Forums Migration
Please read this thread
Price components of gasoline and diesel
by Snagglefoot - 07/10/20 08:20 AM
Peak Synthetic
by oilchangeguy - 07/10/20 07:01 AM
[Cut Open] FRAM Ultra XG7317 (6230 miles)
by DuckRyder - 07/10/20 06:41 AM
Need a New Frig
by Boomer - 07/10/20 06:01 AM
How to tell what engine mount is gone.
by mossietheno1 - 07/10/20 04:28 AM
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
Castrol Euro at Walmart, but which one?
by Impatient - 07/10/20 12:48 AM
Car Stereo Upgrade
by montero1 - 07/09/20 11:55 PM
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
Puckster02, TurbodogTodd, TNVOL, lowon, 907Lynette
71904 Registered Users
110 registered members (77Se7en, 1978elcamino, A310, 4WD, 53' Stude, 28oz, 14 invisible), 1,609 guests, and 53 spiders.
Topics307,677
Posts5,315,462
Members71,904
'12 Odyssey EX-L trans filter #5331754 01/25/20 11:57 AM
shortlid Offline OP
66k on 2012 Honda Odysesey EX-L. It is modified for handicap access and a wheelchair so carries more equipment onboard than unusual Odyssey design. Looking to start doing drain and fills on automatic trans. Plan is Honda ATF, then canister style trans filter change. $31 for factory "lifetime filter" or Beck Arnley, aftermarket, etc for $8. Anyone have experince with the Honda canister style auto trans filters?
'06 Toyota Seinna XLE AWD 160k
'04 Toyota Highlander V6 4WD 3rd row 240k
'12 Honda Odessey EX-L Handicap van 65k
'97 Ram 2500 4X4 Quad Cab 5.9 Plow truck 115k
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5332048 01/25/20 06:00 PM
discountdon Offline
https://www.odyclub.com/threads/2012-odyssey-external-in-line-transmission-filter.156596/
If my parts diagram-fu is correct, it looks like the 2011+ Odysseys have external, user-accessible ATF filters. Please refer to your respective "AT Oil Level Gauge - ATF Pipe" diagram.
5AT: 25450-P4V-013 (near the base of the ATF dipstick tube, under a 2-bolt cover)
6AT: 25430-PLR-003 (driver's side of the tranny case, about mid-height, held on by a bracket, lines have compression bands)
check schematics!
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5332066 01/25/20 06:25 PM
SubieRubyRoo Offline
It's been supposed that the factory filter is really only there to catch "chunks". IMO, especially considering changing the original is very difficult, plus the fact that most Odysseys have run their whole lives with no filter changes, plus the fact that the factory filter is probably 80 microns efficient... stick an inline Magnefine and change every 30k. Put it someplace that's accessible and carry on smile
De omnibus dubitandum.
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5335146 01/29/20 07:12 AM
R
RyanY Offline
R
The 5AT in the '12 EXL does not have an easily accessible filter. Only in the 6AT in the higher trim levels are DIY level replacements. Some folks like to install Magnefine inline with the return hose so they can change it periodically.
I just change the ATF frequently to keep things fresh (3x drain and fill at 30k and then 1x drain and fill every year after). Not the same as changing the filter but it's all that can be done without opening the transmission case.
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5340942 02/04/20 03:54 PM
H
hallstevenson Offline
H
Just change the fluid frequently, say every 30k miles (or more frequently if it makes you feel better). Many folks have pulled these filters after 150k miles and considered them "clean", as in there was no need to replace it after all.
Re: '12 Odyssey EX-L trans filter [Re: shortlid] #5457668 06/19/20 11:49 AM
shortlid Offline OP
OK doing drain and fills now. Had the original fluid tested by Blackstone. Said it was past due for change. Really has me thinking about installing inline. Stealership says not accessible on 5AT.
