$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
103 registered members (ABomb369, alchargo, 104Guy, 28oz, 1WildPig, ABerns, 8 invisible), 2,178 guests, and 17 spiders.
Topics301,695
Posts5,200,786
Members70,758
Page 1 of 3 1 2 3
Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T #5334108 01/27/20 07:11 PM
chinee Offline OP
2017 Civic with 24,000 on the odometer, OCI 4,786 miles over 5 months.
Oil capacity is 3.7 qts, which is exactly the amount drained, that plus a small amount in the filter and sent to sample, makes for a very small increase in oil level (due to fuel dilution).
This fill was a Pennzoil Platinum mix, 2.5 qts of 5W30 and 1.25 qts of 0W20, an attempt to use a slightly "thicker" oil to compensate for the anticipated fuel dilution.
Replaced with PP 0W20, didn't try a mix this time, will run another 5K or so.
[Linked Image]
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334156 01/27/20 08:12 PM
R
rubberchicken Offline
R
Since your in Florida, why not run 100% 5w30 ? Or a 0w30. I would feel perfectly fine with a 5w30.
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334164 01/27/20 08:18 PM
O
oldhp Offline
O
100% 5W30 if it was my car waaaay down there in da heat zone.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334177 01/27/20 08:29 PM
R
Rand Offline
R
fyi blackstone routinely under-reports fuel dilution because its an indirect?? measurement not a something they distinctly measure.
I wouldnt be surprised if it was closer to 5%
A friend with a CRV 1.5T watches his oil level visibly rise in the winter.
NE OHIO is not exactly MN or BC either.
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334188 01/27/20 08:35 PM
Marco620 Offline
Thanks for posting. As I get ready for new car I think I will run 0w30. Report looks okay, flash point getting a wee bit low.
15' Civic 1.8 i-vtec 310,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334194 01/27/20 08:38 PM
P
parshisa Offline
P
With that low of a flashpoint FD is well over 5%. Ok report though, still breaking in engine
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334195 01/27/20 08:38 PM
chinee Offline OP
The recommended oil is 0W20. The first change I did with 5W30 was a knee-jerk reaction after reading about the fuel dilution issues with this engine, thinking a heavier oil would compensate for the fuel dilution (I think I read that somewhere).
With the 2nd oil change, I took the 5W30 I had left over and simply mixed it with the recommended 0W20, just to see what the results would be.... nothing to write home about right?
The current fill is PP 0W20, the recommended oil... let's see how that does. Depending upon the intensity of the fuel odor and the amount of oil in the engine at the next drain, I will then decide whether to stay with 0W20 or go to 5W30 on the next fill.
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334211 01/27/20 08:46 PM
G
gregk24 Offline
G
I can't believe they went with a 3.7 quart sump. That seems very small for all that is required of that engine. Our 1.8 TSI Jetta takes 5.7 quarts.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334395 01/28/20 06:25 AM
M
Matagonka Offline
M
I bet fuel dilution is higher than they're saying. Look at your viscosity, you're losing it.
2018 Mazda 3 Touring HB 2.5
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: gregk24] #5334483 01/28/20 08:42 AM
A
ARCOgraphite Offline
A
My 1.4T VW is 4L
Oil temp on the DIC is well below boiling most of the time. I have to wail on the boost to get it above 210F.
Hopefully you can get to a 6K or so OCI.
Is this triggered by an OLM?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334616 01/28/20 11:39 AM
A
ad244 Offline
A
Wow, Low flash point
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: Rand] #5334780 01/28/20 03:36 PM
chinee Offline OP
You know, I saw these numbers and thought “This can’t be good...”
I wouldn’t be surprised if it was closer to 5%.
I also wasn’t aware that Blackstone’s measurement of fuel dilution might be under-reported... Maybe you can recommend another lab?
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334803 01/28/20 04:25 PM
P
parshisa Offline
P
Oil Analyzers. cheaper and uses GC to measure fuel dilution (no extra charge for TBN)
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: chinee] #5334822 01/28/20 04:53 PM
wemay Offline
I can't recall ever seeing a 0W-20 UOA with significant viscosity loss. Your choice of going with the recommended viscosity was a good one imo.
2019 VW Passat Wolfsburg TSI
VW High Performance Genuine Engine Oil 0W-20
OEM
2013 Hyundai Santa Fe Sport 2.0T
Shell Rotella Gas Truck 5W-30
OEM
Re: Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T [Re: parshisa] #5334913 01/28/20 07:18 PM
I
IndyFan Offline
I
Cheaper? Only if you get TBN from Blackstone. $33.90 for Oil Analyzers vs. $28 for Blackstone, without TBN. I don't run long enough OCI's to worry about TBN.
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Page 1 of 3 1 2 3
