Originally Posted by hallstevenson
Honda still says to change the oil filter (under most conditions*) every other oil change. If folks look up Honda's "A" service, it says "change engine oil" while a "B" means change the oil and filter. They determine these routines using a Honda-branded filter too, certainly, so even an FU filter isn't needed (although they only cost $1-2 than a Honda filter).
Completely agree, and I was aware of that as well. However, my 2 cents was based on OP's looking for reassurance that he would be OK at "extended" mileages for OCIs. Considering the mess the Odyssey filter makes by draining all over the subframe rail, I would avoid changes on it too!
