Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
101 registered members (A310, 69GTX, 55hambone, ArrestMeRedZ, ammolab, 11 invisible), 1,791 guests, and 18 spiders.
Topics302,060
Posts5,208,292
Members70,826
Alignment questions: is camber/caster not usually touched? #5333275 01/26/20 10:47 PM
F
FordBroncoVWJeta Offline OP
F
Little brother put the 03 Taurus in the ditch in the morning ice. Didn't do any damage besides pop the front driver tire bead. No tire damage. Took it into Goodyear for an alignment. Now the steering wheel is centered in the 11 o'clock position going down the road (wasn't like that before hand). And all they adjusted was toe. Did they not adjust anything else?
I'm planning on going back and at least getting the steering wheel fixed.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333279 01/26/20 10:49 PM
F
F
[Linked Image]
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333280 01/26/20 10:53 PM
ctechbob Offline
Depending on the car, Camber and Caster may not be adjustable from the factory without different parts.
You'd have thought that they would have at least checked the steering wheel for being straight though. That's amateur hour there.
The right side of that car has more camber than I would expect from a family hauler both front and rear, but that might be normal depending on the car.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333338 01/27/20 05:32 AM
D1dad Offline
Nissan put a new cvt in my car and when I got it back the steering wheel was at 10 o clock and I had just put new Dunlop’s and had an alignment. I took it back obviously upset and they fixed it. Camber on most cars is usually not able to be adjusted on most cars but I’ve never had an issue when it was a tad off. Volkswagen van and my impala come to mind while I both had over 100k and no abnormal tire wear or or noises.
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333339 01/27/20 05:42 AM
E
ET16 Offline
E
If I remember correctly, there is a kit for adjusting camber on the Taurus.
Re: Alignment questions: is camber/caster not usually touched? [Re: D1dad] #5333340 01/27/20 05:43 AM
M
mattd Offline
M
Camber isn’t adjustable on that car in the front. It requires drilling out the holes for the strut mount IIRC. There still isn’t much room for adjustment even then. With those readings I’m surprised it’s not pulling left. Something may be bent on the RF.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333399 01/27/20 07:25 AM
A
atikovi Offline
A
Well, unless the alignment tech is incompetent, something must have been bent if the wheel is so far off. It's takes a pretty hard hit to pop off a tire bead. Sure you're getting the full story from bro?
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333409 01/27/20 07:43 AM
A
ARCOgraphite Offline
A
Tech may not have had wheel centered when he set toe.
but
things to check
1- The strut top bearing race on impact side may have come apart - a lot of people don't even know they exist.
2- the steering coupling/ rag joint may have failed or is worn. IIRC Taurus have a handshake finger joint under the dash to decouple the steering shaft there in case of a hard LF hit. With the car OFF, if you can move the steering wheel 10 degrees very easy, its shot..
3- Going off road in a ditch shouldnt have caused a negative camber on the pass , side if that's what went in first.
one degree negative is not terrible by any calculation and is good for crown correction for the average driver in the U.S.
check the stuff above and if good, back to the shop.
ps: the rear toe could use a touch up if easy.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333424 01/27/20 07:57 AM
Chris142 Online Content
Online Content
If he hit something so hard that it took the tire off the rim it's likely that something is damaged. The 1.9* negative camber on the passenger side says something is bent. That negative camber will be easy to see and will wear that tire.
I don' t think caster is adjustable on this car.
If he is like my customer and has no real understanding of front ends he likely told them to just align it as best as they can without replacing parts.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333431 01/27/20 08:05 AM
A
A
You bend a LCA its going POSITIVE on the camber and the caster should be wonky there too.
But accident could have popped a LCA thrust poly bushing and its moving around.
Then the strut top steering ball race like I mentioned.
sound like it went over a short curb at least.
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333472 01/27/20 08:53 AM
P
Pew Offline
P
They didn't touch your rear toe at all. I bet the tech looked at the total rear toe, saw it was in the green, and left it at that and that's how you're getting your 11 o'clock steering wheel.
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333549 01/27/20 10:24 AM
gathermewool Online Content
Online Content
That front right camber is really high.
The past few Subarus I've had, the front camber was able to be adjusted by up to 1* of camber.
-----I had -1* camber on my previous STI (maxed out), -0.7* camber on my current Legacy (maxed out), and zero camber on her FXT.
-----I don't recall where I read it way back when, but it was recommended not to exceed -1* of camber or so for a DD to minimize inside tire wear (that, and most of us normal drivers won't make up that extra degree of camber when cornering at anything less than auto-X speeds.)
The rear camber is NOT adjustable and was as negative as yours is, if not closer to -2* - par for the course for Subaru.
Caster has not been adjustable on any car I've owned, as far as I know.
Aftermarket parts are required for caster and rear camber adjustment on my Subarus, or for more aggressive negative camber in the front.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Alignment questions: is camber/caster not usually touched? [Re: Pew] #5333665 01/27/20 11:54 AM
M
mclasser Offline
M
Yeah, they didn't touch the back (unless bro only asked for a front end alignment). Most shops only do a toe-and-go and say in the fine print they'll mess with other stuff for an add'l fee.
Could be several things:
(1) Back not in sync w/the front
(2) Lazy tech didn't center the steering wheel correctly
(3) Something is bent - FR camber is suspect
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5333750 01/27/20 01:05 PM
sloinker Online Shocked
Online Shocked
I had a Ford pickup,(IFS 4X4), many years back that hit a deer on the passenger headlight area. They had to replace basically all the steering and suspension parts along with the sheet metal and plastic parts. It still wouldn't come into alignment specs. They eventually put it on a frame machine and pulled that last few thousandths to make it compliant to minimum specs. Built Ford tough.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Alignment questions: is camber/caster not usually touched? [Re: FordBroncoVWJeta] #5334096 01/27/20 07:00 PM
BlueOvalFitter Offline
I just recently had an alignment done on my 07 F-150. They stated my caster/camber needed to be adjusted. They recommended a caster/camber shim kit. I ordered it and had my son install it. I brought it back to have it aligned and they got it right on!
thumbsup
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
