Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
130 registered members (762fermeandyou, 1978elcamino, 390pi, 07titan, 928, 18LateModelFan, 7 invisible), 2,532 guests, and 19 spiders.
Topics301,886
Posts5,204,565
Members70,796
Page 1 of 4 1 2 3 4
Another reminder why I always change my own oil #5332042 01/25/20 04:52 PM
DreamerGT Offline OP
I bought a new to me Honda insight back in October and the dealer performed the oil change. When I was changing out the transmission fluid I noticed teeth marks from a wrench on the oil filter smirk2 Now that I think about, I bet the drain plug was torqued to 123lb the same amount the car makes LOL Any tips are welcome to remove the filter, I really don't want to buy a oil filter wrench that I'm only going to use once.
02 Ford Mustang GT 5w-20 Super Tech HM (far from stock)
15 Ford Focus ST 5w-30 Pennzoil Platinum (stock)
12 Honda Insight 0w-20 ???
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332053 01/25/20 05:04 PM
V
vw7674 Offline
V
Make your own chain wrench, (length of chain long enough to wrap around filter, + screwdriver to pass through it to act as a lever)
But first you need a section of chain to wrap the filter with.
You can puncture the filter off-center with a large screwdriver as well, but I only did that once, BIG MESS. Chain wrap is far cleaner.
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332062 01/25/20 05:20 PM
B
bubbatime Offline
B
Oil filters are not supposed to be hand tight so you’ll need a filter wrench for every oil change. Just buy the Lisle, it’s the best.
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Another reminder why I always change my own oil [Re: bubbatime] #5332070 01/25/20 05:29 PM
B
bbhero Offline
B
What ???
LOL
There's nothing wrong with hand tight... As long as you are not a total pansy with like only 50 lbs of grip strength only LOL
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332084 01/25/20 05:48 PM
F
fsdork Offline
F
I hand tighten my filters after oiling the gasket, and still need a wrench to get them off more often than not.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332089 01/25/20 05:55 PM
B
bubbatime Offline
B
Hand tight on, wrench to get off.
Re: Another reminder why I always change my own oil [Re: bubbatime] #5332115 01/25/20 06:16 PM
SteveG4 Offline
Correct.
Somewhere between Alaska and Wisconsin...
2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
Re: Another reminder why I always change my own oil [Re: bubbatime] #5332118 01/25/20 06:20 PM
P
PowerSurge Offline
P
Oil filters are not supposed to be hand tight..
You were born and raised at a Jiffy Lube, right? Lmao
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332122 01/25/20 06:24 PM
spasm3 Offline
I get my filter tight by hand, then I snug it just a bit with the oil filter wrench.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332128 01/25/20 06:28 PM
M
Maddog3355 Offline
M
Another vote for a screwdriver hammered all the way through and clean up the mess.
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332130 01/25/20 06:29 PM
I
Ihatetochangeoil Offline
I
My filter is between sizes for which they make fluted wrenches. I use a blue paper towel as a liner inside the wrench, drive it on with a dead blow hammer, then use a ratchet to loosen the filter. IF the filter were on real tight, I could use a breaker bar, as I'm sure the cast filter wrench could withstand a LOT of torque. And to install a new filter, I never use anything but my clean dry hand and moisten the gasket with new oil. I'm not a guerrilla, I'm a 5'4" man of 150 lbs. I've been changing my own oil and doing this for 40+ years and never had a leak...and every filter I've ever put on by hand takes a wrench to remove.
If you're going to go this route, save yourself a big mess. Use a drain pan in position, use a hammer and nail or ice pick, knock a hole in the lowest part of the filter and let the oil drain, then drive your screwdriver through an empty filter. Lot less mess...
Re: Another reminder why I always change my own oil [Re: bubbatime] #5332138 01/25/20 06:40 PM
super20dan Offline
totally agree. o bought the 63600 model and its the best ihave used.
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332153 01/25/20 07:01 PM
T
tiger862 Offline
T
The general rule for changing out an oil filter is after you hand tighten it, take the oil wrench and give it a quarter turn to tighten it.
Tiger862
2018 Grand Caravan
Re: Another reminder why I always change my own oil [Re: DreamerGT] #5332162 01/25/20 07:12 PM
T
ted s Offline
T
so wrong
Re: Another reminder why I always change my own oil [Re: tiger862] #5332163 01/25/20 07:13 PM
A
ammolab Offline
A
Can you post a reference to that rule? I can’t find any published instructions that include a wrench when installing an oil filter. Some thing other than the ”error-net”.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Page 1 of 4 1 2 3 4
