2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
26 registered members (Bailes1992, bachman, 97prizm, boostedtsiawd, ArrestMeRedZ, BlakeB, 1 invisible), 809 guests, and 16 spiders.
Topics301,814
Posts5,203,184
Members70,784
EB Oil Drain Plug #5331911 01/25/20 01:59 PM
BlueOvalFitter Offline OP
Has any after market companies come up with a good replacement oil drain plug for the 2015 and newer EB engines?
My cousin owns a 2017 NAVI, 3.5 EB, and is looking for a replacement drain plug.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332031 01/25/20 04:30 PM
T
tcp71 Offline
T
Buy a few on amazon. Just over $5 each.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332044 01/25/20 04:52 PM
M
michaelluscher Offline
M
I've seen them on the shelf at my local AZ
So the aftermarket is starting to cater to them
2006 Toyota Camry SE V6
131k
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332094 01/25/20 05:58 PM
R
RhondaHonda Offline
R
I have a Fumoto in mine but I don’t have the plastic oil pan. Are you asking about the plastic pan trucks?
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332136 01/25/20 06:37 PM
bdcardinal Offline
Ronin drain plugI haven't seen one in person, but I have read good things online about them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: EB Oil Drain Plug [Re: RhondaHonda] #5332331 01/25/20 10:29 PM
Yes, the oil pans that are plastic/composite. He checked into the RONIN plug and they want $78.
He's going to call FUMOTO Monday morning and see if they make one for his pan.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332474 01/26/20 07:33 AM
R
RhondaHonda Offline
R
Last I heard they didn’t have one. I know they switched to metal pans in 2018 or 2019 but that’s probably more trouble than it is worth.
2019 Ford Raptor
Re: EB Oil Drain Plug [Re: RhondaHonda] #5332743 01/26/20 01:21 PM
That's just like Ford.
In the late 90's the 5.4 engine was spitting out spark plugs. So, in the 2K's Ford redesigned the 5.4 heads to 3 valve heads and you couldn't/can't get the plugs out! shrug
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5332955 01/26/20 05:11 PM
M
MNgopher Offline
M
Curious what problem is needing to be solved by an aftermarket solution here? Near as I can tell, these plugs work fine, and I find it to be way easier to use in real life. I keep a spare on hand that cost all of three dollars, and to date have not needed it (3.5 years in and 57 000 miles).
For the price of a Ronin, i can buy 26 replacement plugs that would last for over 200,000 miles if I replaced it with a new one every time which is not needed.
Re: EB Oil Drain Plug [Re: MNgopher] #5333174 01/26/20 08:38 PM
It's not the cost that matters (to a degree). It's when you release the factory plug you are releasing all 6 qts. of oil at one time! It can be very messy!
With an improved aftermarket plug that allows you to release the oil at a slower rate, it's not messy at all.
Just saying................ coffee
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5333395 01/27/20 07:19 AM
M
MNgopher Offline
M
I can state that is not an issue on my 2.7 equipped 2016 F150. Can't speak to the other engine platforms.
I don't mind the quick drain, with the comment make sure the drain pan has a large opening to accept the rate of flow...
Re: EB Oil Drain Plug [Re: BlueOvalFitter] #5333746 01/27/20 01:03 PM
Ford figured out their FAUS PAUX and went back to a steel threaded oil drain plug on the 2020 model vehicles. smirk2
2007 F150, 4.2 V6
"One Box, One OCI!"
