I have a nighthawk m1 hotspot that I would like to get connected to a netgear ac2100 wireless router. So far I've had it working twice when I can get it to connect, the issue seems to be with the m1. The m1 is setup with ip passthrough enabled, dhcp turned off, and Ethernet standby disabled. The ac2100 is standard setup with ip changed to 192.168.2.1 not to conflict with the 192.168.1.1 on the m1. Tried to setup dmz but didn't have enough time to make sure that was correct. When the router is connected my signal goes from 2-3 bars of cell signal to steady 4 bars and speeds increase 20-30 mbps. Also the hotspot wifi range isn't the best even with long range enabled, so the other reason for wanting to get this setup. Seems like the nighthawk is picky on what it will connect to for a additional router setup. I basically want the m1 to function as a stand alone modem with the router providing everything else. Anybody have any experience with getting the m1 to connect to a router reliably? Or any suggestions on trying another router that is known to work? Any help is appreciated.
