Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
109 registered members (ammolab, 1978elcamino, alex_at, Aichiguy, 28oz, 01VFR, 8 invisible), 2,397 guests, and 20 spiders.
Topics301,905
Posts5,205,137
Members70,798
conventional wisdom rebuild axle or replace? #5333763 01/27/20 01:22 PM
N
NissanMaxima Offline OP
N
Hi all,
The outer CV boot on my 95 Maxima has developed a crack and is slinging grease in the wheel well. I had hoped the Nissan OEM axle complete with boots etc. would still be available but alas it has been discontinued. My options are a Nissan Value Advantage axle or have the shop just replace the boots by cleaning out as much of the grease as possible and installing new Nissan boots (outer and inner) with the supplied Nissan grease. Does anyone have experience with Nissan Value Advantage parts? My impression has always been they are an inferior choice compare to OEM parts and not to be used for warranty work. Some google searches seem to indicate they are coming from China. Since the car only has about 77k miles on it, has been well kept and was caught early, I'm inclined to have the shop rebuild what I think is probably a superior axle and CV joints with new boots and ask them take a look at the CV joints while it is opened up.
https://partsadvantage.nissanusa.co...manufactured-Parts-Application-Guide.pdf (see pages 2 and 20 for those that are interested).
1995 Nissan Maxima SE 5 speed
2015 Toyota Corolla S+
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333780 01/27/20 01:38 PM
supton Offline
If caught early, just reboot. If it's not clicking then I'd assume all will be well when opened up--there's always a chance that it's got bad wear, but IMO it's unlikely.
Is this something that you are planning to swap? If so, then you can reboot. It's not hard, assuming that Nissan didn't do anything odd here. But it's messy as all get out...
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333797 01/27/20 01:54 PM
W
Wolf359 Online Content
Online Content
W
Depends on the price difference. On Ford axles, I'd just swap them out as they were so cheap and there were no issues with aftermarket ones. On my Mercedes, the aftermarket ones were junk, caused a vibration. The OEM ones were 1000+ and even the name brand aftermarkets were over $300 so it was just easier/cheaper to reboot the old axle with a $40 OEM kit.
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333806 01/27/20 02:03 PM
K
KGMtech Offline
K
New boots on the old axles, and go forward in peace. The risk of dirt inside the torn boots is overblown, unless you regularly drive in dirt roads, gravel roads, and you've caught it early.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: conventional wisdom rebuild axle or replace? [Re: KGMtech] #5333810 01/27/20 02:06 PM
supton Offline
I bought a (well) used ATV a couple months ago, and missed that it had blown CV boots. The grease had turned yellow. Oops. But after tearing it apart, the joints were fine (low mile machine used around someone's house).
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333814 01/27/20 02:08 PM
D1dad Offline
I’ve use the value advantage brake pads and they’re as good as anything else. Doe AA or AZ not have new cv shafts for a 95? I replaced the cv shafts on my wife’s 07 Murano with aftermarket and they lasted longer than the ones from the factory.
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333816 01/27/20 02:09 PM
O
Onetor Offline
O
OEM or cvjremancvjreman
N = R* x fp x ne x fl x fi x fc x L
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333819 01/27/20 02:17 PM
N
nthach Online Content
Online Content
N
The Nissan Value Advantage axles look like a Chinese-made part. I'd try rebooting the OEM ones first, if they aren't clicking or making other noises.
I've seen The Critic go through a few Cardone-reman or Chinese axles on a Rogue or Murano before he found one that worked. I'd certainly trust a Chinese axle over a Cardone reman, just because the case hardening of the joints wasn't destroyed by a regrinding of the joint races.
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333831 01/27/20 02:34 PM
N
N
Thanks all. I knew I would forget something!...I'm going to have the dealer take this one off my hands this time. The cost for reusing the axle/CV joints and just installing new boots/grease/clamps is actually about $70 more than the new Value Advantage assembly but I just can't get past thinking that OEM axle once rebuilt is still going to be better than the Value Advantage assembly and for what it's worth, the technician the Nissan service advisor spoke to agreed although the parts guy said he has no problem with Value Advantage parts but couldn't say where they were coming from or who was building them. (And I don't Service was basing their input on collecting more money since as some mentioned, it is a messy job rebuilding one).
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333841 01/27/20 02:51 PM
L
LeakySeals Offline
L
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333849 01/27/20 02:58 PM
Donald Offline
Try with a reboot. If it does not work out you have not lost that much in trying and can get a new or reman axle.
2015 Ford F-250 w/Powerstroke
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333861 01/27/20 03:04 PM
slacktide_bitog Offline
Since you're in Colorado, I heard good things about CVJ reman. See if you can get thermoplastic boots installed.
Most aftermarket and reman axles use neoprene boots, which are inferior. Torn boots are virtually the only reason for CV failure. Raxles doesn't do axles for the 4th gen Maxima anymore.
If the Nissan Value Advantage axles use thermoplastic boots like real OE axles, get those. If they use neoprene like aftermarket axles, then use CVJ
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5333959 01/27/20 05:00 PM
O
Olas Offline
O
Sometimes you just have to go with whatever is quickest/easiest/cheapest or sometimes you have to do whatever it takes to have the car ready for work at 05:30 tomorrow, but it seems crazy to me that people would throw away two perfectly good CV joints and an OEM driveshaft just to replace one boot. Over here it is much more common to replace the individual component if the other stuff is still good, so please allow me to ask a genuine question with no snarkiness or rhetoric, just curiosity;
I'm interested to know what causes the different approoaches to the same problem so I wonder if there is a particular reason, such as cost or parts availability or something, that makes the solution of 'a new axle' seem common in NA?
Re: conventional wisdom rebuild axle or replace? [Re: Olas] #5334064 01/27/20 06:37 PM
W
Online Content
W
On a Ford Taurus you can pick up an axle for under $50. Not worth it to replace the boots at that price. Pop the old one out and then put in the new one. It's harder to take out the old one and take it all apart to replace the boot, you've got to pay for labor on top of the charge for the boot and also hope that the old axle is fine. If it was making noise, probably not.
Re: conventional wisdom rebuild axle or replace? [Re: NissanMaxima] #5334107 01/27/20 07:10 PM
T
tiger862 Offline
T
On my niece's Kia the axle came apart when ball joint snapped so I thought no problem get a new one. The axle wasn't available and no boot available so I went with universal boot, cleaned and greased as well as prayed. Only problem is ABS light is on which I will look at after I get it running. (After axle replacement her sister took car and destroyed it.) Axle makes no noise. If boot is torn just replace boot.
Tiger862
2018 Grand Caravan
