Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
34 registered members (avi1777, ArrestMeRedZ, 14Accent, blufeb95, bbhero, 5 invisible), 1,071 guests, and 19 spiders.
Topics301,683
Posts5,200,447
Members70,756
Orbital Buffer - Boat Detailing #5330982 01/24/20 10:32 AM
P
PontiacHO Offline OP
P
Any recommendations on a decent orbital buffer? Wondering if Northern Tool may have one that would be suitable for use 4 or 5 times a year. Would also like to try and avoid the bonnet style pads. They tend to get floppy. Thanks.
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5330983 01/24/20 10:35 AM
Donald Offline
What about the HF DA buffer. I use it on my boat. I thought DA was a step about orbital.
I have the best looking waxed boat on a trailer as I never dirty it with river or lake water.
2015 Ford F-250 w/Powerstroke
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331000 01/24/20 11:00 AM
The Critic Online Crying
Online Crying
For a boat (gelcoat), rotary is the only way to go.
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331008 01/24/20 11:15 AM
P
P
So the dual action is rotary and orbital action combined?
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331019 01/24/20 11:25 AM
K
kschachn Offline
K
Google is applicable here:
https://buffandshine.com/collections/dual-action-polisher-pads
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331040 01/24/20 12:00 PM
Donald Offline
It may also depend on how good you are. While a rotary is the fastest type of buffer it can damage paint if you screw up. Maybe harder to damage gelcoat than car paint.
I like the HF DA.
Re: Orbital Buffer - Boat Detailing [Re: Donald] #5331046 01/24/20 12:06 PM
Online Crying
I like the HF DA.
It is a lot harder to damage gel-coat.
Even for automotive paint, the current flavor is to use lower-speeds on a rotary, similar to how rotary is currently used in Europe. With speeds <1500 rpm, the likelihood of damage is reduced significantly.
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331069 01/24/20 12:51 PM
1
1978elcamino Offline
1
I have the HF polisher, except for the somewhat short cord it actually works really well. Its the red one, not the drillmaster black one. Dont buy the HF pads, they are terrible.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331074 01/24/20 12:55 PM
P
P
Thanks. I’m in need of something that speeds up the process. The hull is one thing but add in the interior and hard top it takes a lot of time. I’d rather be on the water fishing instead of hand waxing-buffing.
Anybody using Woody wax?
I assume that I would need to do a cleaner first to remove the haze etc.
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331166 01/24/20 02:56 PM
Driz Offline
Post a pic of what you got there. what year boat what kind. How many eons🤦🏻‍♂️ ago did someone buff it. Don’t be afraid of buffing through gell coat It’s hugely thick Only warnings buff OFF sharp edges if you can NOT INTO the edge. If you can help it . That’s the one place you really can cut in super fast if using heavy compound. Just be careful of that . Decals too, do those by hand in between ect. If there’s heavy haze you may have to use wet/ dry (. Black ) sandpaper and water or you’ll buff till October🤦🏻‍♂️
Do small portions at a time. Expect it to take a week if you’re smart. Start someplace easy to see and work on and alternate to a PITA spot then back again ect. Why🤣 to save your back, knees and mind.! When you get tired quit or you’ll start hating life. Do wear safety glasses always as that compound gets tossed all over.
HF low speed grinders Ok. Nothing high speed like the hi speed type. Don’t use one of those tie on bonnets throw it away!!! Get a good one.
Check out YouTube there’s plenty of good hull cleanup videos .
Re: Orbital Buffer - Boat Detailing [Re: Driz] #5331277 01/24/20 05:41 PM
P
P
Not sure how to post a photo. It’s a 23 ft center console. Not big but every surface needs buffed and waxed. Even the powder coated leaning post and t-top rails.
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331282 01/24/20 05:50 PM
T
Trav Offline
T
Do you have a decent sized air compressor?
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331312 01/24/20 06:40 PM
B
bcossa2001 Offline
B
I have the 6”HF Drillmaster. Use it monthly on cars. No issues and recommend it.....
"Facts are pesky things"
2003 Town & Country--143 k
2016 Fusion 8 k
2016 Fusion 34 k
2017 Santa Fe 8k
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331331 01/24/20 07:21 PM
O
ondarvr Offline
O
HF buffers are good enough, they sell several different levels of performance.
Get the hook and loop pads in wool and foam, wool for faster cutting, foam for a higher gloss.
Use a multi step buffing compound system. Fast cutting products won’t yield as high of a shine as polishing compounds.
Not all gel coats buff out in the same way, some only require a quick buff, some need to be sanded, and on others nothing will make it look good again.
Do a very small area first to determine the exact method needed to achieve the desired result.
Re: Orbital Buffer - Boat Detailing [Re: PontiacHO] #5331590 01/25/20 07:16 AM
P
P
Thanks for the great info shared here. Now it’s a matter of making the time to travel 200 miles pull the boat from my wet slip and go to work. 1st world problems. Life is good.
