Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
67 registered members (Astro_Guy, bullwinkle, 2002 Maxima SE, 4WD, Bailes1992, 6 invisible), 1,463 guests, and 18 spiders.
Topics301,732
Posts5,201,619
Members70,766
Tire Pressure Gauge #5332682 01/26/20 12:06 PM
Smoky14 Online Content OP
OP Online Content
As I age I find it harder to check tire pressure in these 17" wheels especially the front with disks almost as large as the wheel. Has anyone discovered a easy solution? I think a gauge with almost a reverse angle would work, I tried bending the brass end fitting on a gauge and only managed to snap it off.
Any ideas.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: Tire Pressure Gauge [Re: Smoky14] #5332697 01/26/20 12:30 PM
W
Wolf359 Offline
W
I normally never check the tire pressure. Have cars that have the TPMS on them so only do it when it's low. Only time I hook up is with a tire inflator like this Ryobi. Has the pressure gauge right on it and it's easy to see.
https://www.homedepot.com/p/RYOBI-18-Volt-ONE-Cordless-Power-Inflator-Tool-Only-P737/206159256
Re: Tire Pressure Gauge [Re: Smoky14] #5332705 01/26/20 12:39 PM
J
JLTD Offline
J
Got a picture? That would help with suggestions. I have always use the pen-style pressure tester, which is angled near the end so the fitting is at 45°.
Lates.
Re: Tire Pressure Gauge [Re: Smoky14] #5332735 01/26/20 01:13 PM
A
atikovi Offline
A
Assuming it's the Fusion. Doesn't it have a tire pressure reading in the display screen?
Re: Tire Pressure Gauge [Re: Smoky14] #5332761 01/26/20 01:46 PM
02SE Offline
All our streetbikes are Sportbikes with very little clearance between the discs and the wheel. I use a tire pressure gauge which has a 45° angled chuck on the end of a hose which is about a foot long. I get in front of the front wheel, with the valve stem at about the 4 o'clock position as viewed from the right side (when seated on the bike) of the bike. With my right hand I feed the chuck in between the discs and wheel, and with my left fingers coming in from the other side of the wheel I press it onto the valve stem to get the reading. I use the same procedure to add air if needed. Works for me, and is easy enough that I've never had an issue.
Re: Tire Pressure Gauge [Re: Smoky14] #5332901 01/26/20 04:05 PM
BusyLittleShop Offline
Angle valve stems are the best solution for easy access in tight conditions...
[Linked Image from dealsanimg.com]
My RC45 angle valve stem circled in white...
[Linked Image]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Tire Pressure Gauge [Re: Smoky14] #5332914 01/26/20 04:22 PM
02SE Offline
I also have angled valve stems on our Sportbikes.
Re: Tire Pressure Gauge [Re: Smoky14] #5332919 01/26/20 04:26 PM
N
Nukeman7 Offline
N
This digital tire gauge is extremely accurate and affordable. The 45 degrees offset should work for your situation.
Accutire MS-4021
Re: Tire Pressure Gauge [Re: Smoky14] #5333101 01/26/20 07:25 PM
Z
ZeeOSix Offline
Z
Gauge with a hose and 90 degree head works pretty good. This one has the button to let air out too. So over fill the tire, put the gauge on and let air out until you reach the pressure you want.
https://www.amazon.com/Accu-Gage-RA60X-Right-Angle-Pressure/dp/B002MQOXGW/
Re: Tire Pressure Gauge [Re: Wolf359] #5333201 01/26/20 09:13 PM
B
Bonz Offline
B
You don't check your tire pressures on your motorcycles?
Re: Tire Pressure Gauge [Re: Bonz] #5333203 01/26/20 09:16 PM
spasm3 Offline
When i had a little GZ250, i checked the tire pressure every other day riding to work. If it sat a few days, i always checked it before a ride.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Tire Pressure Gauge [Re: Smoky14] #5333368 01/27/20 06:40 AM
A
alarmguy Offline
A
I often wondered, more so now, is there a "gold" standard in mechanical tire pressure gauges.
So many of them are cheaply made. I guess with a simple search I can find one that is calibrated to some named standard?
I still have a Sears Craftsmen from the 1970s that seems to be rock solid, round gauge with needle.
We also have a bunch of those "stick" gauges all of questionable quality including the Sears now that it is so old.
I guess I can just compare them all on the same tire but would be nice if there is some official standard that some gauges carry.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Tire Pressure Gauge [Re: alarmguy] #5334059 01/27/20 06:32 PM
B
Bonz Offline
B
Honestly from my experience, those stick gauges that cost a couple bucks don't do a bad job. I have compared them to more "accurate", meaning more expensive gauges, also against the TPMS numbers on various vehicles and they are pretty much right there.
Re: Tire Pressure Gauge [Re: Bonz] #5334522 01/28/20 09:43 AM
L
LoneRanger Offline
L
I'm guessing he didn't catch that it is a motorcycle thread. My bike has a center stand so one thing I always do during the "pre-flight" in add'n to checking pressure is I turn each wheel one revolution and make sure there's nothing sticking in the tire, i.e. nails or other road debris. Inflation specs for my Guzzi, are same one-up or two-up: 36 psi front, 42 psi rear.
I use a stubby dial gauge like this, it clears the discs front and rear:
https://www.homedepot.com/p/Slime-5-60-psi-Chrome-Dial-Gauge-20049/203351010
You can also get them with angled nozzles or flex hoses.
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: Tire Pressure Gauge [Re: Smoky14] #5334690 01/28/20 01:16 PM
N
natas Offline
N
PSA - Motorcycle Tire Air Pressure
Check your tire pressure on your bike at LEAST 1x a week--preferably every time you ride (or every other day, etc.) with an ACCURATE gauge.
This is a Public Service Announcement.
I have one of those Milton dual head tire inflators with a built in gauge and it's a pain to to get to the schrader valve--with the valve at the 6 O'clock position, I have to bring the inflator down from above between the spokes to get an an angle to attach to the valve--a royal pain.
