Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
76 registered members (brages, 4WD, Astro_Guy, 2002 Maxima SE, Bailes1992, 8 invisible), 1,483 guests, and 20 spiders.
Topics301,732
Posts5,201,619
Members70,766
will a thermostat gasket leak coolant into the engine? #5333736 01/27/20 12:55 PM
M
motor_oil_madman Offline OP
M
I just had a new 5.7 MPI marine engine installed in my boat. I got 12hrs on it now and noticed that the 2 bolt flange gasket where it mounts to the engine is leaking just a tad on one side. Looks like the gasket blew out or got damaged some how. It doesn't leak when running, but I do notice a very small puddle of coolant that must be seeping out. It's very small the size of my pinky nail. lol The thermostat is on the very very front of the engine unlike my older 350 where it was 4'' back close to the carburetor. I wonder if it's separate on the new engine? it's just on a flat portion of the intake, if that's still the intake.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333739 01/27/20 12:56 PM
M
M
Is that portion of the coolant separate from the intake or am I leaking coolant into the lifter valley? This engine has roller lifters btw.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333779 01/27/20 01:37 PM
Chris142 Offline
No it won't leak into the engine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: will a thermostat gasket leak coolant into the engine? [Re: Chris142] #5333795 01/27/20 01:53 PM
M
M
How come? Does that only happen when the intake manifold gasket itself leaks?
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333803 01/27/20 02:01 PM
Spktyr Offline
Pretty much, yes.
Intake manifold gaskets seal intake air and coolant (and sometimes oil) passages from each other and the outside, so when they fail, everything can mix. Thermostat housings only seal a coolant passage. Nobody routes intake air or oil through a thermostat housing, so no, a blown thermostat gasket will not itself let coolant go into internal engine passages where it isn't supposed to or allow coolant to mix with other fluids.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333848 01/27/20 02:56 PM
Donald Offline
Did they reuse the intake manifold? Thermostat housing cover?
You need to take it apart and see if either surface is corroded. New gasket and a tiny tiny amount of Permatex Ultra (black).
If this is raw water cooled you are only leaking some water from river or lake. If you are in the ocean and raw water cooled I would not want salt water leaking on my new engine.
2015 Ford F-250 w/Powerstroke
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333863 01/27/20 03:06 PM
M
M
No it was a complete drop in motor. It's closed cooling also. (Anti freeze)
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333906 01/27/20 03:54 PM
P
PandaBear Offline
P
Not sure about that specific engine but every single thermostat I see is between the coolant passage and the outside, not between oil and coolant. I'd be pretty [censored] if a leaking gasket other than head gasket will mix between oil and coolant (that includes intake manifold gasket).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333943 01/27/20 04:36 PM
Donald Offline
You will still need to take apart the cover on the thermostat housing and check both surfaces. Check for corrosion and flatness.
You could ask the engine supplier to provide new thermostat housing and cover. I have a similar but older version of that engine in my boat. I have taken apart the thermostat housing but cannot remember exactly how it looks.
You want to get this fixed so you do not get low on coolant.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5333997 01/27/20 05:35 PM
E
eljefino Offline
E
Yeah, why is this your problem? Go get it warrantied.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5334110 01/27/20 07:15 PM
T
tiger862 Offline
T
Put tablet in radiator that GM recommends. 8.00 on Amazon.
Tiger862
2018 Grand Caravan
Re: will a thermostat gasket leak coolant into the engine? [Re: tiger862] #5334309 01/27/20 11:12 PM
M
M
An engine shouldn't need any kind of stop leak. Fix it right and move on with life.
Re: will a thermostat gasket leak coolant into the engine? [Re: eljefino] #5334310 01/27/20 11:14 PM
M
M
Because I want to use it while the weather is nice. This boat has been in the shop most of the time I've owned it due to people taking 4 times as long as they told me it would take.
Re: will a thermostat gasket leak coolant into the engine? [Re: motor_oil_madman] #5337176 01/31/20 09:31 AM
W
WyrTwister Offline
W
If you had any coolant in the oil , the appearance of the oil would visually change , as it got worse .
Excuse me , did you say you had checked the fasteners that attach the tstat housing ?
Wyr
God bless
Re: will a thermostat gasket leak coolant into the engine? [Re: WyrTwister] #5337203 01/31/20 10:10 AM
M
M
I didn't check. You can see the gasket is damaged, that's why it's leaking.
