
