VW Budack Cycle 2.0T - hugely unimpressed.
by pezzy669 - 02/16/20 01:13 PM
Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
105 registered members (Avery4, 4WD, 928, 5AcresAndAFool, alchargo, 10WSmuckers, 14 invisible), 2,497 guests, and 36 spiders.
Topics301,520
Posts5,197,202
Members70,712
Software fix for blown headgasket? #5331913 01/25/20 02:01 PM
CaptainHazelwood Offline OP
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5331931 01/25/20 02:14 PM
old1 Offline
I kind of skimmed through the video, but It seems to me that what ford is doing is to change some computer settings to try to prevent the head gasket problems, not fix an already existing problem.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5331939 01/25/20 02:26 PM
Cujet Offline
Reducing peak cylinder pressure = lower power at certain RPM's.
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5331940 01/25/20 02:27 PM
Driz Offline
Sounds like you need to take a trip down the Yellow Brick Road. We’re off to see the Wizard............talk about magic pixie dust🤬. Ford sure outdid themselves with this one.
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5331972 01/25/20 03:18 PM
M
MParr Offline
M
It appears that this TSB is related to the 1.5 Ecoboost engines. I’m so glad that I did my research and avoided that engine.
https://www.fordescape.org/threads/field-service-action-19b37.114378/
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: Software fix for blown headgasket? [Re: Cujet] #5331977 01/25/20 03:23 PM
Chris142 Offline
Ya but if adjusting the timing and such is enough to prevent problems the engine has a real bad design.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5332008 01/25/20 04:02 PM
BlueOvalFitter Offline
Maybe the setting of said sensors controls the stress on faulty engine parts to reduce failures. shrug
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5332043 01/25/20 04:52 PM
Chris Meutsch Offline
I am coming closer and closer to just keeping my CR-V till death do us part. Nearly 300k and it's all good. Software schmoftware.
2005 Honda CR-V EX, 280k
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5332200 01/25/20 07:56 PM
sloinker Online Shocked
Online Shocked
I'm waiting for the software fix on their timing chain stretch issues.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5332664 01/26/20 11:47 AM
Well so if this software fix lowers performance, don't they end up in VW Dieselgate territory? Not the emissions cheating, obviously. But if the car is not delivering the performance and/or economy the buyers paid for wouldn't they be entitled to compensation?
Current top comment in YT:
hdz12ez
1 day ago
I'm no engineer but I was a Ford master technician for quite a few years. Here's what I'm thinking: These little four cylinder turbocharged engines(and almost all Ford engines these days) have a ton of cylinder pressure at higher loads in order to make the power that they do. That being said, it's possible that the cylinder head is actually lifting off of the block due to the extremely high combustion pressures and causing coolant intrusion through that tiny space that's being created. Now, these engines have what is called VCT(Variable Camshaft Timing), this is for performance and fuel efficiency. This is controlled via the PCM(Powertrain Control Module). I'm thinking that they are reprogramming the VCT so that the intake valve stays open just a bit longer on the intake stroke and into the power stroke thus creating a lower compression ratio due to less air being used for the combustion event and causing less cylinder pressures to be used. It's the same principal as the Atkinson Cycle engine. This will reduce or eliminate cylinder head lift(possibly due to head bolt stretch, (because they are torque to yield bolts) and keep the coolant from entering the combustion chamber. This will cause loss of power no doubt, how much I don't know, but probably minimal. This is the only way that I can think of coolant entering the engine without otherwise being damaged to begin with being that the cooling system is a closed loop system. This is my best guess.
Re: Software fix for blown headgasket? [Re: Chris142] #5332674 01/26/20 12:00 PM
E
emmett442 Offline
E
I think you are mistakenly assuming this is "THE" fix, when it's really just the cheapest fix. Adjusting timing advance affects cylinder pressure greatly (can technically control a 500 psi range, probably), yet is simple and this cheap to do.
Doesn't make it a bad design. It's just all they are willing to do. Apparently, they don't have to adjust it enough to reduce power or increase emissions greatly.
A little too much timing can pop head gaskets in any engine...
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5332818 01/26/20 02:35 PM
K
kc8adu Offline
K
this just delays the failure enough to get out of warranty.
like the "death flash" as i called it on the dodge trucks.
compensating tor the leaking plate on the intake rather than fixing them right.
i still have 100+ .bin files of customers trucks i pulled in case some stealership did the update against the customers orders.
so i could reverse the update.
Re: Software fix for blown headgasket? [Re: CaptainHazelwood] #5334208 01/27/20 08:45 PM
Update video. Looks like a couple of the guy's viewers are privy to details of the software fix. Appears it's programming of the elec coolant pump to keep cyl temps lower.
Re: Software fix for blown headgasket? [Re: kc8adu] #5334270 01/27/20 10:00 PM
clinebarger Offline
Didn't some of those still "Ping" after the intake plate was resealed. At least I've come across a few 5.2L/5.9L Magnums ping pretty bad in hot weather. Not that it would surprise me if Chrysler went to far on pulling back the ignition lead.
I've always wondered about the lack of Knock Sensors on this system?
2001 Chevy Camaro L92/4L80E
