plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
94 registered members (b1amgm47, 1978elcamino, aquariuscsm, alex_at, A_User55555, AndyB, 6 invisible), 2,504 guests, and 16 spiders.
Topics301,907
Posts5,205,175
Members70,798
Oil Recommendations For Leaks? #5331755 01/25/20 10:59 AM
shurguywutt Offline OP
Does anyone have a good oil recommendation for a vehicle that has some slow leaks?
I have been running Supertech (Warren) high mileage synthetic 5w-20.
Recently I switched to Mobil 1 0w-40 because I felt like it. My truck has a few slow oil seeps that I do not want to repair right now ($$$). Should I keep running the M1 or switch to a 5w-30 HM syn? Recommendations? Thanks!
2008 Pilot 2WD J35Z1 180k
M1 Synthetic 0w-40
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331765 01/25/20 11:13 AM
O
Olas Offline
O
Maxlife is the one for leaks - viscosity should be chosen based on the climte you operat the vhicle in.
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331788 01/25/20 11:41 AM
JohnnyJohnson Online Content
Online Content
Only your truck can answer your question.
2004 Corolla 139119
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331793 01/25/20 11:48 AM
supton Online Content
Online Content
If it's a slow leak then I wonder if it leaks when hot--in which case any oil (which thins under heat) is going to leak.
In hot 'ole Florida I wonder if you are fine with a HM 10W30 and call it a day. 5W20 is fine I'd think (originally spec'd, no?), not sure you need a 40, but it isn't hurting anything, but I don't see why you'd need a 0W at all, unless if the particular oil has other properties that you want and that's what it is.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331794 01/25/20 11:49 AM
csandste Offline
Almost became the second post on this thread. I was going to say that most people will say Valvoline and that you should try a number of different brands to see which works best in your vehicle. Posts two and three cover these points exactly.
2017 Kia Soul Plus-- Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331816 01/25/20 12:15 PM
SatinSilver Offline
Valvoline Maxlife red bottle 5w30 would be my first choice.
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331824 01/25/20 12:26 PM
CT8 Offline
What is leaking?
2015 F150 2.7
2018 F350 6.2
Re: Oil Recommendations For Leaks? [Re: CT8] #5331854 01/25/20 12:58 PM
PimTac Offline
Originally Posted by CT8
What is leaking?
This is the question right here.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331871 01/25/20 01:15 PM
Danh Offline
If a HM motor oil doesn’t do the trick, try LiquiMoly Oil Saver. You can start with the recommended 300ml dose and taper off in subsequent oil changes. Worked for me, saving a very expensive front cover leak replacement on a Ford V-6.
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331874 01/25/20 01:19 PM
SatinSilver Offline
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5331898 01/25/20 01:50 PM
BlueOvalFitter Online Happy
Online Happy
Where is the leak? Will it be a PITA to repair? Valvoline Maxlife is the best HM oil to fix most slow leaks. YMMV
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Oil Recommendations For Leaks? [Re: SatinSilver] #5331921 01/25/20 02:04 PM
53' Stude Offline
Maybe do a KREEN soak or....
Try Harvest King King HM or ST HM
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Oil Recommendations For Leaks? [Re: SatinSilver] #5332011 01/25/20 04:03 PM
I thought it had been consuming oil. It may or may not have been. I just got around to fixing a couple slow leaks including the valve cover gaskets and the vtec solenoid gaskets/o-rings. It needed a valve adjustment pretty bad which I did as well. Not sure if this would help with consumption. I was told by a shop that the rear cam seal was leaking($$$)... Not really sure if this was true or maybe just another leak made it appear that it was leaking. Anyways, I figure the right oil couldn't hurt so that's where I'm at with it.
M1 Synthetic 0w-40
Re: Oil Recommendations For Leaks? [Re: 53' Stude] #5332017 01/25/20 04:08 PM
Where do you get KREEN?
M1 Synthetic 0w-40
Re: Oil Recommendations For Leaks? [Re: shurguywutt] #5332028 01/25/20 04:28 PM
spasm3 Online Happy
Online Happy
Kanolabs.com
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
