Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
40 registered members (AZjeff, bmod305, bbhero, Bookmaker, Bjornviken, Bighorn2500, 6 invisible), 1,103 guests, and 19 spiders.
Topics301,934
Posts5,205,766
Members70,801
Thinking about transmission cooler for Honda #5331141 01/24/20 02:26 PM
J
jayjr1105 Offline OP
J
So I've been keeping up with dump and fills every so often on the Odyssey but now I'm reading that an ATF cooler install could also help with longevity of the transmission. Kits are as cheap as $30 on amazon that have 4.5/5 reviews. Seems like a no brainer for $30 and a weekend afternoon spent but I'll wait to hear from people who have done this.
https://www.amazon.com/Hayden-Automotive-516-Performance-Transmission/dp/B000C3BBEY/
Does the transmission naturally pump the fluid through this or do you need a pump? Where are there even transmission fittings on the vehicle?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5331143 01/24/20 02:31 PM
SubieRubyRoo Offline
I used one of the Long Tru-Cools, I think it was LPD4454; it has two different size channels in it so it does not utilize the full cooler until the fluid is hot and thin. Kind of like a built-in thermostat. Seem to remember it was about $45.
De omnibus dubitandum.
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5331148 01/24/20 02:34 PM
J
J
Those Long Tru-Cools seem like the prices are all bloated because they are referenced so often. Do you have to drop the front bumper? How difficult is the install overall?
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5331152 01/24/20 02:39 PM
Dave Sherman Offline
I installed one on a Subaru, it's not difficult. There is already an ATF cooler in the radiator. Follow the lines from the transmission to the radiator. You will want to find the line going TO the cooler in the radiator, you'll put the additional cooler in BEFORE the stock cooler. That way, the additional cooler will be most effective at losing the heat, and you won't over-cool the fluid. Disconnect one of the lines, start the engine briefly, and see which line is squirting out ATF to figure out which one is the one going to the cooler.
If you're not towing anything, I don't think an additional cooler is going to do a lot for you though. If longevity is your intent, I think a Magnefine filter might be a better idea.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5331154 01/24/20 02:44 PM
CT8 Offline
Is the reliability problem from poor design or low quality parts or the fluid overheating?
2015 F150 2.7
2018 F350 6.2
Re: Thinking about transmission cooler for Honda [Re: CT8] #5331155 01/24/20 02:46 PM
J
J
Older models had bearing issues. New models is just from heat/wear & tear I believe.
If this is $30 though and a fun little project, that's pretty cheap even if it only slightly improves the longevity of the transmission right?
Define towing? Several kids and luggage, roof rack carrier, plus bike rack with 4 bikes. This is only a few times a year but you have to admit that's some extra weight.
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5332191 01/25/20 07:48 PM
J
J
I bit the bullet and got this one. $25, tons of good reviews. I'll wait for a nice Saturday to install it.
https://www.amazon.com/gp/product/B000C39C86/
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5333770 01/27/20 01:28 PM
Z
zorobabel Offline
Z
Return it and buy one of the stacked plate coolers like the Hayden 677 or 678. They are so much easier to mount.
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5333791 01/27/20 01:48 PM
I have the Hayden 678 on my Outback. Took like 25 minutes to install from start to finish using the metal straps and the generous room through the radiator openings in the front bumper cover. Other than missing the bypass feature of the Tru-Cool, I feel they’re essentially identical in form and function and the Hayden was about 55% of the Tru-Cool.
Re: Thinking about transmission cooler for Honda [Re: zorobabel] #5334028 01/27/20 06:01 PM
J
J
It's a 15 year old van that I'm trying to extend the tranny life in. Doesn't need to be fancy. Not too worried about the extra few degrees I'd gain from the stacked plate design but I appreciate the recommendation. I am okay with the mounting clips going through the fins. I understand how the drilled side plates could make it easier however.
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5334519 01/28/20 09:42 AM
Z
zorobabel Offline
Z
Are you OK with replacing the AC condenser and the extra work on the AC system? I would not use the mounting clips; in fact, I still have 2 packs of them unopened from my 2 installations.
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5335241 01/29/20 08:20 AM
W
WyrTwister Offline
W
My late Dad and Mom had a small / medium size Airstream travel trailer . They used it to go fishing .
They had a ~ 1978 Ford LTD With 3 speed automatic , 302 ci V-8 engine & numerically low gear ratio differential . This put a lot of strain on the transmission , while towing the Airstream .
One time , they went fishing . Dad was driving to the lake , with a tail wind ( less air flowing through the radiator ) . Transmission blew the front / torque converter seal and started loosing ATF .
They limped into the next town and got the transmission fixed . The technician recommended an external cooler .
After they returned from fishing , they came to our house . Dad asked me if I would help him install a cooler . I said , certainly . We went to checker auto parts , near our house . Dad purchase the largest cooler they stocked .
We installed it and Dad never had any transmission problems with that car . Next car they purchased was a 1991 Chevy Caprice with 5.0l V-8 & overdrive automatic , and numerically low gear ratio automatic transmission .
Dad asked me to help him install a cooler , before he ever towed the trailer . Never had any transmission problems .
Wyr
God bless
Re: Thinking about transmission cooler for Honda [Re: jayjr1105] #5335258 01/29/20 08:40 AM
Schmoe Offline
1000's of those vans on the road without an AT cooler.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: Thinking about transmission cooler for Honda [Re: Schmoe] #5335288 01/29/20 09:12 AM
J
J
Again, kits are anywhere from $25 to $60. What does a transmission cost?
