Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
Tgarst, Predator35001819, Markapuu, jds59, JimMorrison
70728 Registered Users
131 registered members (92saturnsl2, advocate, Aero540T, ABerns, 2010Civic, 11 invisible), 2,103 guests, and 29 spiders.
Topics301,588
Posts5,198,635
Members70,728
Burning smell from rear wheel #5334027 01/27/20 06:01 PM
2
2010Civic Online Content OP
OP Online Content
2
I have a burning like smell coming from the right rear wheel on my 2005 Honda Accord. It's a LX so it has rear drum brakes. It's a faint smell and probably wouldn't be noticable to the average person. The left rear doesn't smell.
The car has 194k miles and I am pretty sure the drums and shoes are original. I pulled the drum off and everything looked good as far as I could tell. The shoes don't have a lot of material left but there is enough. The drums look decent.
I jacked up the rear of the car and spun both rear wheels. They both spin with minimal resistance and feel the same. The brakes don't make any noise and the wheel/lug nuts aren't warm after a 25+ mile drive.
Any ideas what could be causing it?
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Burning smell from rear wheel [Re: 2010Civic] #5334033 01/27/20 06:08 PM
A
atikovi Online Content
Online Content
A
You're in the rust belt? Brake fluid or gas leaking from rusty lines on to the exhaust.
Re: Burning smell from rear wheel [Re: 2010Civic] #5334034 01/27/20 06:09 PM
R
Rand Offline
R
Maybe its intermittently sticking? I'd probably have it apart for an inspection.. if its in good shape you might be looking at the wrong culprit.
Then again with 15 year old brakes you can sometimes have strange issues such as hoses, leaking wheel cylinders, etc.
Re: Burning smell from rear wheel [Re: 2010Civic] #5334037 01/27/20 06:14 PM
supton Offline
What is the smell? Hot brake, hot metal or hot rubber? My car has an intermittent hot (almost burning) rubber smell, and I assume it's just a hot exhaust hanger or the like.
Now a hot brake, that'd be an indication of problems.
2011 Toyota Camry, base, 2.5L/6MT, 201k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Burning smell from rear wheel [Re: 2010Civic] #5334053 01/27/20 06:27 PM
2
OP Online Content
2
I'd say it smells like hot rubber or brakes? Hard to tell.
2010 Honda Civic LX
59,992 miles
Re: Burning smell from rear wheel [Re: 2010Civic] #5334075 01/27/20 06:43 PM
T
tcp71 Offline
T
Sticky parking brake? Cable partially seized?
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Burning smell from rear wheel [Re: 2010Civic] #5334114 01/27/20 07:19 PM
V
vwmaniaman Offline
V
Touch your rear wheels after a drive and see if it is warmer on one side than the other. Gas mileage lower than normal?
Don't waste your time on a slipshod repair.
Re: Burning smell from rear wheel [Re: vwmaniaman] #5334145 01/27/20 07:53 PM
I
Imp4 Online Content
Online Content
I
Agreed.
If one wheel rim is warmer than the other, likely a stuck or seizing parking brake mechanism or wonky wheel cylinder.
Take it apart and service the brakes.
Check and adjust for proper functionality.
Visually inspect exhaust system for a plastic bag or tarp type material that was run over and now melted to the exhaust pipe or muffler. Maybe bound up between heat shield and exhaust pipe???
Or a chunk of underbody rustproofing that came loose and is wedged to the exhaust???
Look around and you'll likely find something....
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Burning smell from rear wheel [Re: 2010Civic] #5334281 01/27/20 10:11 PM
2
OP Online Content
2
A few weeks ago I jacked it up and removed the wheel after a drive and the smell quickly went away. Couldn't tell where it came from. Nothing was hot. Maybe there is some plastic burning on the exhaust? It is on that side.
2010 Honda Civic LX
59,992 miles
Re: Burning smell from rear wheel [Re: 2010Civic] #5334409 01/28/20 06:47 AM
supton Offline
I'd keep poking around, but I'm telling you, I've had that come and go for a few years and on more than one vehicle.
Re: Burning smell from rear wheel [Re: 2010Civic] #5334504 01/28/20 09:13 AM
gathermewool Offline
Dumb questions:
How old are the tires?
Properly inflated? 2010 has TPMS, so that should let you know when any tires is ~ 27#.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Burning smell from rear wheel [Re: gathermewool] #5334559 01/28/20 10:25 AM
2
OP Online Content
2
From 2017. Yes they are properly inflated. It's a 2005 accord so no tpms.
2010 Honda Civic LX
59,992 miles
Re: Burning smell from rear wheel [Re: 2010Civic] #5334568 01/28/20 10:33 AM
SLO_Town Offline
One time I ran over a plastic bag and it stuck to the exhaust. It smelled like something was hot. Even though only plastic residue remained on the exhaust, it smelled for several weeks afterward.
FWIW,
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Burning smell from rear wheel [Re: 2010Civic] #5334754 01/28/20 02:49 PM
H
hallstevenson Online Content
Online Content
H
Burning rubber has a pretty distinctive smell. I don't think you'd confuse it with the smell that comes off of brakes.
