$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
103 registered members (1WildPig, ABerns, 28oz, 330indy, ABomb369, alchargo, 8 invisible), 2,080 guests, and 17 spiders.
Topics301,695
Posts5,200,763
Members70,756
'12 Odyssey EX-L trans filter #5331754 01/25/20 10:57 AM
shortlid Offline OP
66k on 2012 Honda Odysesey EX-L. It is modified for handicap access and a wheelchair so carries more equipment onboard than unusual Odyssey design. Looking to start doing drain and fills on automatic trans. Plan is Honda ATF, then canister style trans filter change. $31 for factory "lifetime filter" or Beck Arnley, aftermarket, etc for $8. Anyone have experince with the Honda canister style auto trans filters?
'06 Toyota Seinna XLE AWD 160k
'00 Ford E250 Handicap van 140K
'04 Toyota Highlander V6 4WD 3rd row 240k
'98 Dodge Ram 1500 4X4 Quad Cab 5.9 160k
'97 Ram 2500 4X$ Quad Cab 5.9 Plow truck 115k
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5332048 01/25/20 05:00 PM
discountdon Offline
https://www.odyclub.com/threads/2012-odyssey-external-in-line-transmission-filter.156596/
If my parts diagram-fu is correct, it looks like the 2011+ Odysseys have external, user-accessible ATF filters. Please refer to your respective "AT Oil Level Gauge - ATF Pipe" diagram.
5AT: 25450-P4V-013 (near the base of the ATF dipstick tube, under a 2-bolt cover)
6AT: 25430-PLR-003 (driver's side of the tranny case, about mid-height, held on by a bracket, lines have compression bands)
check schematics!
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5332066 01/25/20 05:25 PM
SubieRubyRoo Offline
It's been supposed that the factory filter is really only there to catch "chunks". IMO, especially considering changing the original is very difficult, plus the fact that most Odysseys have run their whole lives with no filter changes, plus the fact that the factory filter is probably 80 microns efficient... stick an inline Magnefine and change every 30k. Put it someplace that's accessible and carry on smile
De omnibus dubitandum.
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5335146 01/29/20 06:12 AM
R
RyanY Offline
R
The 5AT in the '12 EXL does not have an easily accessible filter. Only in the 6AT in the higher trim levels are DIY level replacements. Some folks like to install Magnefine inline with the return hose so they can change it periodically.
I just change the ATF frequently to keep things fresh (3x drain and fill at 30k and then 1x drain and fill every year after). Not the same as changing the filter but it's all that can be done without opening the transmission case.
2007 Cadillac CTS 3.6L >129k miles; Castrol Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >106k miles; STP (Amalie) 0W20 + ACDelco PF2057
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5340942 02/04/20 02:54 PM
H
hallstevenson Offline
H
Just change the fluid frequently, say every 30k miles (or more frequently if it makes you feel better). Many folks have pulled these filters after 150k miles and considered them "clean", as in there was no need to replace it after all.
