Originally Posted by Imp4
Whatever the product, do a reasonable preventative maintenance schedule and just about any major brand of product will work fine.
Its not quite that clear cut, some products arent compatible I had major issues using the little packets of permatex brake lube. They would swell the rubber on the caliper pins and cause sticking.
C'mon man, that's just disingenuous.
People use that product all the time with satisfactory results.
The fact that you used the permatex packet and experienced swollen caliper boots does not mean the permatex caused the problem. You and I each could come up with 7 additional contributing factors that may have resulted in that condition.
not swollen caliper boots.. the rubber on the caliper guide pin swelled up and caused sticking.. also seems to dry out more than sil-glyde.
Sil-glyde after 2+ years was lightly discolored yellowish.. still great..
permatex packet after 2-3 years mostly dried .. needed cleaned up and fresh applied badly.
Commenting on why I dont use those packets anymore and switched to sil-glyde.
no need to break out the large incorrectly used adjectives or take offense.
If it works for you great. I didnt like it.. I am interested in others but I do brakes about every 2 years.. still have 3/4 tube of sil-glyde I'm throwing out because its 8 years old.. and the cap broke. Also the fleet is now newer I only do brakes on 1 car instead of 3.
I might consider
https://www.amazon.com/Raybestos-DBL-2T-Brake-Lube-Brush/dp/B0015RCGRM when I need to buy but that is aprox 3 lifetimes worth for me.
