GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
2015 Forester - whine/Rough at specific RPM
by MoneyJohn - 02/19/20 09:06 AM
Brake hum when backing up after a rain storm
by vortex - 02/19/20 08:54 AM
TorchHypnosis, Tgibson, GardenStateAudi, Strommen95, Idaholewis
70748 Registered Users
118 registered members (andreigbs, 1978elcamino, 28oz, 750IX, 01rangerxl, 4WD, 14 invisible), 2,369 guests, and 26 spiders.
Topics301,659
Posts5,200,094
Members70,748
So I picked this up.. #5333183 01/26/20 08:49 PM
M
Mad_Hatter Offline OP
M
Got this little nugget of intake cleaning goodness from Amazon today. Can't wait to try it out, it's induction method so no diluting... nice thing is I can reuse the bottle and set up with any cleaner.
product info
[Linked Image]
Re: So I picked this up.. [Re: Mad_Hatter] #5333187 01/26/20 08:58 PM
O
OilReport99 Offline
O
Is that a PEA based cleaner?
Re: So I picked this up.. [Re: Mad_Hatter] #5333194 01/26/20 09:05 PM
spasm3 Offline
That looks interesting. You just have to be careful using it in a dry flow ( GDI) intake. I worry about pooling then hydrolocking if it pools anywhere in the intake and you step on the gas. I have used the CRC product, but not the whole can, and i kept the revs down under 3k for several miles.
I do like the idea that you could put something else in the can! Maybe kreen as discussed in an earlier thread for GDI engines.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: So I picked this up.. [Re: OilReport99] #5333196 01/26/20 09:07 PM
spasm3 Offline
I don't think so, its a strong brew of solvents, but they clean. In my MPFI engines, i run a tank with b-12 dumped in the tank, then a follow up tank with a bottle of techron I do that before an oil change.
Re: So I picked this up.. [Re: spasm3] #5333198 01/26/20 09:09 PM
O
OilReport99 Offline
O
Thanks
Re: So I picked this up.. [Re: spasm3] #5333231 01/26/20 10:01 PM
M
M
Correct and that's what I'm doing. I'm due to change the oil out next weekend so I thought it would be a good time to give this a try. In the future I think I will refill the can with a PEA based cleaner but using this mix of solvents should give the valves on my PI engine a good cleaning. The instructions say that the provided "T", which has a open hole, is dialed to meter and atomize the solution so as not to stall.. like I've had happen to me just spraying directly into the intake form a can. The instructions go on to say that at normal idle it should take between 8~10mins to empty out the can. I'm gonna do it with my son next weekend so I can have him behind the wheel to give the engine some throttle if needed but I'm hoping it goes as planned/described and that won't be necessary. Then we'll do the oil change once the cans emptied out and go for a nice long drive. That's the plan anyhow...
I plan wash all the plastic in a tub of soapy water afterwards and fill up the can with some MMO I have on hand to prevent corrosion until it's needed next winter/spring. Truth be told I really wanted the can and jig setup for use with other cleaners but I'll take the Berryman's. I thought about making my own setup..but meh, I decided I was too lazy for that and the price for this wasn't that bad
Re: So I picked this up.. [Re: Mad_Hatter] #5333289 01/26/20 11:06 PM
daves87rs Offline
Thought about giving that a try.....
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier
Too much GM.. ;-)
Re: So I picked this up.. [Re: Mad_Hatter] #5333364 01/27/20 06:31 AM
P
pbm Offline
P
What did that kit cost? It seems like it could provide some benefit over pour in products.
'Journalism is Dead'
Re: So I picked this up.. [Re: Mad_Hatter] #5333375 01/27/20 06:53 AM
P
pbm Offline
P
Re: So I picked this up.. [Re: Mad_Hatter] #5333528 01/27/20 09:56 AM
StarCaller Offline
Re: So I picked this up.. [Re: Mad_Hatter] #5334018 01/27/20 05:54 PM
B
BAJA_05 Offline
B
What vehicle are you using it in there Huckleberry?
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: So I picked this up.. [Re: pbm] #5334144 01/27/20 07:53 PM
M
M
That's my thinking pbm.. undiluted cleaners.
Sorry yes, about $13 on Amazon. It's not a bad deal.. you'd pay about half that just for the can of Berryman's Total and you can reuse the setup over and over.
Re: So I picked this up.. [Re: BAJA_05] #5334150 01/27/20 07:58 PM
M
M
You know Baja..I'm really not interested in conversing with you until you can learn to conduct yourself like an adult on this forum. I really don't need anymore unprovoked, profanity laced private messages from you. And fwiw, anyone who's followed my posts knows what I drive and have driven, so I'm not going to indulge your childish antics, thank you.
Have a great rest of your day...
[Linked Image]
Re: So I picked this up.. [Re: Mad_Hatter] #5334324 01/28/20 12:14 AM
Skippy722 Offline
[Linked Image]
Imagine having to care so much about a particular brand and what other people drive. crzy
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: So I picked this up.. [Re: Skippy722] #5334334 01/28/20 01:28 AM
dogememe Offline
[Linked Image]
Ikr lol
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
