Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
93 registered members (Alaskanmont, 53' Stude, 2004tdigls, 5AcresAndAFool, 4WD, 2K2AcuraTL, 7 invisible), 1,958 guests, and 17 spiders.
Topics303,305
Posts5,233,664
Members71,038
Oil for my 65 mustang. #5332019 01/25/20 05:12 PM
old1 Offline OP
I won't need any for some time, as I have a few gallons of the old hddo oil from before anybody started to lower the ZDDP in it, but at some point I will have to start to use more modern oils. What I am wondering is if since my engine is a well broke in 65 200 ci stock engine, is it even necessary to use an oil with more than the SN amount of ZDDP?
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Oil for my 65 mustang. [Re: old1] #5332020 01/25/20 05:15 PM
spasm3 Online Happy
Online Happy
Flat tappets? I'd want more zinc than sn.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Oil for my 65 mustang. [Re: old1] #5332029 01/25/20 05:29 PM
RDY4WAR Online Content
Online Content
The OEM cam of the 200ci doesn't really "need" additional ZDDP. It won't hurt, but isn't a necessity. The cam lobes have weak enough ramps, paired with weaker OEM valve springs, where the 800 ppm API SN/SN+ limit on phosphorus is sufficient.
I will of course recommend Driven GP-1 10w-30 or 15w-40 as it is formulated specifically for such an application. Mobil 1 0w-40 would be a decent choice also.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Oil for my 65 mustang. [Re: old1] #5332061 01/25/20 06:20 PM
old1 Offline OP
I kinda thought that the SN limits would probably be ok, but then some oils have considerably less than the 800 limit. I guess I probably shouldn't worry about it till I am on my last jug of what I have, because by then the oils on the market will probably far different than they are now. Not to mention that I may not even be driving anymore by that time, as I have enough for at least 5 years. Since I only change it at most once a year, sometimes only every 2 years, as I only drive it about 1000 miles a year, and all warm weather, and mostly long drives.
Re: Oil for my 65 mustang. [Re: old1] #5332090 01/25/20 06:55 PM
K
ka9mnx Offline
K
Back in '65 most oils contained less, and less effective, ZDDP than modern oils.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Oil for my 65 mustang. [Re: old1] #5332114 01/25/20 07:15 PM
N
Nitronoise Offline
N
Rotella 10w 30 HDEO for semi's has a big zinc loading over950 PPM works well with older muscle cars and the detergent package keps them clean as a whistle
07 Ford Freestyle 166K
06 Honda Acord EX 133K
02 Ford Tarus 123K
00 Buick Regal SC 144K
95 Goldwing 28K
Re: Oil for my 65 mustang. [Re: RDY4WAR] #5332123 01/25/20 07:25 PM
O
OVERKILL Offline
O
I second the M1 0w-40 recommendation as it is relatively cheap and very easy to find.
Re: Oil for my 65 mustang. [Re: old1] #5332141 01/25/20 07:41 PM
J
JeffKeryk Online Content
Online Content
J
Any decent 10w30 or Shella Rotella 15w40.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Oil for my 65 mustang. [Re: old1] #5332145 01/25/20 07:48 PM
super20dan Offline
the ford 6 isn't oil picky. the small block 289 and 302 might be a different story. I got lifter ticks from time to time with these engines. all my ford 200,s 250 and 170 were happy on most anything
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Oil for my 65 mustang. [Re: old1] #5332165 01/25/20 08:15 PM
G
Gokhan Offline
G
For flat tappets you want a 10W-30 or 15W-40 -- in other words an oil with a thick base oil, as the flat tappets temporarily shear the VIIs, which, as a result, cannot thicken the oil as intended. Don't worry about ZDDP -- modern oils have a better antiwear package than oils of the past with high ZDDP.
Amsoil ACD 10W-30/SAE 30 is a monograde, and it's as good as it gets for a 10W-30 -- it has a thicker base oil than that of a 15W-40.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 70 mpg on gas, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Oil for my 65 mustang. [Re: old1] #5332193 01/25/20 08:49 PM
F
fraso Offline
F
You could probably use a Starburst oil and not have any long-term wear issues with it. I use 10W-30 Petro-Canada Duron SHP HDEO in my slant six because it is also suitable for API SN. See Engine Wear.
