Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
35 registered members (bbhero, Black_Thunder, blufeb95, avi1777, ArrestMeRedZ, 14Accent, 5 invisible), 1,065 guests, and 19 spiders.
Topics301,683
Posts5,200,448
Members70,756
Shell Helix Ultra 5W-30 #5334326 01/28/20 12:30 AM
SR5 Offline OP
I just saw this stuff in Repco (Australia) today, it must be new as I’ve never seen it before.
Shell Helix Ultra 5W-30 full synthetic.
It’s a GTL (PurePlus) based oil, and according to the jug it’s made in Hong Kong.
It’s rated API SN-Plus, ACEA A3/B4, BMW LL-01, MB 229.5 / 226.5 and Renault RN 0700 / 0710.
This is the first SN-Plus (for LSPI control) and A3/B4 (for high HTHS) oil I have ever seen in the wild.
Do you have it in North America? It would probably be called Pennzoil Platinum Euro of some sort.
Looks like a top quality oil to me.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334327 01/28/20 12:46 AM
E
edyvw Offline
E
I think we do, but it is hard to find.
5W40 pretty much meets all those requirements.
SN+ is really irrelevant because ACEA A3/B3 B4 applications really do not have LSPI issues since old VW 1.4 turbo+ compressor engine some 10+ years ago and are anyway much more stringent than SN+.
Last edited by Kestas; 01/28/20 06:27 AM. Reason: No need to completely quote the first post in the second post.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334332 01/28/20 01:24 AM
SR5 Offline OP
Our Shell Helix Ultra 5W40 is API SN and ACEA A3/B4 plus all the Euro OEMs. A great oil, but not SN-Plus or it wasn’t the last time I checked. Unfortunately I was in a bit of a rush today and didn’t check the 5W40.
I agree A3/B4 is a very high quality standard, but the last time I checked they hadn’t explicitly included a LSPI test like SN-Plus and D1G2 has. Not that I’m worried, just saying. I like how they are both MB 229.5 which means a Noack volatility of 10% or less, much better than the 13% of Dexos or the 15% of API.
I like how the new SHU 5W30 is SN-Plus and A3/B4 oil, as it allows for a one-size-fits-all approach if you have both Euro and non-Euro cars in your garage.
Lots here run the SHU 5W40 in all their regular (non-Euro) cars, as it’s such a great oil. The new SHU 5W30 should help the newer Japanese car owners who want a Euro quality oil that still meets their owners manual requirements.
BTW what’s MB 226.5 ? I’m not familiar with that one.
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334343 01/28/20 02:39 AM
K
Kamele0N Offline
K
https://www.oilspecifications.org/mercedes_mb.php
MB 229.5 + some additional Renault specs...
Since nowadays you have Renault 1.6 dCi enginrs rebranded as 1.6 CDI (or whatever MB calls them)
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Shell Helix Ultra 5W-30 [Re: Kamele0N] #5334350 01/28/20 03:26 AM
SR5 Offline OP
Thanks mate
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334353 01/28/20 03:41 AM
SR5 Offline OP
From the specs alone, we know it’s a 5W30 that has passed LSPI tests for TDI engines (SN-Plus), has a Noack of 10% or lower (MB 229.5), a TBN of 10 or more for long life ( A3/B4), a HTHS of 3.5 cP or more for extra wear protection (A3/B4) plus lots more BMW and MB test for low wear and deposit control. It would also be a full-SAPS oil, typically above 1%, so not DPF friendly. But it would be required to pass a stay-in-grade shear stability test.
I believe in Europe a typical OCI for an oil such as this is 20,000 miles or 2 years in the correct application.
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334371 01/28/20 04:51 AM
A
adams355 Offline
A
Yes, I think it is very good oil. I use the SHU 5w-40 and honestly it's the only oil I have ever put in my car that I have heard and felt a significant difference over what 'new oil sounds' I usually hear. I use my jedi skills to decide this.
The 5w-40 is still SN and has a HTHS of 3.7 cP or more.
A few months ago you could buy this oil for $45 for 5L anywhere. It is now up around the $65 mark.
I think people are starting to hear about GTL oils. I did see the SHU 5w-30 advertised recently and I haven't seen it before, will be good for the wife's next car.
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334399 01/28/20 06:33 AM
M
Mad_Hatter Offline
M
Interesting read about Shell Helix. Reads similar to some other Shell products, like Pennzoil.
https://www.shell.com.pk/motorists/...works/clean-and-protect-your-engine.html
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334421 01/28/20 07:08 AM
A
adams355 Offline
A
Yea that's not about the ultra formula which is GTL. That's about the 'active cleansing agents' formula that was and is still found on their standard oils. On the Ultra bottles it now says pure plus technology.
https://www.shell.com.au/motorists/...ZnJhbWVkYXBwX2FlN2Muc3RhdGljLzM2MC5odG1s
https://www.shell.com.au/motorists/oils-lubricants/helix-for-cars/pureplus.html
Re: Shell Helix Ultra 5W-30 [Re: adams355] #5334427 01/28/20 07:23 AM
M
Mad_Hatter Offline
M
Shell's "active cleaners" has nothing to do with the base oil type, in this case GTL aka "PurePlus". And Shell includes it's "active cleaners", whatever they are, in ALL Shell Helix formulas including their Ultra line. See link below..
https://www.shell.com/motorist/oils-lubricants/helix-for-cars/pureplus.html
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334460 01/28/20 08:04 AM
A
adams355 Offline
A
Yes i'm sure they still have an additive/active cleansing package etc in the GTL. I wasn't implying that they didn't just that the GTL is only available in the Ultra . Also, the Ultra bottles have replaced the graphics on the front picture to PurePlus technology instead of the 'active cleansing technology' graphic found on all shell oils except for the Ultra.
Re: Shell Helix Ultra 5W-30 [Re: adams355] #5334532 01/28/20 09:54 AM
M
Mad_Hatter Offline
M
Ah yes, i see..but how do we know Shell isn't using GTL in some portion in their other fully synthetic Helix products, much like they do in Rotela Gas Truck? IIRC, Gena Fishbeck stated Shell uses some GTL in it's RGT along with "other" synthetics. She didn't go so far as to say in what %. Either way Helix Ultra w/GTL looks like a solid lube. Wonder how much different it is than Pennzoil Ultra Platinum??🤔
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334647 01/28/20 12:21 PM
sloinker Offline
What % GTL is in any of them? We may be thinking 100% but Pennzoil is actually selling us 5% and laughng all the way to the bank?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Shell Helix Ultra 5W-30 [Re: SR5] #5334648 01/28/20 12:24 PM
E
edyvw Offline
E
I just got Pennzoil Platinum Euro 5W40 for my BMW and it is SN+. Not that I really care, but it is.
Re: Shell Helix Ultra 5W-30 [Re: edyvw] #5334686 01/28/20 01:06 PM
G
George Bynum Offline
G
I understand it not mattering for you; it is interesting that Pennzoil's website says "Euro*, *API SN PLUS specification not applicable
I guess the website (https://www.pennzoil.com/en_us/products/full-synthetic-motor-oils/pennzoil-platinum-euro.html) is behind the product and label.
They are better than most, however.
