Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
108 registered members (2013ecof150, 64bawagon, 53' Stude, 2003f7, 2015_PSD, 2004tdigls, 4 invisible), 2,141 guests, and 16 spiders.
Topics301,900
Posts5,205,001
Members70,798
Radio, Instrument panel, display, AC cutting off #5331408 01/24/20 09:39 PM
DrDanger Offline OP
So I had the radio cut off a few times 2 months ago. Read up and installed a ground wire from battery - to chassis. Problem solved. Until..
Yesterday I got to do a 100 mile trip.
Radio, Instrument panel, display, AC cutting off started on the last 10 miles. They come back on, stay on for a 2-3minutes(sometimes) and then go out again. Car drives normally otherwise.
Drove 5 miles today and re-tightened any ground cable I saw. Still same thing. And airbag warning turned on.
What could be causing the issue?
I want to run a 4 AWG from alternator to battery + to try to solve it.
OBD II sees voltage dropping from 14.4 to 12.8V, but this is only OBD module voltage.
Still tells me alternator cable is loose or worse....
Any input appreciated.
Re: Radio, Instrument panel, display, AC cutting off [Re: DrDanger] #5331426 01/24/20 10:04 PM
CT8 Offline
Bad chassis ground?
2015 F150 2.7
2018 F350 6.2
Re: Radio, Instrument panel, display, AC cutting off [Re: DrDanger] #5331582 01/25/20 07:03 AM
T
Trav Offline
T
Is this a VW?
Re: Radio, Instrument panel, display, AC cutting off [Re: DrDanger] #5331863 01/25/20 01:06 PM
DrDanger Offline OP
Car is a Peugeot 407 sedan, 2004, 90k miles, 2.0l petrol. Had not had time to check my thinking today.
Re: Radio, Instrument panel, display, AC cutting off [Re: DrDanger] #5332570 01/26/20 09:38 AM
DrDanger Offline OP
So far it looks like the fuse box ground was loose, contact sprayed it and so far, so good.
4 miles with no incident. A buddy mechanic said not to mess with battery plus to alternator.
Re: Radio, Instrument panel, display, AC cutting off [Re: DrDanger] #5332876 01/26/20 03:46 PM
T
Trav Offline
T
A common upgrade on many Euro cars is a 2 or 4 AWG alternator to battery and 2 or 4 AWG from battery to fuse box depending on alternator output and options the car has and 1/0 battery to starter.
VW got all sinister with very light cables that caused all sorts of gremlins, doing the upgrade really straightens them out to say nothing of the much faster cranking in cold winter temps.
