Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
48 registered members (97f150, blufeb95, bachman, 74Widebody, 2013ecof150, BusyLittleShop, 4 invisible), 1,232 guests, and 23 spiders.
Topics301,810
Posts5,203,160
Members70,784
How many ounces of dishwasher to clean oil in cooling system? #5332927 01/26/20 04:43 PM
I
Isaac Offline OP
I
Hello Guys
I have a 2008 Volvo XC90 3.2 and the coolant reservoir was full of oil sludge.
A couple of weeks ago I replace the Water to Oil cooler because it was cracked and it was allowing oil to pass to the cooling system.
We flush with water all the cooling system until clear water come out from the radiator.
A week later there is still a little oil floating in the water and grease stuck to the walls of the coolant reservoir. Check my pic.
I have flush again with water, but there is still oil floating and also is sticking to the walls of the coolant reservoir
I want to clean the entire system very well, before adding the coolant.
I have read that many people use liquid dishwasher to clean up the remaining oil residue.
How many ounces of liquid dishwasher should I add to the coolant reservoir to completely clean the residual oil that remains in the cooling system?
Thx for your time and help
Isaac
Oil grease stuck to the walls of the coolant reservoir
[Linked Image]
Cleaned after the water flush
[Linked Image]
2008 Volvo XC90 3.2L AWD
2002 SKODA Octavia 1.8T
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5332929 01/26/20 04:45 PM
E
eljefino Offline
E
You want automatic dishwasher soap as it doesn't sud. If you use hand dish soap the bubbles will mess your car up hysterically.
A few teaspoons ought to do it. Remember there's stuff like chlorine in there you don't want to run long-term. Do a few fresh water rinses when done.
If you can remove the reservoir, plug its openings, and shake your cleaner around, you'll get better results, but it won't be indicative of the hidden parts of the rest of your engine, radiator, etc.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5332952 01/26/20 05:09 PM
A
atikovi Offline
A
Went through this on a 2017 Chevy Spark when the trans cooler in the radiator ruptured. Used half a 5 pound box of Cascade powder in 2-3 batches, then ended with Prestone 2 in 1 Flush and Oil Degreaser.
[Linked Image from prestone.com]
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5332972 01/26/20 05:22 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Use shout, per this diy:
https://www.dieselgiant.com/mercedes_citrus_flush.htm
Which lays out the Mercedes citric acid flush.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: atikovi] #5333000 01/26/20 05:45 PM
L
Lubener Offline
L
+++1 keep the dish detergent for dishes.
The "thinking" man's friend.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5333010 01/26/20 06:01 PM
SVTCobra Offline
I ran Dawn dish soap to clean out diesel that leaked into the coolant on my old 7.3 Powerstroke. Never did run into any problems with uncontrolled foaming. I just squirted a heavy amount and filled with water, drove it to work for 2-3 days, then drained while hot. Repeated it 4-5 times until the water didn't have a film and refilled with green antifreeze. Never did have a problem.
Think twice, speak once.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5333035 01/26/20 06:28 PM
M
maxdustington Offline
M
99 Toyota Tercel CE 5EFE/C151
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: SVTCobra] #5333178 01/26/20 08:46 PM
O
oldhp Online Content
Online Content
O
↑↑↑↑↑ This ↑↑↑↑↑
Did this on a 3.1 Lumina. Intake gasket leaked. Ran 2 batches of Dawn thur it with no thermostat in it, heater on high. Put hose in top of radiator and it run for 45'ish minutes while return heater was off. Worked like a charm.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: oldhp] #5333217 01/26/20 09:41 PM
B
BigGeo Offline
B
I just went through a similar problem with my son’s ‘08 accord. I used simply green, which worked great. Here’s the instructions https://simplegreen.com/cleaning-tips/rooms/automotive/radiator/
Applied the procedure 3 times.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5333332 01/27/20 05:15 AM
dlundblad Offline
I would just get some food grade citric acid. 2 lbs should be enough for your engine. Fill with water, run at idle for 20-30 mins depending on if you remove the thermostat. Rinse, rinse and rinse again. Refill with antifreeze.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5333421 01/27/20 07:54 AM
L
Linctex Offline
L
I like the simple green idea, never thought of that.
I've always used a generic equivalent of Cascade dishwasher soap, about 2-3 cups
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Linctex] #5333453 01/27/20 08:32 AM
doitmyself Offline
Originally Posted by Linctex
I like the simple green idea, never thought of that. I've always used a generic equivalent of Cascade dishwasher soap, about 2-3 cups
Note that BigGeo's link is for the Simple Green Pro HD version available at Home Depot. This formula is the homeowners version of the Simple Green Aviation product that claims to be safer for metal, plastic, rubber, etc..
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5334076 01/27/20 06:44 PM
I
Isaac Offline OP
I
Guys
Thx so much for your advices. I live in Central America so I need to see what Product I find.
My Mechanic is using Formula 83 Degreaser This thing has help but I am tire of flushing this thing. I am in my 3er Flush and I want something that clean this immediately.
This saturday I will check in a hardware store to see if I find something more aggressive.
[Linked Image]
We have to remove the admission manifold (Volvo Engineering) to have access to replace the Water to Oil cooler and also I took the opportunity to put a new thermostat.
[Linked Image]
[Linked Image]
This thing was very dirty
[Linked Image]
Check where is the alternator shocked2
[Linked Image]
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5334428 01/28/20 07:27 AM
K
Kira Offline
K
What caused the oil cooler to leak? Are they known to be cheap?
How is the alternator driven?
Good job getting it all cleaned up.
Re: How many ounces of dishwasher to clean oil in cooling system? [Re: Isaac] #5334766 01/28/20 03:11 PM
N
nthach Offline
N
In Panama, I assume P&G sells Mexican Tide or Ariel laundry detergent or you have access to a store that sells janitorial supplies. I'd run Mexican Tide or find a phosphated dishwasher detergent at a rate of 3-4oz for the cooling system capacity. Remove the thermostat and run the engine at operating temp for at least an hour. Cool down, drain, repeat until no oil residue is left. Then do a triple flush with fresh water to remove all the detergent.
The pressure cap will reduce risk of foaming up.
