Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
Sony MEX-GS820BT, good AM/FM?
by sasilverbullet - 02/27/20 05:59 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
23 registered members (BlueOvalFitter, dishdude, Bailes1992, alcyon, bbhero, AnthemBassMan, 3 invisible), 662 guests, and 16 spiders.
Topics302,026
Posts5,207,493
Members70,819
4runner oil level. #5332600 01/26/20 10:17 AM
L
laserred96gt Offline OP
L
I've noticed something odd when checking the oil on our 17 4runner, when checking the dip stick it indicates that it is way over filled.
We purchased it used last year so the whole time I was thinking the dealer over filled it but this time I changed it myself and put in exactly 6.6 quarts which is what the manual calls for and it reads the same.
I'm not sure why the pictures are showing upside down.
[Linked Image]
[Linked Image]
2017 4Runner Limited, 52k
04 E-150, 4.6, 245K, Synblend 5w20.
11 Camry 2.5, 74K, PU 5w20.
Re: 4runner oil level. [Re: laserred96gt] #5332610 01/26/20 10:39 AM
AZjeff Offline
If you hold the dipstick right down near the radiator cover the focus will be better. Can't see much the way it is.
Have you checked on 4runner forums to see if this is a thing?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 4runner oil level. [Re: laserred96gt] #5332611 01/26/20 10:39 AM
T
TmanP Offline
T
I've always found that style of Toyota dipstick to be difficult to read.
I'd guess that you're just reading smeared oil from the side of the tube.
I usually wipe and try at least 2 or 3 times till I'm satisfied, and it's definitely easier with a cold engine.
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: 4runner oil level. [Re: AZjeff] #5332615 01/26/20 10:42 AM
L
L
Yes I actually just googled it and found a post on a 4runner forum about it, it does seem like other people are having the same issue, thanks. I'm fine with it as long as it doesn't cause an engine problem.
Re: 4runner oil level. [Re: laserred96gt] #5332623 01/26/20 10:50 AM
V
VQ35DE Offline
V
Needs to be cold. We have a 2016 4runner.
2017 Mazda CX-5 GS AWD
Re: 4runner oil level. [Re: laserred96gt] #5332625 01/26/20 10:52 AM
L
L
I took a couple more pictures after pulling it out and wiping it off multiple times and still don't get a clear reading. I've never had a vehicle with a difficult to read dip stick like this one.
Now one side shows a little over filled and the other shows way over filled, the car has been sitting cold all through the night.
[Linked Image]
[Linked Image]
Re: 4runner oil level. [Re: laserred96gt] #5332632 01/26/20 11:01 AM
Delta Offline
Those dipsticks are like that. I have the older 4.0 and it does the same thing. Basically have to wait 30 minutes in between readings to allow what was on the side of the dipstick tube to flow back down to get an accurate reading.
'17 VW GTI 2.0T - 6MT - 20K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 139K - RGT 5w30
Re: 4runner oil level. [Re: laserred96gt] #5332665 01/26/20 11:50 AM
I
iahawk Offline
I
just a thought...but when you drain your oil you don't get it all out...and if you're always adding the full 6.6 liters the manual says you are adding to the overfilled amount at each oil change. Why not try draining oil at next change and not adding the full 6.6..just add enough to reach the full mark on the dipstick?
Re: 4runner oil level. [Re: laserred96gt] #5332678 01/26/20 12:02 PM
02SE Offline
Probably stating the obvious, but you did drain the oil filter canister, and change the filter. And also started the engine to refill the oil filter canister and then shut the engine off and let the oil drain back into the sump while on level ground, I assume.
Re: 4runner oil level. [Re: laserred96gt] #5332689 01/26/20 12:13 PM
P
PWMDMD Offline
P
I have never been able to add whatever the oil capacity of the engine is regardless of make or model because you never get all the oil out. If it says 5.5qts I start with 5qts and then add until it's to the full line. In this example, I'm never able to add an additional 0.5qts no matter how long I allow the oil to drain and usually 5.0qts brings me to the top. I assume there is half a quart still inside the engine.
Current: 2019 Lexus RX 350 (Mobil AFE 0W-30 and Toyota OEM Filter) and 2018 Honda Pilot Touring (PP 5W-30 and Mobil 1 EP M1-110A Filter)
Re: 4runner oil level. [Re: laserred96gt] #5332701 01/26/20 12:35 PM
J
JLTD Offline
J
Mine is tough to get a reading on also; but since it doesn't burn any in 10,000 miles thumbsup
Seriously though when I do an oil & filter change I put 6 1/2 quarts in it, and it is near the top of the hatched area on the stick.
You might want to try turning the dipstick 20 or 30° in either direction to avoid having the two sides indicate different amounts… It has worked for me. But if you turn it too far, it will be unable to reach the sump.
Lates.
Re: 4runner oil level. [Re: laserred96gt] #5333157 01/26/20 08:21 PM
T
Triple_Se7en Offline
T
Read the dipstick on the first pull - cold engine reading-only. Wait 30 minutes for a 2nd reading, due to the design of the dipstick tube.
Our Kia 2.0 MPI has similar issues with higher readings on one side of the dipstick, if I try to read the dipstick twice within a minute or two.
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
04' Chevy Colorado Castrol 0W40 & Wix
Re: 4runner oil level. [Re: laserred96gt] #5333755 01/27/20 01:11 PM
J
john_pifer Online Content
Online Content
J
6.6 quarts? That’s interesting. My 2007 PreRunner 4.0 is only a 5.5-quart capacity.
Uses no oil after 225K mi.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 225K
18 Civic HB 1.5T 6MT (Fiancee's) - VME 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 4runner oil level. [Re: laserred96gt] #5333904 01/27/20 03:53 PM
DGXR Offline
Pull the dipstick, wipe it clean and leave it out of the engine for at least 2 hours, preferably overnight. Push it all the way in and pull it out, then you will get a clear reading. The dipstick inside the tube is such a narrow fit that it keeps oil stuck in the tube as long as the dipstick is inside, which messes up the oil level readings. I thought they would have figured out the design problem by now.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
