(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Rislone New Gas Hy-per Cleaner Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
102 registered members (01rangerxl, antonmnster, ammolab, Alaskanmont, 4WD, 53' Stude, 14 invisible), 1,890 guests, and 19 spiders.
Topics303,551
Posts5,237,307
Members71,086
electric motor amp rating #5331452 01/24/20 11:42 PM
M
motor_oil_madman Offline OP
M
So if an electric motor says it takes 23 amps, does that mean it pull that much all the time or is that only at a full load getting ready to stall?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: electric motor amp rating [Re: motor_oil_madman] #5331457 01/24/20 11:48 PM
T
tundraotto Offline
T
startup load is not usually listed on the motor spec plate....listed is the running load. starting load is much higher. like 3 times higher.
Re: electric motor amp rating [Re: motor_oil_madman] #5331460 01/24/20 11:54 PM
P10crew Online Content
Online Content
^ correct
Re: electric motor amp rating [Re: motor_oil_madman] #5331484 01/25/20 12:58 AM
M
M
Yeah but that 23 amp running load is still based off of it actually being loaded all the way down right? So even though it says 23 amps on the name plate it may only be pulling 18 or 19 correct? Or am I wrong?
Re: electric motor amp rating [Re: motor_oil_madman] #5331488 01/25/20 01:17 AM
O
oldhp Offline
O
Yes. Most likely less. I don't think you would want the motor running at it's Max or close to it all the time. I'm sure some electric motor guy will chime in here soon that will know for sure.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: electric motor amp rating [Re: motor_oil_madman] #5331504 01/25/20 02:35 AM
P
pitzel Offline
P
Yeah rated amps is at rated hp output. A synchronous motor won't exceed the rpm implied by the number of poles and the frequency of the current delivered. Nor will an induction motor which induces an excitation current in the rotor, but still relies upon phase rotation and will have slippage.
Quote
If its rated that way, I don't see the issue. That's probably the most efficient way to operate, to match an actual load to the nameplate. Of course it rarely perfectly works out that way, so reducing the motor's duty cycle, or alternatively, using a VFD to alter the (induction) motor's output can be on the table.
Re: electric motor amp rating [Re: motor_oil_madman] #5331575 01/25/20 07:44 AM
Online Content
[Linked Image]
Yes you are correct.
The amp draw shown on plate is at rated HP output.
An idling motor will be less than what is on name plate.
There can also be a SFA amp rating. That is when the motor is loaded past it’s rated output. Most but not all modern fractional horse power motors have a 1.15 service factor. The old (good uns) had a 1.25 service factor. Hence the SFA rating on the tag. There may also be a locked rotor amp spec on the tag LRA.
Re: electric motor amp rating [Re: motor_oil_madman] #5331655 01/25/20 09:33 AM
F
Farnsworth Offline
F
It's at the rated hp at the stated voltage and the duty ratings. If line voltage is 120 the amps will be less than at the115 stated on the plate. 2cents
Re: electric motor amp rating [Re: motor_oil_madman] #5331719 01/25/20 10:58 AM
sloinker Offline
Starting current can be many times full load current. Many motors run above full load amps and into service factor routinely, sometimes their full if somewhat shortened lives. I've seen more than one motor with a large floor fan or water hose utilized for cooling purposes. As stated above synchronous motors run at synchronous speeds without slip.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: electric motor amp rating [Re: sloinker] #5331925 01/25/20 03:09 PM
Online Content
^ spot on!
This is exactly why I had my power company come and jack a tap position on the transformer feeding my house and shop. Prior to the tap change I was running 113. Now I have a good strong 123/242 volts. Before they would do the tap change they installed a recording VM for 2 weeks.
Re: electric motor amp rating [Re: motor_oil_madman] #5332013 01/25/20 05:05 PM
Z
zeng Offline
Z
Yes, you're right . It is power on demand .
Re: electric motor amp rating [Re: motor_oil_madman] #5332024 01/25/20 05:18 PM
B
barryh Offline
B
Depending on the inertia involved, start up current can be as high as 5 times full load current for a single phase motor. For big 3 phase motors we used to say 7 times. That's when you use a starter that starts in star and then switches to delta when the motor is nearly up to speed Reduced voltage starting is not so simple on single phase motors making them generally less suitable for high inertia loads.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: electric motor amp rating [Re: motor_oil_madman] #5332266 01/25/20 10:04 PM
Online Content
Op mad man... did these fellas answer the 3 ?’ You had?
Re: electric motor amp rating [Re: P10crew] #5332319 01/25/20 11:11 PM
M
M
Well lets use my table saw as an example. Say it says 1-3/4hp 14 amps on the motor @ 115v. (Yes I know we typically have 120v at the wall outlet, that's just what it says on the motor). How much amperage would it be pulling when it's just running and only spinning the blade without feeding any wood throught it compared to sawing wood? I know we've agreed that it's not going to be pulling a full 14 amps, but how much amperage (estimate) would it be using just running with no load compared to sawing wood? Is it possible it's only using maybe 7 out of the 14 amps just spinning nothing but the blade?
Re: electric motor amp rating [Re: motor_oil_madman] #5332586 01/26/20 10:58 AM
M
M
P10 crew not yet. Lol
