Good luck finding that... is there a reason why you're interested in specific groups? That alone won't guarantee "better" performance or protection. If you're interested in the best performance, most discussions IIRC have always gone back to the MIL SPEC 2105E/ SAE J2360 as being the granddaddy of them all... basically, if your gear oil meets this, it's the cream of the crop. Maybe I'm wrong.
Quote
MIL-PRF-2105E this specification released in 1995 combines the performance requirements of its predecessor (MIL-L-2105D) and API MT-1. MIL-PRF-2105E maintains all existing chemical/physical requirements, stationary axle test requirements, field test requirements and data review by the Lubricants Review Institute that were required under MIL-L-2105D. It also adds the stringent oil seal compatibility and thermal durability test requirements under API MT-1. MIL-PRF-2105E has been re-written as SAE Standard J2360. SAE J2360 standard is a new global quality standard that defines a level of performance equivalent to that defined by MIL-PRF-2105E, a U.S. military standard for approval that was not available to oil blenders in all parts of the world. It includes all of the most recent axle and transmission testing requirements identified in API GL-5, API MT-1, and MIL-PRF-2105E including the need to demonstrate proof-of-performance through rigorous field testing.
