Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
116 registered members (762fermeandyou, AlaskaMike, 928, atikovi, 69GTX, 390pi, 13 invisible), 2,486 guests, and 24 spiders.
Topics301,888
Posts5,204,603
Members70,796
Low VI gear oils #5332068 01/25/20 05:28 PM
dparm Offline OP
I'm shopping around for 75w90 gear oils for my C7 Corvette and am noticing that many of the well-regarded or track-focused products (Gear 300 LS, Amsoil SVG, Delvac 1, etc.) have very low VIs...usually between 140 and 160. Why are these so low despite being synthetic formulations?
By comparison, Renewable Lube's Bio-SynXtra 75w90 has a VI of 187, I suspect due to its KV @ 40C being an impressive 90cSt versus the above fluids which are all 100-120. As an aside, I find it odd that the non-LS version of Motul Gear 300 has an insane VI of 222, again due to an even more impressive KV @ 40C being 72.6cSt!
Is RLI's fluid really that much better due to its naturally high-VI basestocks, are they using VIIs, or is there something else at play? At a glance, it seems foolish not to take the RLI.
2017 Chevrolet Corvette Grand Sport
Re: Low VI gear oils [Re: dparm] #5332148 01/25/20 06:51 PM
SteveG4 Offline
Good questions! Is thinner better in high-performance vehicles? I don't know and hope for smart answers here. smile
For the last decade, I've stuck with Mobil 1™ Synthetic Gear Lube LS and have enjoyed its performance in cold Alaska.
[Linked Image]
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Low VI gear oils [Re: dparm] #5332154 01/25/20 07:01 PM
O
OVERKILL Online Content
Online Content
O
The VI of PAO base oils is very close to the range you are mentioning, so anything "high" will be pumped up with VII, which I don't think you want. The VI range you mention certainly isn't "low".
Re: Low VI gear oils [Re: OVERKILL] #5332178 01/25/20 07:33 PM
dparm Offline OP
To be more precise, all of the fluids I mentioned have very similar high-temp viscosities. Your point is certainly valid -- is a rear diff getting as hot as motor oil? Probably not. My car doesn't have a sending unit for temperature in the differential, but given that the car has a transaxle where the MTF, rear diff, and eLSD are all integrated into one big unit, there is a disadvantage with heat soak. The highest transmission temp I've ever seen is ~250 F which was at the end of a 30 minute session in 100 degree ambient temps. It does have dedicated transmission AND differential coolers.
But...the car is not on track all of the time. It all comes back to the "as thin as possible, but as thick as necessary" mantra.
Good info, but I assume RLI's gear oils are group V, like their motor oils. Their marketing folks always use this phrase: "This biobased formula has combined Stabilized HOBS technology with synthetic base stocks to provide a super high viscosity index (VI) with fuel savings performance." This leads me to believe it is not using VIIs.
Re: Low VI gear oils [Re: dparm] #5332180 01/25/20 07:37 PM
O
Online Content
O
Good info, but I assume RLI's gear oils are group V, like their motor oils. Their marketing folks always use this phrase: " This biobased formula has combined Stabilized HOBS technology with synthetic base stocks to provide a super high viscosity index (VI) with fuel savings performance". This leads me to believe it is not using VIIs.
Assuming they are using high visc POE for example, we could check XOM Chemical:
https://www.exxonmobilchemical.com/en/products/synthetic-base-stocks/esters
Esterex TM111, which is their heaviest Ester product, has a VI of 81:
https://www.exxonmobilchemical.com/en/chemicals/webapi/dps/v1/datasheets/150000000347/0/en
PAO is much higher.
shrug
Re: Low VI gear oils [Re: dparm] #5332195 01/25/20 07:51 PM
sloinker Offline
I would think the nature of a differential is a shear machine in and of itself. Add pack VI are easily sheared if I understand the literature. I would think that a gear oil with natural viscosity from a Group IV or V would be preferable. I know that racing vehicles like in Nascar utilize coolers for their differentials. I wonder what they use? Light to get rid of parasitic loss but able to deal with heat and shear. I'm guessing a robust group IV/V combination.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Low VI gear oils [Re: sloinker] #5332218 01/25/20 08:12 PM
dparm Offline OP
They're using whatever will sap the least power and just barely get the car across the finish line. cool
Re: Low VI gear oils [Re: dparm] #5332889 01/26/20 03:55 PM
N
nascarnation Offline
N
For sure.
I know for Indycar qualifying they use stuff that's about as thick as kerosene, but not for the race.
