Castrol 0W-20?
by TRDPRO85 - 02/19/20 02:44 AM
What is a dealer prep fee?
by WhyMe - 02/19/20 01:01 AM
Vintage Sinclair promo
by HiPowerShooter - 02/18/20 11:29 PM
why did my Ford iolm go to 9% after 3k miles?
by dogememe - 02/18/20 11:15 PM
HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
29 registered members (dieselguy67, Bailes1992, dlundblad, bbhero, ChemLabNL, avi1777, 1 invisible), 923 guests, and 18 spiders.
Topics301,634
Posts5,199,574
Members70,746
waterpump fan clutch and thermostat now overheating #5331843 01/25/20 12:43 PM
H
HyundaiAbuser Offline OP
H
So i recently replaced the water pump, fan clutch and thermostat in my mazda b4000 due to a leaking water pump. After bleeding i let it idle for about 20 minutes with no problems at all but once driving around my neighborhood it slowly climbed to the hot whereas this has never happened before. I used an aftermarket thermostat in this case where there was a motorcraft one before which is my first instinct. Secondly i am wondering if the rtv i used on for gaskets could be clogging it up that bad? What do you guys think?
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331845 01/25/20 12:47 PM
CT8 Offline
Air pocket ? Did you check the fluid?
2015 F150 2.7
2018 F350 6.2
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331852 01/25/20 12:55 PM
slacktide_bitog Offline
Maybe it's due to air in the coolant. If you don't have one, get the Lisle coolant funnel. It makes bleeding the coolant much easier smile
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331856 01/25/20 01:00 PM
Nick1994 Offline
Probably air in the coolant. But just because a part is new doesn’t mean it’s any good. Aftermarket fan clutches often times suck, it might take a few tries to get a good one.
Take it for a drive, pop the hood, and shut off the engine and see if the fan keeps spinning or if it stops within a second or so.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331865 01/25/20 01:09 PM
Chris142 Offline
Recheck the level after it cools. If it's low fill and drive again. Did you put the stat in the correct direction? A little bit of rtv won' t plug anything up.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331881 01/25/20 01:29 PM
H
H
Update, after cooling i went back out and checked the coolant level and holy cow about a 1/2 gallon low. Total rookie mistake I just did the water pump on my hyundai and totally forgot about this. After topping off i drove around a bit and now the gauge stays between 45-55% in its given range whereas it used to sit at 25 then 55 then 70 and back to about 40 at random. I'm letting it cool off again then going to check and repeat. Thanks for the quick responses guys.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331883 01/25/20 01:29 PM
H
H
On the flip side i have lost heat in the truck so i am going to flush the heater core.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331886 01/25/20 01:33 PM
M
mk378 Offline
M
The heater can't work when the coolant is not full. Heater not working is often the first symptom it isn't full.
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331895 01/25/20 01:47 PM
R
ragtoplvr Offline
R
or first symptom that a head gasket is failing.
Rod
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331917 01/25/20 02:02 PM
Delta Offline
Air bubble.
'17 VW GTI 2.0T - 6MT - 20K - Edge 0w40
'15 Camry SE - 2.5 - 26K - PP 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 138K - RGT 5w30
