Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
25 registered members (alcyon, Brian553, blufeb95, Bailes1992, bbhero, 3 invisible), 1,241 guests, and 13 spiders.
Topics301,932
Posts5,205,743
Members70,801
Pentosin SP-III 15125km, 2017 Golf 1.8TSI #4891841 10/09/18 10:39 AM
Z
zero10 Offline OP
Z
Code
Lab Number              YD7066        YJ2918
Sample Date             03/03/2018    09/22/2018
Unit                    15122         30237
Oil                     15122         15125
Type                    Factory Fill  Pentosin SP-III
Tin                     0             0
Lead                    1             1
Copper                  33            17
Aluminum                9             8
Silicon                 22            7
Iron                    25            19
Chromium                0.8           0.8
Silver                  0             0
Zinc                    805           825
Magnesium               6             8
Nickel                  0             0
Barium                  0             0
Sodium                  4             1
Calcium                 1700          1600
Vanadium                1             0
Phosphorus              615           664
Molybdenum              0             0
Boron                   3             1
Manganese               5             0
Viscosity(D445)@100*C   11.38         11.77
Water(D4007) (%v/v)     0             0
Solids(D4007) (%v/v)    <0.1          <0.1
Glycol                  No            No
Fuel Dilution           No            No
Oil Changed?            Yes           Yes
Just got my results for the second change interval on this car, this is the first UOA I have on the SP-III which is the oil I am hoping to use for extended drain intervals once the warranty is up so I'm planning to get a few baseline UOAs on the shorter factory change intervals.
The copper seems a little high to me - should I worry?
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4891864 10/09/18 10:59 AM
Propflux01 Offline
Looks to me like the copper is going down. I would attribute that to engine breaking in.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4892340 10/09/18 08:31 PM
G
Garak Offline
G
I agree, and wouldn't worry. Those are kilometres, too, and the vehicle is essentially brand new.
Plain, simple Garak.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4892351 10/09/18 08:42 PM
K
Kjmack Offline
K
i have the same engine in my Jetta , its really a good compromise between power and mpg . i have 50,000 miles and it runs perfect .
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4892359 10/09/18 08:54 PM
K
Kjmack Offline
K
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4897012 10/15/18 11:04 AM
Z
zero10 Offline OP
Z
Thanks - I'll give the copper another change interval and see how it's doing. I know often times new parts have some residual copper that'll show up on the analysis I guess I just thought it would all wash out in the first change interval.
I'm happy with all the other numbers though. My driving is mostly highway but I'm a believer in the Italian tune-up so I make sure to wind it up to 6000RPM at least a couple times a day.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4900852 10/20/18 02:40 AM
L
ledslinger Offline
L
Your first change with the Pentosin seems an eerily similar formula to the factory fill. If you have an oil cooler that is brazed, that might be the copper.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4903650 10/23/18 05:23 AM
Z
zeng Offline
Z
The copper is trending down with good overall metal wear rates, and shear stable.
Is the recommended factory extended service intervals basing on service indicator around 30,000 km ?
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #4906220 10/25/18 10:43 PM
J
JOD Offline
J
Originally Posted by zero10
[code]
I have this same engine, and my results aren't that different. Wear metals were single digit by the 3rd oil change. Question though: without TBN, how will you know if you can extend the interval?
With a direct injection turbo engine, I'm not sure how much more you'll really be able to extend the OCI over the factory recommendation with a low-saps 504/507 rated oil.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5322596 01/14/20 03:40 PM
Z
zero10 Offline OP
Z
Code
Lab Number              YD7066        YJ2918            ZG5744            ZL5997
Sample Date             03/03/2018    09/22/2018        04/13/2019        11/10/2019
Unit                    15122         30237             45046             59986
Oil                     15122         15125             14809             14940
Type                    Factory Fill  Pentosin SP-III   Pentosin SP-III   Pentosin SP-III
Tin                     0             0                 1                 0
Lead                    1             1                 1                 1
Copper                  33            17                9                 5
Aluminum                9             8                 6                 4
Silicon                 22            7                 3                 3
Iron                    25            19                16                14
Chromium                0.8           0.8               0.5               0.4
Silver                  0             0                 0                 0
Zinc                    805           825               857               861
Magnesium               6             8                 7                 7
Nickel                  0             0                 0                 0
Barium                  0             0                 0                 0
Sodium                  4             1                 1                 1
Calcium                 1700          1600              1650              1600
Vanadium                1             0                 1.5               0
Phosphorus              615           664               698               662
Molybdenum              0             0                 0                 0
Boron                   3             1                 70                235
Manganese               5             0                 0.8               0
Viscosity(D445)@100*C   11.38         11.77             12.05             11.5
Water(D4007) (%v/v)     0             0                 0                 0
Solids(D4007) (%v/v)    <0.1          0                 0                 0
Glycol                  No            No                No                No
Fuel Dilution           No            No                No                No
Oil Changed?            Yes           Yes               Yes               Yes
A quick update, I've had a couple samples since the last time I posted.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5327815 01/20/20 12:01 PM
Dirtyhands1798 Offline
Looks nice. Any oil consumption between changes? Did you fill in an additional bor additive or did pentosin/fuchs add bor to their formula?
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5328634 01/21/20 10:35 AM
Z
zero10 Offline OP
Z
I always fill just over the full line (I tend to overshoot by a mm or two) and by the end of the oil change interval it's at about 25% of the way from low to full. I'd say ~0.75L of loss during the oil change interval. Drive cycle is about 75% highway 25% city, 130km/day round-trip. I make sure to wind it right up to the limiter at least once a day and there are some long hills where I have 30ish seconds of WOT in 5th gear.
The boron is really confusing because along side the ZG5744 sample I also sent in a virgin sample for analysis and it came back showing ~500ppm of boron. They called me up confused, asking if I was absolutely sure that it was the same oil I had used because it made no sense to them. I bought 3 5L jugs at the same time, the engine takes ~6-6.5L of oil so it's always 1 jug plus a bit from another... I think one of my jugs has higher boron and I can't explain why.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5330487 01/23/20 04:34 PM
B
Brons2 Offline
B
wow very nicely done! 1ppm iron per 1000 km in the latest sample. hard to argue with that!
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 5w & 10w30 seasonal, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Dealership Castrol 0w20, Mazda filter.
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5331266 01/24/20 05:25 PM
E
edyvw Offline
E
Pentosin SPIII is probably one of best VW504.00/507.00 oils. Last time I checked it was also PAO based.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Pentosin SP-III 15125km, 2017 Golf 1.8TSI [Re: zero10] #5334265 01/27/20 09:44 PM
Samrsnow Offline
This is a 5w30 or 5w40? I have the Pento-high performance II 5w40 in my old BMW at the moment.
1987 BMW e28 535is - mystery mileage (300,000+) Chevron 20w50 - Mahle filter.
