Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
46 registered members (Amkeer, bbhero, BlakeB, ArgleBargle, AZjeff, Bjornviken, 5 invisible), 1,141 guests, and 25 spiders.
Topics301,934
Posts5,205,768
Members70,801
1997 Civic Ignition Module & Coil Replacement? #5330157 01/23/20 09:38 AM
N
njohnson Offline OP
N
Hey Everyone,
My brother and I believe the ignition control module on his 1997 Civic is going bad. He is going to replace it in the next couple of days, but, he was wondering if the ignition coil should be replaced at the same time? Is it a good idea to replace both?
Thanks,
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: njohnson] #5330187 01/23/20 10:14 AM
J
jayjr1105 Offline
J
There is a good Eric the car guy video on this and he explains what to look for and if other components should be replaced.
https://www.youtube.com/watch?v=RpJpIWLbi2o
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: njohnson] #5330259 01/23/20 11:33 AM
SubyRoo Offline
If it's in his budget I would go ahead and replace the coil also. He might as well since he will be right there and its just two screws and two wires holding it in place.
1999 Acura Integra GS-R 273K
1998 Honda CR-V EX 263K
2010 Mazda 3 60K
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: njohnson] #5330312 01/23/20 01:23 PM
N
nthach Offline
N
Before swapping out the ICM, I'd test it - Honda has the procedure outlined in their service literature. They rarely ever fail. The coil is easy but I'm leery of non-OEM parts.
Have the valves ever been adjusted? Might want to do that first on a cold engine. It's an oft-overlooked item on Hondas and can do wonders for driveability.
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: njohnson] #5330346 01/23/20 02:18 PM
M
mk378 Offline
M
The typical ICM failure is that the engine will work fine for several miles then suddenly stall completely dead and crank but not start. After a few minutes to cool off it can be re-started. Testing during the time that it won't start reveals there is no spark.
If the car does this it's very likely the ICM. If it does something else you should check further.
The coil is prone to blow out and stay dead. A coil bad in this way will make small sparks to a grounded test wire with the cap off, but they aren't hot enough to fire the engine. Firing into an open circuit (bad spark wires or spark wire removed while running) is a lot of stress on the coil.
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: mk378] #5330383 01/23/20 02:53 PM
N
njohnson Offline OP
N
That is exactly what is happening. He drives for a couple of miles, the engine stalls and after pulling over to the side of the road, it cranks but won't start. After a few minutes, it restarts and then doesn't do it again for the rest of the trip. That is why we think it is the ignition control module.
He was thinking if he should replace the ignition coil while we are replacing the module.
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: nthach] #5330389 01/23/20 02:57 PM
N
njohnson Offline OP
N
Where is this Honda service literature? We don't know how to test the ICM ourselves without it.
Re: 1997 Civic Ignition Module & Coil Replacement? [Re: njohnson] #5330532 01/23/20 05:47 PM
Dave9 Offline
Most things like this are online somewhere.
https://honda-tech.com/how-tos/a/honda-civic-how-to-test-and-replace-ignition-control-module-374873
I would not replace the coils as long as they seem to be working, unless you plan long trips where it is likely you'd need to tow it to a shop and pay someone else to fix it... but then you could rationalize at least several hundreds of dollars worth of pre-emptive repairs. At some point if reliability is paramount, it is time for a newer vehicle for longer trips.
