Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
99 registered members (aquariuscsm, 01VFR, ABerns, alex_at, AlaskaMike, bbhero, 7 invisible), 2,508 guests, and 19 spiders.
Topics301,912
Posts5,205,224
Members70,800
2008 Highlander Battery Post Bolt Snapped #5333829 01/27/20 02:31 PM
M
maverickfhs Offline OP
M
As the title suggests, had a friend and they were doing a battery change and one of the 10mm bolt to hold battery in place head snapped.
Without drilling, is there any other work around to extract and replace with a new on? Thank you thumbsup
[Linked Image from i.postimg.cc]
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333835 01/27/20 02:38 PM
Donald Offline
The proper way is to drill it out. Preferably with left hand drills and a good soaking with PB Blaster or similar. Some will weld a nut on what is broken and get it out that way.
Part of that bolt is probably rusted or corroded.
You do not want the battery bouncing around where its two posts could contact the hood for example.
If there is a nut down there that is spot welded in place you could grind the spot welds and then use a new nut held with a wrench to tighten.
2015 Ford F-250 w/Powerstroke
Re: 2008 Highlander Battery Post Bolt Snapped [Re: Donald] #5333836 01/27/20 02:40 PM
M
M
Thank you, yes there's a small nut spot welded there.
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333875 01/27/20 03:20 PM
Yah-Tah-Hey Offline
The torque on those is about 70 in lbs so they are easy to break.
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333888 01/27/20 03:31 PM
J
JustinH Offline
J
I would simply drill it out then put a different bolt in there, and spin a nut on the back of it.
Should be secure.
'16 Ford Escape
'11 Scion XB
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333894 01/27/20 03:45 PM
B
Black_Thunder Offline
B
since it has a nut spotweld on etc. they usually aren't too hard to knock loose with a hammer chisel.
once you get it out you could run a carriage bolt through the bottom and nut it on top which might make it easier to tighten back up.
I'd buy Callahan autoparts if I could.
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333897 01/27/20 03:48 PM
K
kschachn Online Content
Online Content
K
If any of the old bolt is visible on the other side of the welded nut and if you can get to it, generally the broken piece of bold will unwind from that side.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: 2008 Highlander Battery Post Bolt Snapped [Re: kschachn] #5333901 01/27/20 03:50 PM
M
M
Yes we could tighten up a nut from the other/downward visible side, question is should we be tightening up that nut and eventually the remainder of the broken bolt would come out?
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5333949 01/27/20 04:47 PM
L
LeakySeals Offline
L
Can you get the battery out of the way so you can bite whats left and pull it out from the back?
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: 2008 Highlander Battery Post Bolt Snapped [Re: kschachn] #5333996 01/27/20 05:33 PM
E
eljefino Offline
E
If it's part of a battery tray it's probably seen acid and corroded. The suggestion to just drill through everything and put another nut & bolt holds water.
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5334045 01/27/20 06:21 PM
B
bullwinkle Offline
B
Last time this happened I just drilled & tapped the hole, stuck a spare bolt in there (with lots of antiseize on it).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5334123 01/27/20 07:29 PM
K
Online Content
K
What I meant was that a lot of the times the reason a bolt snaps off is because the protruding threads on the other side of the nut are rusted. When you try and unscrew the bolt the rusty threads hang up and the rest of the rusty bolt snaps off. So if the remaining bolt piece is still protruding from the back side, generally you can unscrew it from there and back it out of the nut.
You don't need to add another nut or tighten up anything, just unscrew the broken off bolt from the other side. All of which assumes you're able to grab it however.
1994 BMW 530i, 252K
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5334134 01/27/20 07:40 PM
Z
zzyzzx Offline
Z
Thread title suggests that the broken bolt is on top of the battery.
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5334230 01/27/20 09:05 PM
M
mehullica Offline
M
The bolt goes through a thin tab on the radiator support. Might be enough room underneath to grab with some visegrips & turn it out
Re: 2008 Highlander Battery Post Bolt Snapped [Re: maverickfhs] #5334234 01/27/20 09:07 PM
R
Rand Offline
R
A picture is worth a 1000 words.
[Linked Image from parts.toyota.com]
