PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
108 registered members (4WD, atikovi, AdditiveOCD, ArrestMeRedZ, Al, 762fermeandyou, 8 invisible), 1,906 guests, and 20 spiders.
Topics302,056
Posts5,208,260
Members70,826
Need some advice, how to repair chipping paint on rough stucco #5333151 01/26/20 08:12 PM
dishdude Online Content OP
OP Online Content
Bought the house 5 years ago, at the time a sprinkler was hitting this spot of the house, I fixed that immediately and had the house professionally painted. Apparently the sprinkler damaged the original paint and it is now chipping. What can I use to remove the loose paint? I've peeled some off by hand and tried a brush. Should I use a pressure washer, wire brush or a some type of a drill attachment? The stucco is a rough texture so scraping isn't an option.
Also, what primer would be recommended after I get this cleaned up?
[Linked Image from i.imgur.com]
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Need some advice, how to repair chipping paint on rough stucco [Re: dishdude] #5333172 01/26/20 08:37 PM
W
walterjay Online Content
Online Content
W
Get professional advice. If you go to a place such as Sherwin Williams they may have a solution.
Re: Need some advice, how to repair chipping paint on rough stucco [Re: dishdude] #5333335 01/27/20 05:25 AM
demarpaint Offline
Power washing combined with wire brushing works well. After power washing expect the edges to curl up a bit as it dries out. Go back at those areas with a wire brush until you get it smooth and flush with no loose edges. That can take time and be a PITA. Spot prime it with a good latex primer like NO23 BM Fresh Start Exterior primer when there is shade on that side of the house. You want the primer to dry slowly w/o the aid of the sun/heat. Paint with a good latex exterior paint. Make sure you paint in the shade, especially in areas of the country like Arizona. Be careful of paint store advise, not all paint stores are created equal, I've heard them give some real bad advice over the years.
Get a good dust mask if you do any wire brushing, and wear it!! Good luck! If you decide to use an airless sprayer be sure to back roll it while the paint is wet.
God Bless Our Troops
Re: Need some advice, how to repair chipping paint on rough stucco [Re: demarpaint] #5333845 01/27/20 02:52 PM
OP Online Content
Thank you! This is just the advice I was looking for.
Re: Need some advice, how to repair chipping paint on rough stucco [Re: dishdude] #5333893 01/27/20 03:43 PM
demarpaint Offline
No problem. PM me if you have any questions or problems.
