What sort of ATF and is Merc V synthetic?
by Stinky123 - 02/20/20 12:37 PM
Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
103 registered members (1978elcamino, 77GrandPrix, 928, 69GTX, 330indy, 12 invisible), 1,996 guests, and 16 spiders.
Topics301,700
Posts5,200,917
Members70,759
Autozone Clearance 85w140 gear oil 5 gal #5333936 01/27/20 04:31 PM
G
GON Offline OP
G
Autozone
STP Five Gallon 85w140 gear oil, $20.
90 plus dollars at many retailers.
Bought one, guess hoarder mentality. I tow a lot with a 2002 and 2006 F350, but I know synthetic recommended for gear oil if towing.
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: GON] #5333951 01/27/20 04:50 PM
Donald Offline
A diff takes a couple of quarts. And its STP. No thanks.
2015 Ford F-250 w/Powerstroke
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: Donald] #5333960 01/27/20 05:01 PM
Chris142 Online Content
Online Content
Whats wrong with the STP brand? It's made by Warren and is the same as ST.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: GON] #5334001 01/27/20 05:36 PM
I
Imp4 Online Content
Online Content
I
Is it possible to use 5 gallons of this if you don't run a shop?
A great price on something you don't need is not a bargain.
How long will it take you to go through this stuff?
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: Imp4] #5334012 01/27/20 05:46 PM
G
GON Offline OP
G
Not sure how or where I will use it. I have a 2002 F350 4x4, and a 2006 F350 RWD. If, and that is a if, this is a good fit, I imagine both vehicles would need 1-2 gallons total.Maybe I will find other uses. At $20, worth the risk. My garage is full of unused deals. But when they work, they often work real well. Time will tell.
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: GON] #5334043 01/27/20 06:19 PM
6
69Torino Offline
6
Chainsaw bar oil at $1 per quart lol
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2000 Nissan Xterra
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: 69Torino] #5334099 01/27/20 07:02 PM
T
tundraotto Online Content
Online Content
T
My thoughts exactly!
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: tundraotto] #5334104 01/27/20 07:08 PM
simple_gifts Offline
If you use it for cutting wood, you'll just end up smelling like a rear end by the end of the day....
I'll pass as B+C oil
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: GON] #5334235 01/27/20 09:09 PM
D60 Offline
A buddy of mine bought me a bucket and a pump...took me about 10 years to use it all, but so nice to just hook the filler tube in the fill hole and pump it fill
Ignore the haters, it's a good deal and useful. Add a basic hand pump that inserts in the lid for extra awesome points
Re: Autozone Clearance 85w140 gear oil 5 gal [Re: D60] #5334280 01/27/20 10:11 PM
c502cid Offline
^^^^This^^^^. I've been working off the same 5 gallon bucket of gear oil for years (with hand pump) and just having it, even better with the easy to fill a diff pump, is great. $20?! Great deal!
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
