Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
110 registered members (53' Stude, 762fermeandyou, Aichiguy, 4WD, alchargo, AndyB, 11 invisible), 2,671 guests, and 36 spiders.
Topics301,518
Posts5,197,175
Members70,712
Page 1 of 3 1 2 3
'12 Civic burning oil after switch to M1 #5332288 01/25/20 09:33 PM
sr20detfwd Offline OP
Just inherited a 2012 civic 1.8 from my aunt, and she always had it serviced at the dealer promptly when the maintenance minder came on. It has 92,xxx miles, I switched to Mobil1 and a Honda filter and ive been burning about a 1/2 quart every 700 miles since the oil change, about 3400k since last oil change. No leaks and it runs beautifully.
I didn't see any mention of low oil during any previous dealer oil changes which has me wondering if M1 is causing the burning(im sure they may not even check)? Should i try switching back to Honda's oil? Very strange, not sure what the next step is.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332291 01/25/20 09:34 PM
O
OVERKILL Online Content
Online Content
O
Is this the first OCI on M1? If so, give it at least two OCI's before you switch, sometimes it settles and stops.
Re: '12 Civic burning oil after switch to M1 [Re: OVERKILL] #5332293 01/25/20 09:38 PM
Gotcha, yes its the first oil change. Forgot to mention using the recommended 0W-20 as well.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332294 01/25/20 09:39 PM
O
Online Content
O
You use M1 AFE, EP or AP?
Re: '12 Civic burning oil after switch to M1 [Re: OVERKILL] #5332297 01/25/20 09:42 PM
It is the AFE i am using.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332298 01/25/20 09:44 PM
O
Online Content
O
thumbsup Keep an eye on it, but I expect it will probably taper off.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332299 01/25/20 09:45 PM
Thanks for the help, ill keep an eye on it.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332309 01/25/20 10:02 PM
K
kstanf150 Offline
K
Any idea what the Honda dealer used ?
Re: '12 Civic burning oil after switch to M1 [Re: kstanf150] #5332327 01/25/20 10:20 PM
I looked at the history, seems to bounce between 0w20 SYNBLEND and 0w20 FULLSYN.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332368 01/25/20 11:35 PM
stanlee Offline
Official volatility numbers withstanding I'm pretty certain my truck burns 0w-30 M1 AFE at a noticeably higher rate than pretty much everything else I've used (all 5w30 synthetics) including other M1 products.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332397 01/26/20 02:18 AM
Char Baby Offline
I use QSUD 0W20 in the Civic 1.8L in my signature. Doesn't burn a drop during the whole OCI which has been as long as 9200 miles/6 months. Try it and you may notice some extra engine quietness as well.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332415 01/26/20 04:45 AM
demarpaint Offline
As mentioned it might take an OCI or two for the consumption to taper off. If after the second OCI with the oil you still have a consumption issue, and the PCV valve is good, and there are no leaks, switch back to the oil you were using before. That's what I would do.
God Bless Our Troops
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332447 01/26/20 06:25 AM
I changed the PCV a month or two ago with an OEM one, seems "springy" and functional prior to install lol.
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332448 01/26/20 06:28 AM
K
ka9mnx Offline
K
I tried AFE when it first came out and had the same issue. I was impatient and went back to vanilla M1.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: '12 Civic burning oil after switch to M1 [Re: sr20detfwd] #5332450 01/26/20 06:32 AM
O
OilReport99 Online Content
Online Content
O
I ran AFE 0W-20 in a 2012 Corolla, and it didn't consume any oil. OCI was 10k miles or one year.
Page 1 of 3 1 2 3
