USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Key FOB Will Only Open Doors
by Gebo - 02/20/20 03:47 PM
Leather Care
by Smoky14 - 02/20/20 03:36 PM
Does Caliper Pin Boot Over Bolt Or Sleeve?
by Fitz98 - 02/20/20 03:11 PM
Costco requiring membership for food court
by WhyMe - 02/20/20 02:56 PM
Next Tesla OTA Update - Street Lights
by JeffKeryk - 02/20/20 02:49 PM
Robocalls stopped for now...
by rekit - 02/20/20 02:27 PM
Pennzoil 0w30
by Eddie - 02/20/20 01:55 PM
Using an upper cylinder lube for lean running engine?
by dunlop0078 - 02/20/20 01:45 PM
New Ford Escape...1.0 liter...really?
by grampi - 02/20/20 01:34 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
137 registered members (2009Caraman, 55hambone, A310, 4fordsd, AandPDan, 2015_PSD, 16 invisible), 2,068 guests, and 18 spiders.
Topics301,723
Posts5,201,395
Members70,763
Page 1 of 3 1 2 3
Anybody burn wood for heat? Advice please. #5331592 01/25/20 07:21 AM
dlundblad Offline OP
We have a little wood stove in the living room. Nothing fancy, but it keeps the load off the furnace. It’s a “high efficiency” stove according to the manufacturer with igniter tubes on the top of the box. Supposedly you can get 15 hours of burn time, but I haven’t been able to do that unless hot ashes count.
I bought a stovepipe thermometer to make sure the fire is hot enough not to create creosote, but I’m having a hard time maintaining that temperature long term say 3 hours or so after filling when there’s nothing but hot coals.
When it gets to the creosote level on the thermometer after burning a few hours, would this create creosote or is that more of an issue when the fire is initially warming up?
All of wood I’m burning is fully seasoned btw. Dead elm, some hickory etc. No pine. I’ve cleaned the chimney once since buying the house.. It didn’t really need it IMO, but I don’t know how often the PO used it either.
Thanks guys.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331593 01/25/20 07:23 AM
Here’s the thermometer. It normally stays on the low end of the burning range unless I open it up. The hottest I’ve ever had it was right in the middle at 12:00.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331599 01/25/20 07:27 AM
E
eljefino Offline
E
Have you tried hearth.com?
A small, hot fire is better than a big, smoldering one.
It would seem that a small one, or coals, dampened down, would not have much air flow in, so what little heat goes up the chimney will still be hot. So the thermometer should read "burn zone"... until it doesn't. All fires peter out sometime.
I bet you get creosote on every "cold start" but if you leave the stove cranking it'll "undo" that.
I have a nifty chimney cleaner, a bunch of 3-foot fiberglass rods and a nylon "weedwhacker head". Pull the stove, stick the head up the chimney, then keep clicking more rods into place. Run it with my drill. Don't have to climb on the roof. Do it once a year.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331605 01/25/20 07:40 AM
That sounds like the thing I used. A co worker let me borrow his. Seemed to work well.
I did it from the roof. Let it all fall and settle in the stove then went back a week later, removed the pipe from the stove and vacuumed out the junk.
Somewhat time consuming but no mess in the house either.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331613 01/25/20 07:46 AM
Snagglefoot Offline
When I’m home I’ll get a fire going and after it burns down to coals I load two logs at a time in a cross cross fashion. When they burn down to coals but are still in a recognizable shape, I throw on another two logs. I find throwing on only one log causes it to burn out too easily.
My stove is an airtight unit with a connection from outside air. I don't dampen it down. My temp will be 500 F when the stove has lots of wood in it burning and cruises along at around 400 F all day. I don’t mind keeping the temp high as it lowers the chance of creosote build up. So basically it has two logs in the stove most of the time. I find I need to stoke it every couple of hours and will put in three logs if I leave the house. All this is predicated on it being colder than 15 F. If it’s above that the stove just over-heats the house. I use ponderosa pine and fir. smile
If you want the job done right......do it yourself.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331635 01/25/20 08:13 AM
K
Kira Offline
K
It sounds like you don't run a fire every day.
Running a fire consistently helps you establish a routine for cleaning.
People who live on wood heat use a hot fire...get it cooking and load it up before bedtime....then let it run down.
One real drag is when you want heat and you have a "warmer day" whereby the draught is diminished .
It's an unavoidable mixture of efficient and less-efficient burning.
Re: Anybody burn wood for heat? Advice please. [Re: Kira] #5331648 01/25/20 08:24 AM
If it’s consistently cold, I’ll try to keep it running 24/7. If it’s not burning, there will at least be hot coals to get it going again. Lately it’s been a pretty mild winter so I haven’t bothered.
I’m still figuring it out as I go as I’ve never done this sort of thing before and this is my first winter officially using it.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331675 01/25/20 08:59 AM
53' Stude Offline
My brother has been using their fireplace often as they have plenty of rock oak and red and white oak in his area. You dont need much hardwood to have a fire throw off serious heat wink
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331677 01/25/20 09:00 AM
L
Lapham3 Offline
L
Our firebox is built in to a fairly massive brick structure that is also a room divider. Thus, not on an outside wall, so no cold input and all heat radiates inside the home. It can take a few hours to heat up that heatsink, but it produces pretty reliable heat, and when the fire may die down a bit that mass radiates heat for a long time. So we fuel the large box infrequently with mostly 2 - 2 1/2 foot long whole log hardwoods with pine for fire starters.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331689 01/25/20 09:16 AM
Cujet Online Content
Online Content
Of interest, the BTU content of wood varies significantly by type, but not by weight. Seasoned hardwood is considerably heavier than Sitka Spruce by size, but by weight they have similar BTU output when burned.
Re: Anybody burn wood for heat? Advice please. [Re: Cujet] #5331729 01/25/20 10:14 AM
53' Stude Offline
I would never ever burn spruce, pine or hemlock or ANY softwood. Only seasoned oak, cherry rock maple, locust or hickory
161,669 miles
Re: Anybody burn wood for heat? Advice please. [Re: 53' Stude] #5331738 01/25/20 10:28 AM
E
eljefino Offline
E
Can you see the coals with your nose that high in the air? LOL
What grows around people is what gets burned.
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331747 01/25/20 10:41 AM
CT8 Offline
I heated my past house for 17 years with high efficiency wood stove . I would build a fire and let the stove run open until the fire and stove was hot [not red hot] then close the stove damper then the air injected would burn the "smoke" which included the creosote causing parts. After the wood was really burning and starting to be red all over i would close down the air but not all the way just to slow down the burn. In the 17 years there was hardly anything to clean when I brushed the chimney. The High efficiency stoves are wonderful
2015 F150 2.7
2018 F350 6.2
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331748 01/25/20 10:42 AM
CT8 Offline
I heated my past house for 17 years with high efficiency wood stove . I would build a fire and let the stove run open until the fire and stove was hot [not the metal red hot] then close the stove damper the the air injected would burn the "smoke" which included the creosote causing parts. After the wood was really burning and starting to be red all over i would close down the air feed but not all the way, just to slow down the burn. In the 17 years there was hardly anything to clean when I brushed the chimney. The High efficiency stoves are wonderful
2015 F150 2.7
2018 F350 6.2
Re: Anybody burn wood for heat? Advice please. [Re: dlundblad] #5331773 01/25/20 11:20 AM
lewdwig Offline
I was told "back when" to throw a handful of salt in the fire when it was burning hot to help volatilize the creosote. There is a man-made "creosote sweeping log" you can burn periodically...don't know if it's compatible with a high-tech stove.
2001 Subaru Forester L
2003 Buick Park Avenue
2015 Ford Escape
Google search:
(search terms here) site:bobistheoilguy.com
Page 1 of 3 1 2 3
