Windshield Damage
by MolaKule - 02/28/20 10:16 PM
Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
88 registered members (4WD, BHopkins, bbhero, AZjeff, BigCahuna, 9 invisible), 1,706 guests, and 16 spiders.
Topics302,062
Posts5,208,310
Members70,826
is the vw505.01 strongest oil of them all? Use in petrol engine? #5332391 01/26/20 01:04 AM
P
Polyalphaolefin Offline OP
P
If PD engines are the most demanding for anti wear oil properties, and require VW 505.01 (5w40) oil, does it means it can be used in regular MPI nonTurbo petrol engine, just for increased protecion (where ordinary acea a3 (505.00) oil is required). ?
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5332410 01/26/20 04:04 AM
bachman Offline
I don't think strongest or most protective is necessarily any one formulation for all motors.
In a generic sense, unless my car or the motor has very specific requirements that I'd think of as 'fussy', my generic Go To oil was always Shell Rotella T synthetic. That or something similar might be just fine for your situation. VW 505 as you refer to might be just fine or overkill and a bit pricey but that doesn't stop any of us from playing it safe. If your owners man sounds fairly simple in oil specs, you'll have some latitude and can go for the respected synthetics in your area that are more competitively priced IMO.
At present, I do follow the guide of O Manuals for the Mazda and VW whereas my old cars weren't as fussy.
This below may have a cross ref to the motor/s you have there but your car manual is best for specifics. If it's just showing the basic grades as this list does, you probably have many good options.
https://www.kia.com/content/dam/kwc...aintenance/Oil-Grades-and-Capacities.pdf
95 Honda Nighthawk- Rotella T6 syn
17 Golf SW 4MO dsg- Dealer LOF/5-6k *New spec syn -VW/Audi XOM ?
16 Mazda CX9 Tour- Dealer LOF/5-6k Casterol full syn
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: bachman] #5332413 01/26/20 04:37 AM
M
Mainia Offline
M
The irony......Hyundai, the car manufacture with the most engine problems has the least heavy duty oil specs.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5332419 01/26/20 05:00 AM
O
Olas Offline
O
505.01 uses zn/p as antiwasr for the additional camshaft lobe used to drive the injector pump - comtact pressures are very high and the lobe is very narrow.
If your problm is related to spring preseure and cam wear then use it and see benefits. If your problem is not related to the presence of AW compound it wont matter if you use it or not.
What problem are you trying to address?
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5332420 01/26/20 05:01 AM
O
Olas Offline
O
To answer your question directly, yes it is suitable. If you burn oil your cat may suffer but that is not the oils problem it is the leaking seals problem.
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5332572 01/26/20 09:40 AM
P
P
I dot have any problems, just tryingf to find "mojst protective" oil for my engine. Price od 505.01 oil is about the same as any other ACEA A3 oil. My car specifies ACEA A5, but I use A3 to be safer, who cares about fuel economy. I was looking at commaoil.com ther oil for PD engine: PD plus, and "ordinary" 5w40 Syner-G, both have same levels of Zn and P...
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5332609 01/26/20 10:34 AM
O
Olas Offline
O
Any A3/B4 oil will give you all the protection you need - if you want more then go to Redline, they have the most.
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Mainia] #5332626 01/26/20 10:53 AM
N
nascarnation Offline
N
True, but not sure if better oil would have saved them from the problems.
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Olas] #5332637 01/26/20 11:06 AM
K
Kamele0N Offline
K
Originally Posted by Olas
Any A3/B4 oil will give you all the protection you need - if you want more.........
ForMPI engine in your sig.......MB 229.5...BMW LL-01.....Shell helix ultra 5w40 wink
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5333999 01/27/20 05:35 PM
E
edyvw Offline
E
It can be also 0W30 or 5W30.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: nascarnation] #5334079 01/27/20 06:47 PM
T
tundraotto Offline
T
Interestingly enough - my wifes 2015 KIA Sedona has a spec for ACEA A5 or better....that's a pretty hard to find 'economical oil' - spec....and it's not even turbo, just GDI. (3.3L Lambda)
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: tundraotto] #5334313 01/27/20 11:16 PM
E
edyvw Offline
E
That does not exists! That exists only in minds of engineers of Hyundai/KIA and they are dead wrong! We chewed this subject numerous times.
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: Polyalphaolefin] #5334424 01/28/20 07:16 AM
O
Olas Offline
O
, just tryingf to find "mojst protective" oil for my engine...
the most powerful engines need the most protection, so on that basis you shoudl use Redline 70wt nitro.
consider that the most isnt always the best for a given application - seriously, any a3b4 will make the engine last until the car rusts away
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: edyvw] #5334929 01/28/20 07:38 PM
T
tundraotto Offline
T
That's right - not yet, it doesn't, until the new ACEA specs come out.
My point was that if Huyndai's oil specs are weak - it rather weird that their other economy brand KIA - has pretty stiff specs....I am sure there are a few shared engines also....wonder how their oil specs differ?
Re: is the vw505.01 strongest oil of them all? Use in petrol engine? [Re: tundraotto] #5338496 02/01/20 08:43 PM
M
Mainia Offline
M
I say the heck with Hyundai’s oil spec., it is weak.I run Mobil 1 5w 30 ESP in the winter and may go with Pennzoil 5w 40 Euro in the summer in my 1.6T Hyundai Kona AWD.
2005 Honda Civic
