Originally Posted by TheIceStormof06
Originally Posted by wemay
@ TheIceStormof06
I did call (South Motors VW and Doral VW) and the two VW dealerships near me use Castrol exclusively for all their vehicles. Castrol is on my 2019 fill cap. Castrol and VW have extended their official partnership per press releases in 2018. That hardly means "their done".
If I may ask, which VW dealerships did you get your information from regarding this spec and others used for service?
I was also told that some dealerships use a VW branded oil made by...Castrol.
I also plan on going the full 10k miles. I also posted a UOA from Tiguan owner that showed an 8800 mile UOA that could easily have gone further. You're right that it appears to be a robust spec.
I can't speak to VW as it hasn't shown up in VW as yet. I believe my VW dealership said they can see the new part number but it hasn't arrived. That's why I mentioned I got it from Audi dealership where It just started arriving this week. They said the Castrol oils have Castrol all over it but the new Mobil VW oils are non branded Mobil oils. Me saying Castrol is done just means they are no long the exclusive and preferred Factory Fill oil for Audi and VW and you won't see Castrol mentioned specifically on fill caps moving forward... just the 504/508/507 certification respectively.
I live in GA and two dealerships confirmed it so I picked up 0W-30 & 0W-20 for both vehicles in my signature. What both Both VW dealerships in my area said is they won't order the new stuff until they deplete the old stuff and their oil fill drums. The NON 504/508/507 oils found in the drums at dealerships have caused issues. Especially with the 2.0Ts. Engine lights tripped with low miles. Heck, the local Atlanta VW dealerships were putting regular Non certified oil 0w-20 in the V6 Atlas. They use 0W-20 on ALL their oil changes except the Routon. VW is clamping down since the spike in warranty claims.
I'll be opening and doing a oil change tomorrow with the 0W-20. Will report back.
From 2018:
https://pronounce.media/press-relea...ronounce-concierge-service/2018-01-09/87
Below that, is the part number which comes back to Castrol Edge 0W-20 (508.00) on a service performed on my Passat last year, July.
