Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
110 registered members (ammolab, Astro14, atikovi, 4WD, AdditiveOCD, 10 invisible), 1,831 guests, and 20 spiders.
Topics302,058
Posts5,208,274
Members70,826
Forscan for Windows #5330854 01/24/20 07:30 AM
Donald Offline OP
I am looking to install Forscan on my PC and use it with a bluetooth OBDDII adapter and buy a key for my Ford pickup on Amazon and program it using Forscan. Has anyone had success with this? I have a bluetooth OBDII connector I use with Torque, will it work with Forscan also? Or do I need a special one for Forscan?
There are a few keys on Amazon. Anyone have good or bad luck with a particular aftermarket key?
I wonder how much a uncut/unprogrammed key is from a Ford dealer?
2015 Ford F-250 w/Powerstroke
Re: Forscan for Windows [Re: Donald] #5330869 01/24/20 07:58 AM
H
hallstevenson Offline
H
I use it on my wife's Fusion. It does things that Torque can't do, so you generally want both. I used it for non-engine-related things like enabling DRLs, "Bambi" mode, turning on an equalizer for the audio system, etc, etc.
This is the ELM327 adapter I use.
The adapter needs to be able to read/write (toggle) between ALL of the CANBUS networks the vehicle has. Some adapters don't.
Re: Forscan for Windows [Re: Donald] #5330878 01/24/20 08:17 AM
B
BMWTurboDzl Offline
B
Am I the only one who experiences a Freudian slip every time I read posts on this topic?
435i
Re: Forscan for Windows [Re: BMWTurboDzl] #5330881 01/24/20 08:21 AM
Donald Offline OP
yes
Re: Forscan for Windows [Re: Donald] #5330908 01/24/20 08:50 AM
R
racin4ds Offline
R
I've never used it to program a key but Forscan and the cheap ELM adapter works wonderful on my 05 PowerStroke truck. I can run all diagnostic functions and even turn off injectors one by one. Without a doubt the most awesome program out for a ford that doesn't cost and arm and a leg!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Forscan for Windows [Re: Donald] #5330919 01/24/20 09:01 AM
R
redhat Offline
R
Yes, I've used them on many Fords, a 12 Fusion, my 17 Taurus and my 19 F150. I would recommend getting one that has a switch to go between HCAN and MSCAN (high-speed and medium speed canbus) as some Fords modules live in different networks.
The one Hallstevenson posted should work fine. I bought mine off of Amazon as well. Besides a USB HCAN/MSCAN swtiched one, I have used a cheap ELM Bluetooth one with good results, but it was only HCAN.
My biggest take away is always write down the hex values you're changing incase you want to go back. But besides that, the software is pretty easy to use.
19 F150 2.7 - MCSB 5W-30, FL2062, 15k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 32k
84 JD 316 Repowered w/Vanguard 18
Re: Forscan for Windows [Re: racin4ds] #5330930 01/24/20 09:20 AM
F
ford46guy Offline
F
It was created by a Russian programming genius. I've worked with him to get the ford door keycodes. He logged things on all my ford cars below and now the feature is mainstream.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Forscan for Windows [Re: Donald] #5330969 01/24/20 10:12 AM
R
Rand Offline
R
yes
Absolutely.
Re: Forscan for Windows [Re: Donald] #5331026 01/24/20 11:32 AM
T
tcp71 Offline
T
I used it to adjust the sound system on my truck when I added a subwoofer and turn the tpms off every winter when I put the winter wheels (without tpms sensors) on. Use a USB version with the switch. Works great.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Forscan for Windows [Re: ford46guy] #5331068 01/24/20 12:49 PM
R
racin4ds Offline
R
Yes, quite an intelligent fella!!! I'd love to work with him directly and ask a few questions about some features for the PSD trucks....
05 F350 Powerstroke
05 Hyundai Tucson
Re: Forscan for Windows [Re: Donald] #5331324 01/24/20 07:03 PM
Q
qdeezie Offline
Q
I've used it to program new keys on my '03 Focus and '06 King Ranch. I order my OEM key blanks online and get them cut at a local locksmith and program at home in my driveway. Works like a charm. I use that ELM327 connector as well.
'90 F150 XLT Lariat
'13 Hyundai Elantra Coupe SE
'03 Ford Focus ZX3
'06 F150 King Ranch
Re: Forscan for Windows [Re: Donald] #5331330 01/24/20 07:16 PM
dan_erickson Online Content
Online Content
I got a new key on eBay for about $25. It was a refurbished key with a new key blade. Looked brand new. I was skeptical of any aftermarket keys and I was also told by a mechanic not to use aftermarket keys. I had the refurbished key cut and then I programmed it was forscan. Very easy on a 2011 Fusion.
I am not sure what car or key the OP has but a basic 4 button Fusion key was over $100 from the dealer and then 1 hour of labor for programming.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: Forscan for Windows [Re: Donald] #5331741 01/25/20 10:35 AM
J
JustinH Offline
J
Can you tell me if you needed two working keys to use forscan to program a third key?
I have one key for my escape, and have one new blank, if I just get it cut can I program it myself?
'16 Ford Escape
'11 Scion XB
Re: Forscan for Windows [Re: Donald] #5331746 01/25/20 10:41 AM
dogememe Online Content
Online Content
I use Forscan with an OBDLink MX to do key programming. I've done it on my Escape and my previous Escape. It works well, very easy... Only problem I had is one time the key I bought off eBay and had cut locally then didn't work because the chip inside the key was the wrong one. So we had to buy one locally at 3x the price because the car wouldn't start anymore with just one programmed key.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Forscan for Windows [Re: Donald] #5332639 01/26/20 11:12 AM
Donald Offline OP
I bought a new OEM key w/fob on EBAY. I will get it cut at my trusted locksmith. Not going to trust Home Depot to cut a $100 key. Then use Forscan.
So I should find my lost key in 2 weeks once I get the replacement all set.
