Originally Posted by PowerSurge
Originally Posted by Leo99
I wrench my oil filters on. Better to be a little tight than to leak.
Been changing my own oil for over 30 years. Oil filters always hand tightened. No leaks ever. Spin on by hand until gasket makes contact then another 3/4 turn. Good to go.
Do the same here. 3/4 turn after the gasket makes contact with the filter base, the heat of the engine causes the gasket to swell slightly to help seal it up. I have a fairly good grip after all those years in the quick lube business. I can twist the oil filter off bare handed on my truck when I remove it.
For those suggesting to drive a screwdriver through the filter, its risky. I've had several brought to me over the years on a tow truck after the owner drove a screw driver through the filter and nicked the threads on filter mount. That scenario ultimately locks the filter down and you won't spin it off unless the threaded base comes out with the filter.
