Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
107 registered members (4WD, A310, 69GTX, 55hambone, ammolab, 12 invisible), 1,785 guests, and 17 spiders.
Topics302,060
Posts5,208,292
Members70,826
Temperature swing affects on oil #5331498 01/25/20 12:58 AM
L
leeaspell Offline OP
L
So in the last 9 days we have experienced a 54 degree Celsius temp swing. From -50 to +4. What kind of affect does that have on oil sitting in a sump? Got to be some condensation I would think Didnt even attemp to start the car as I never had the block heater plugged in. The hemi work truck with bulk 5w20 castrol gtx started every morning but didnt sound good. The f150 ecoboost with with PP fired up like it was summer time, but would cover the entire street in exhaust
2018 F150 3.5 Eco PP 5W30, Fram Ultra
2013 Fusion 2.5L- vwb 5w20, Napa gold
Re: Temperature swing affects on oil [Re: leeaspell] #5331500 01/25/20 01:03 AM
P
pitzel Offline
P
Well certainly the oil would become less viscous with that temperature change. You really should be using a 0W-xx oil under those conditions, and if you want to get picky, there's probably TSB's back-spec'ing 0W-20 oil in the Fusion. Heated battery blankets are probably more useful than actual block heaters. Where the heck did it get to be -50C in Alberta last week?
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Temperature swing affects on oil [Re: pitzel] #5331502 01/25/20 01:09 AM
L
L
Sorry I lied......maybe a week and a half ago. Im not sure if it was -50 but my truck stopped showing the temp after -45
Re: Temperature swing affects on oil [Re: leeaspell] #5331505 01/25/20 01:40 AM
T
Triple_Se7en Offline
T
Concerned about severe temperature swings of Alberta and not concerned about running a thinner oil in those conditions?
Why not 5w20 in the pickup and 0w20 in the Fusion, during this time of the year?
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
04' Chevy Colorado Castrol 0W40 & Wix
Re: Temperature swing affects on oil [Re: leeaspell] #5331507 01/25/20 01:53 AM
O
OilUzer Offline
O
I put a few oil in the freezer including a dino, a very good syn and PP ...
after one week, PP looked very crisp & clear like before my test.
Other oils looked foggy. Someone said fog was due to moisture ... I think maybe also wax!?
All oils were in the same freezer and next to each other and covered.
As far as -50 to +4 ... I think oil is more stressed by going to typical 230°F+ operating temperatures. Any moisture should be removed by then.
Re: Temperature swing affects on oil [Re: leeaspell] #5331551 01/25/20 05:30 AM
Snagglefoot Offline
Thursday, Jan 16, High Level, Alberta : -47 F. Close enough ! laugh
If you want the job done right......do it yourself.
Re: Temperature swing affects on oil [Re: Triple_Se7en] #5331711 01/25/20 09:47 AM
L
L
What would I gain going to 5w20 in the truck vs 5w30.
Re: Temperature swing affects on oil [Re: leeaspell] #5331730 01/25/20 10:15 AM
Snagglefoot Offline
Almost nothing. You would be much better off with 0w20 or 0w30. It’s the front number that designates the viscosity when at those low temps. I happen to be running a 0w30 in my Chev 6.0 liter V-8.
Re: Temperature swing affects on oil [Re: Snagglefoot] #5331735 01/25/20 10:22 AM
J
JLTD Offline
J
Correct. 0wXX for those temps.
Lates.
Re: Temperature swing affects on oil [Re: leeaspell] #5331745 01/25/20 10:41 AM
N
nlife Offline
N
We got down to -41c one night here in BC, but for the most part we were hovering around -30 to -35 for the week. Then bam, everything warmed up to +7c. I didn't have anywhere to plug in my F150 since we don't have a single outlet anywhere outside the place we're at, but my truck fired up like a champ every time. I can tell you that I REALLY appreciate the autostart now. I'm running PPPP 5w30 since it's a thinner oil and has great cSt numbers.
We don't typically get cold snaps like that so I'm more than comfortable running a 5w30 oil for the few days where the temps do drop significantly.
[Linked Image from cimg0.ibsrv.net]
Re: Temperature swing affects on oil [Re: leeaspell] #5331968 01/25/20 03:11 PM
T
T
5W20 is generally always thinner and easier to start (without cold start rattle) in Alberta winters.
Re: Temperature swing affects on oil [Re: leeaspell] #5332047 01/25/20 04:56 PM
T
tiger862 Online Content
Online Content
T
I would say go with 0w20 in those temps. If you look at viscosity charts at 40 degree c you will see the better flow with 0w20 than 5w30 but at running temp (100c) it is within a few centistokes so you will be safe with 0w20.
Tiger862
2018 Grand Caravan
