How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
118 registered members (2013ecof150, 1978elcamino, 2015_PSD, 28oz, Anduril, 750IX, 5 invisible), 2,463 guests, and 21 spiders.
Topics301,902
Posts5,205,056
Members70,798
Grease for Blend Door Actuator #5331861 01/25/20 01:05 PM
T
TheLawnRanger Offline OP
T
I ordered the "stronger" gear that is supposed to be the problem with my 2011 Impala. It didn't work. I noticed the BDA had very little grease when changing the gear. It came with a tiny tube of Super Lube. So I thought more grease may help.
It did help some. The clicking now only happens if I turn the thermostat all the way to cold or hot and randomly when the car is not running and it's much more quiet. I applied high temp wheel bearing and disc brakes grease because it was in the gun. Will this be ok? I'm planning on getting a new BDA since the new gear likely didn't work due to the other gears probably messed up as well. I would like to add this or another grease to the new part as a preventative measure.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5331945 01/25/20 02:32 PM
P
pitzel Offline
P
Petroleum derived greases (as opposed to silicone greases) may interact negatively with nylon gears. I know I opened up the BDA in my 1992 Oldsmobile one time, and it was basically bone-dry of lube, so I re-did it with silicone lube and its been okay for the past 10 years or so. Even the clear dielectric grease is probably a better idea than petroleum grease that you'd use on wheel bearings for that application.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5331979 01/25/20 03:24 PM
Dave9 Offline
It was probably warpage or plastic brittleness, not lack of lube on something that isn't high speed and only a brief moment of intermittent duty. l'd put only a tiny amount of silicone grease on it and something light like dielectric.
Clicking? If you have other gears stripped, either replace them or live with it but grease won't rebuild a stripped gear, but if too viscous in cold weather, it might put extra drag on it which can't be good.
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5334130 01/27/20 07:38 PM
Z
zzyzzx Offline
Z
Isn't any type of lube going to cause dirt to stick someplace where you really don't want it to?
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5334142 01/27/20 07:50 PM
A
askani79705 Offline
A
I finally gave up on replacing those [censored] things and just unplugged it on the fresh air position.
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala MileSYN 5w30 AC Delco Filter
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5335688 01/29/20 04:59 PM
N
nthach Offline
N
Molykote 33 or SuperLube would be my pick.
Molykote YM-103 is even better, it's a tenacious PAO grease for plastic-on-plastic parts. Toyota uses it for their door lock actuators, steering tilt gearboxes, antenna mast gears and other things. It does cost a pretty penny at $50/50g. Molykote 33 is easier to find, it's a silicone-based lithium grease.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4672754/Grease_for_Telescopic/Tilt_Scr
Re: Grease for Blend Door Actuator [Re: zzyzzx] #5336021 01/29/20 11:27 PM
P
pitzel Offline
P
The DBA's are sealed, so they're not really exposed to dirt. The problem in my experience is that the lubricant literally dries out.
Re: Grease for Blend Door Actuator [Re: TheLawnRanger] #5336386 01/30/20 11:57 AM
T
tundraotto Online Content
Online Content
T
I would use the CRC spray graphite lubricant instead of grease for above mentioned reasons.
Re: Grease for Blend Door Actuator [Re: tundraotto] #5336405 01/30/20 12:28 PM
P
pitzel Offline
P
No, graphite in electronics/electrical stuff = really bad.
