drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
112 registered members (atikovi, 53' Stude, apollo18, 2013ecof150, AandPDan, antone, 11 invisible), 2,424 guests, and 19 spiders.
Topics301,750
Posts5,202,081
Members70,766
Resonating Noise at 3000rpm #5333931 01/27/20 04:28 PM
T
tookien Offline OP
T
I have a reciprocating/resonating wavy bass sort of noise at 3000rpm and above. rav4 2003 2.0L.
No vibrations, no ticking noise. The noise isn't that loud, but consistent.
Checked engine mounts all good.
Checked for any loose heat shields all good.
Right when I let go of the gas it goes away, even at 2900rpm.
It sounds related to intake or exhaust.
Re: Noise at 3000rpm [Re: tookien] #5333934 01/27/20 04:31 PM
gathermewool Offline
Irrespective of vehicle speed?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Noise at 3000rpm [Re: gathermewool] #5333937 01/27/20 04:33 PM
T
tookien Offline OP
T
Yes.
Re: Noise at 3000rpm [Re: tookien] #5333939 01/27/20 04:35 PM
02SE Offline
I'd check the entire exhaust system routing. I'd place strong odds on the exhaust system having rotted out somewhere along it's length, and the pipe is now resting against something and resonating.
Re: Noise at 3000rpm [Re: gathermewool] #5333940 01/27/20 04:36 PM
T
tookien Offline OP
T
While holding the throttle open at 3000 rpm or above, it starts.
I let go of the gas/throttle a little and it stops.
Re: Noise at 3000rpm [Re: 02SE] #5333944 01/27/20 04:37 PM
T
tookien Offline OP
T
Thanks, good idea.
Re: Noise at 3000rpm [Re: tookien] #5333955 01/27/20 04:56 PM
P
PontiacHO Offline
P
A baffle in a muffler can be loose as well as the inner guts of a cat converter. Idler/ belt tensioner may be worn (accessory or timing belt). Loosen/remove accessory belt and bring it up to the RPM that the vibration is happening. Some vehicles are engineered such that the torque converter can be separated from the flex plate so that can be eliminated as a source for the vibration. Sometimes vibrations are tough to isolate....
Re: Noise at 3000rpm [Re: tookien] #5333962 01/27/20 05:02 PM
O
Olas Offline
O
your description first made me think exhaust drone - second place I went to was a wheel bearing noise. does it make the noise in every gear?
Cable ties should hold it
Re: Noise at 3000rpm [Re: PontiacHO] #5333964 01/27/20 05:06 PM
T
tookien Offline OP
T
Thanks, good idea.
Good idea with the belt/tensioner pulley.
The vehicle does make a squeaking noise when started up but eventually goes away.
I traced the squeaking to the belt/tensioner pulley, which I will come around to replacing.
But I don't really know if this noise is related.
Re: Noise at 3000rpm [Re: Olas] #5333966 01/27/20 05:07 PM
T
tookien Offline OP
T
Definitely not wheel bearing noise. I did replace the front wheel bearings.
This noise was pretty much there since I bought the vehicle.
Re: Noise at 3000rpm [Re: Olas] #5333968 01/27/20 05:10 PM
T
tookien Offline OP
T
Drone noise from exhaust could be it.
Re: Noise at 3000rpm [Re: tookien] #5333969 01/27/20 05:11 PM
T
tookien Offline OP
T
Thanks for all the ideas, I will look into them
I don't know why but the noise kind of sounds like it's coming from around the throttle body area, but I checked and don't see anything wrong there. No vacuum leaks or anything.
Re: Noise at 3000rpm [Re: tookien] #5333972 01/27/20 05:13 PM
P
PontiacHO Offline
P
Is this noise, drone, or vibration detectable at the RPM noted while sitting still or does the car have to be moving? Does it have an electric cooling fan or mechanical fan (fan clutch)??
Re: Noise at 3000rpm [Re: tookien] #5334100 01/27/20 07:04 PM
T
tundraotto Online Content
Online Content
T
loose internal exhaust baffle or loose exhaust heatshield is what I'd look for first.
Re: Noise at 3000rpm [Re: tookien] #5334260 01/27/20 09:30 PM
Nick1994 Offline
Ever touch the CV axles? I had a VW that after putting on an aftermarket axle, it vibrated at 2k RPMs regardless of speed.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
