Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Dishwasher makes crackling noise
by jayjr1105 - 02/19/20 05:33 PM
what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
107 registered members (01VFR, 2010Civic, Aero540T, 2003f7, 74Widebody, 10 invisible), 1,765 guests, and 26 spiders.
Topics301,679
Posts5,200,371
Members70,756
Page 2 of 2 1 2
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5330666 01/23/20 08:23 PM
B
Bonz Offline
B
Reality is, if it concerns anyone in the least, don't use it. Asking the question again and trying to regurgitate it doesn't change what has been the case for a long time. And that is the oil works just fine. Take it or leave it. Cheers2
Re: Did Rotella Ever Have JASO MA Certification? [Re: blupupher] #5330817 01/24/20 06:40 AM
A
alarmguy Offline
A
Originally Posted by blupupher
Originally Posted by ad244
Its on the bottle on their latest T6 15w-40
No it is not.
Show me where it says Certified (not meets requirements of) JASO MA/MA2 on the bottle.
Show me the JASO label on the bottle with the JASO number on it.
This is what the bottle says:
[Linked Image]
And there is no JASO label that would look like this one on Honda oil:
[Linked Image]
Again, not saying it is not a good oil for motorcycles, because it is, but it is not a certified JASO MA/MA2 oil.
Shell just says it is safe to use in JASO MA/MA2 applications, which we have probably millions of miles on bikes using this oil with no oil related issues.
Those that seem to get their panties in a wad over this need to get over it.
Use it with no concerns, but if you use it and there is any issue that could be even slightly related to oil and bike is under warranty, you are probably out of luck.
Exactly ^^^ Shell has never been published as a Jaso Oil on the Jaso website. Shell does not print the Jaso symbol on its bottles for that reason.
With that said, Jaso states something along the lines of the oil company REGISTERING their oil that it complies with Jaso standards so I am not so sure that Jaso actually tests and "approves" oils vs the companies registering as it meets their requirements.
Either way, Im sure its all good if the oil company is stating it does but I do agree 100% that is it not a Jaso MA oil unless the oil is published on Jasos website and carries the Jaso symbol. I pointed this out many times about Mobile 1 oils too where Valvolines bottles has the actual Jaso symbol on some of their oils, I think the 20/50 or maybe the 10/40 4 stroke ( I forgot which one since my current bike doesnt require it)
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Did Rotella Ever Have JASO MA Certification? [Re: jayjr1105] #5330819 01/24/20 06:43 AM
A
alarmguy Offline
A
Originally Posted by jayjr1105
Rotella T4 15w40 and T6 5w40 are both JASO MA/MA2 certified. I use it in two honda ranchers with electronic shift.
No its not ^^ read above^^
You will not find the Jaso MA trademark symbol on a bottle of Shell Rotella oil.
07 Suzuki C50
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5331055 01/24/20 12:27 PM
B
BBDartCA Offline OP
B
The reason I raised the concern is regarding warranty approval for a suspect lube failure. If the Motorcycle OEM specified that a JASO MA oil was needed, and a non-registered JASO oil was all that was recorded as being used, the risk for claim denial may be higher. Not a relevant concern for many as I am sure a lot of us are riding bikes well out of warranty. And of course not saying Rotella isnt a quality MC lube.
Below is the MA2 approval markings I am accustom to seeing. Includes the registration number.
[Linked Image]
Former lube industry insider...now vehicle OEM engineering insider.
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5331180 01/24/20 03:17 PM
DGXR Offline
I also have understood that if it doesn't have the JASO label on it, that it meets the specs but is not officially approved or certified. In other words, the oil manufacturer states that the oil provides equivalent performance but won't ponying up for the cost of testing and certification. I'm pretty sure Shell would not put its reputation on the line unless the product is very good. Thousands of motorcyclists can attest to the good value and performance. Use Rotella MA/MA2 oils with confidence.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5331476 01/24/20 11:45 PM
A
Analyzer Offline
A
[Linked Image]
I get what you're saying, and it is a valid concern. Having a lubricant based failure on a modern motorcycle from a reputable manufacturer is nearly non existent. As long as you are using a quality oil from a reputable company, that meets or exceeds the specifications for you're motorcycle, and changing the oil at appropriate intervals, you have nothing to worry about.
Even if you were to have a warranty claim linked to a potentially failed lubricant and you were denied coverage, you could contest their findings. This would then fall on the manufacturer to prove that the failure was caused by the lubricant, and not any other possibilities.
In essence, use a quality oil from a reputable manufacturer, that meets the manufactures specs, changed at the recommended intervals, and your odds of a lubricant based failure will be negligible.
2007 Yamaha FZ1
1986 Yamaha FZX700 Fazer
1997 Suzuki RM250
2016 Mazda 3 Sport
1992 Ford Explorer Eddie Bauer 4x4
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5331666 01/25/20 08:43 AM
B
Bonz Offline
B
Help me recall, however I believe it's been shared somewhere on the forum at one point or another that Shell has said via email response they will back an oil related failure when their product is used in a situation they certify it for use. Probably laughing all the way at every email they get from someone, lol.
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5331668 01/25/20 08:44 AM
A
alarmguy Offline
A
Did any of the Rotella products ever have an actual JASO MA license /approval? ...
http://www.jalos.or.jp/onfile/pdf/4T_EV_LIST.pdf
No
07 Suzuki C50
Re: Did Rotella Ever Have JASO MA Certification? [Re: Analyzer] #5331805 01/25/20 11:58 AM
B
BBDartCA Offline OP
B
Originally Posted by Analyzer
[quote=BBDartCA]
I agree and dissaree. Agree that lube failures due to oil quality are normally unlikely in modern motorcycles. But disagree on warranty rejection. OEMs, when they have a big expensive problem, will sometimes, maybe more often than not, look for loopholes to deny claims. In a very specific case, Moto Guzzi had a disaster with the 8v 1200 cams going flat. While they were trying to figure out what was going on and weasel their way out of responsibility, excuses like “unapprpved Oil” were used to deny claims (the fix was horribly expensive and they administered it very poorly). I see countless other examples but they are not shareable in the public domain.
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5332073 01/25/20 05:30 PM
B
Bonz Offline
B
Ironic, when something is wrong mechanically with a design or a flaw that causes an oil-related problem, you just need to have an oil that meets the manufacturers requirements in the engine. Has nothing to do with the oil being a "good" oil or a "bad" oil based on analysis or other measure of oil quality.
Thanks for the example of Moto Guzzi.
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5332628 01/26/20 10:55 AM
A
alarmguy Offline
A
[Linked Image]
Correct and nothing wrong with your thinking.
Valvoline 4 stroke 20/50 has the same.
07 Suzuki C50
Re: Did Rotella Ever Have JASO MA Certification? [Re: BBDartCA] #5332996 01/26/20 05:43 PM
BusyLittleShop Offline
Unapproved oil is an excuse...
Your Honor, I argue the manufacture's claim is indefensible because ruffly 6.8 % of an new oil change is contaminated with undrained oil... mix in the contamination of multi oil changes and you must deceived in favor of my client...
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Page 2 of 2 1 2
